Boiler Problem Having just moved the position of the boiler it will not now fire up. Only the Boiler Running light is coming on, but the fan is not coming in or there is no ignition, Any Help would be appreciated. Thanks
  • karenkeo May 25, 2008
    PS It is a Baxi PFL 50 Solo 3
Try the connector at the top of the boiler where the fan and the pressure sensor switch connect.This connector can corrode causing the power to not get to the fan. I looks like an ordinary terminal block but actually is a pin connector. Pull the connector apart, clean the pins and the inside of the sockets with fine emery paper, carefully prise the two halves of each pin apart and reconnect the connector. Be careful with the last step otherwise you can break the pins!! To get access to the connector remove the outer casing of the boiler and then the inner front plate - you will see the fan and the offending connector at the very top.
Posted on May 03, 2009
  • 625 Answers
What do you mean "moved the position" of the boiler?
Posted on May 27, 2008
I HAVE A BAND NEW KFA80DGD MODEL. I USED DEISEL, IT LIGHTS AND FAN BLOWS BUT AFTER A FEW MINUTES THE FLAME GOES OUT AND IT SHUTS OFF. THE INDICATOR LIGHT BLINKS...
there are two different viscosity rates and two different calorific values here
if it worked well on kerosene keep it on that
if you want to use diesel then have a technician come and set it up for diesel
Jan 04, 2017 | Heating & Cooling
I have a 9610 thermostat turns on and off to frequently
I am guessing but the thermostat is either faulty or is in conflict with another thermostatic device in the system. The room thermostat measures the air temperature in the room but with a modern intelligent boiler there will be other sensors measuring all sorts of things including the water temperature.
Personally I prefer to have thermostatic radiator valves rather than a room or zone thermostat.
Jan 02, 2017 | Heating & Cooling
My oil furnance is running but when it reches temperature it shuts off and will not come back on until we bleed the lines
You have a small leak on the suction side of the pump between the tank and the pump. when this happens the pump looses prime each time the furnace shuts down and when the furnace tries to fire up again the saftey device trips before the oil gets to the burner.
Jan 25, 2015 | Heating & Cooling
70 series boiler model #70-148. I need the pionts/box that controls the thermosstat. It runs but it does not matter what the thermosstat is set at. I was told by a pro that the points are sticking. I
Be sure the thermocouple is still working, clean the contact points with crocus cloth and be sure the voltage going in to the controller is correct.
Jan 21, 2015 | Heating & Cooling
Johnson Starley boiler main board fuse blowing
Chances are the fuse on the circuit board is for control circuit protection. Take note of the location of all the thermostat connections on the circuit board and remove them. Do this with the power OFF. Replace the fuse and re establish power. If the fuse did not blow, the problem is in the wiring to or from the thermostat. It could even have the insulation rubbed through and making contact with the side of the boiler or a mouse could have chewed through the insulation causing a short to a metal object.
Once the issue with the thermostat wiring is resolved, reinstall the low voltage connections and you should be good to go.
Jan 08, 2015 | Heating & Cooling
What is a TPR valve on a Utica Boiler?
TPR Temperature and Pressure Relief valve. Usually mounted directly on the tank and has a lever on the valve.
Dec 27, 2014 | Heating & Cooling
How do I get my radiators to start working?
ch1 indicates wirless thermostats? check the thermostats in the room have fresh batteries. this type can be wired but may be running on batteries you have to use a screw driver from below to open the unit. if you dont have a manual here is a link.
http://www.manualslib.com/products/Danfoss-Randall-Tp5000-Si-Range-2781091.html
i hope this helped
Oct 22, 2014 | Heating & Cooling
Heating & Cooling Logo
158 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
