Question about Canon EOS-1D Mark II Digital Camera
Hi, I`ve got Canon 1D mark II n with shutter problem. There is an overexposed streak that runs 3/4 across the image about an inch wide
    Brigadier General:
  • 3,006 Answers
Your camera almost certainly has a shutter fault and must be professionally repaired.
Replacement and recalibration is a not a DIY job. Expect to need a new shutter assembly; it's not cheap but is still cheaper than another SLR.
If you're very lucky, the repairer may find a simple fault with the existing mechanism and offer to fix it but if you depend upon your camera for a living then be absolutely sure that it's as reliable a repair as replacing the shutter assembly. If the fault has existed for more than a couple of dozen of shots then there will already be adverse wear to other elements of the shutter assembly which may either cause it to fail again soon or will require it to be recalibrated.
I hope that my answer has been of assistance, please take a moment to rate my free answer.
Posted on Sep 30, 2010
How do you clean the Shutter inside a Conon 1D Mark II ?
With black images and you cannot see shutter action, it sounds as though you have a shutter failure. There should be a "clean sensor" setting in the menu that will hold the shutter open until you power off the camera. If the shutter still doesn't open with this feature then the shutter has failed and will need to go in for repair.
Jul 03, 2014 | Canon EOS-1D Mark II Digital Camera
My Canon 1D MkII suddenly started capturing images completely black. File sizes are smaller 2, the black images are only 2mb. Could it be possible the data is no longer getting recorded to the memory...
The first thought I had come to mind was the shutter has failed but, the Canon 1D MK II shutter is capable of 150,000 actuation. If you feel this is not possible then another thing you may want to look into is the memory card needing to be cleared of pictures and formatted in the camera, always format your memory cards in the camera. The Canon 1D MK II has two memory card slots it is possible to have one card undersized and it's run out of space, the camera will not automatically shift to the unused card it needs to be done manually through the small screen on the back.
This just happened to me while in a portrait shoot the battery died to the point it wouldn't even show the setting on the top LCD screen or the viewfinder. I replaced the battery and continued to shooting. The camera had been set on RAW but after the battery failure it began shooting RAW+ s jpg. If you had the camera set for jpg images and the battery failed as it did mine then it's entirely possible that the camera defaulted to small jpg files. Okay last suggestion and possible the most important. The Canon 1D MK II with original firmware installed is capable of working with a 4gig memory card Compact Flash or SD, if you have installed a larger card and just attempted to shoot with it without formatting, the camera will refuse to cooperate. If this is the case and you have installed a 8gig memory card(s) for example first try to format the card and if this failes then you need to go to the Canon site download the updated firmware for that camera and do an update. Everything will be good after you do this, when I did the update for mine there were seven updates one of which corrected the limitations on the memory card size. If the lens contacts are dirty and the camera is getting poor information from the lens you would I think receive a code 99 so not receiving any code of fault I'd say it's the card.
Cheers
Apr 18, 2011 | Canon EOS-1D Mark II Digital Camera
I need the instruction manual of the canon eos 1d markII in spanish but cannot find it on the internet, I only find english and is no good for me. Any advice? thanks Maria
Hi Maria,
start here:
http://software.canon-europe.com/
Select Cameras --> EOS-1D Mark II
On the next page select: Language --> Spanish
Click "Submit"
The Spanish manual will be the first download in the list.
Best regards,
Peter
Mar 19, 2010 | Canon EOS-1D Mark II Digital Camera
Diagonal black line across the bottom right corner - canon eos 1D Mark IIN
Most likely the shutter blind is sticking and not getting out the way when you take a picture. It will need a service.
Nov 27, 2009 | Canon EOS-1Ds Mark II Digital Camera
Canon EOS-1D won't save pix to CF card. G.
The E99 message usually ends up being a shutter box that needs to be replaced. The 1D shutter box should be good for 100,000 images or more, you can probably find the estimated lifespan on Google somewhere.
If you can"t save pics to the CF card then you might have a bent or broken pin on your CF card reader. Look down into the CF slot, does it look ok?
We are an online digital camera repair shop but we haven't done any 1D cameras before.
Thomas D,
Owner; Darntoothysam com
Oct 02, 2009 | Canon EOS-1D Mark II Digital Camera
Canon 1D shutter problem
may be shutter not opening fully some grit dust in it i had thia prob with my camera cleaned it and it was fine
Sep 15, 2009 | Canon EOS-1D Mark II Digital Camera
I had problems with my 1D Mii on a recent shoot.
Run the SENSOR Cleaning option to see if that fixes the problem
Jul 29, 2009 | Canon EOS-1D Mark II Digital Camera
I have used the Canon Creative 3 program for quite some time, but now have Windows vista and it won't load. Can it be updated for that operating system/
Canon Vista compatible software now available ...with added support for some cameras, but not older ones. Go here: http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct and navigate to your camera model and select "Drivers/Software" link. RAW Codec for Vista and updates to Zoombrowzer and DPP are available for the following: EOS-1Ds Mark II, EOS-1D Mark III, EOS-1D Mark II N, EOS-1D Mark II, EOS 5D, EOS 30D, EOS 20D, EOS 400D DIGITAL, EOS DIGITAL REBEL XTi, EOS Kiss Digital X, EOS 350D DIGITAL, EOS DIGITAL REBEL XT, EOS Kiss Digital N
May 04, 2008 | Computers & Internet
Horizontal streaks on pages
Streaks at 2.82 inch intervals: Horizontal marks at this interval are the result of a mark on the fusing roller of the printer. In some cases, these marks can be cleared up by running a cleaning page through the unit. Laser Printer Cleaning sheets can be purchased at your local printer/office supply store. If the marks persist, this can indicate a more serious problem with the fusing roller that would require service attention.
Streaks at 3.74 inch intervals: Horizontal marks at this interval are the result of a mark on the image drum of the printer. There is no way to repair a damaged photosensitive image drum, so in the case that it is scratched or otherwise damaged, the entire CRU (toner/drum cartridge) would require replacement to clear up these marks.
Dec 03, 2007 | GCC Technologies Elite 12/1200N Laser...
Canon EOS-1D Mark II Digital Camera Logo
436 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
