Question about Coleman 850-870 Single-Speed Blender
How do you change the battery in the Coleman blender. Mine won't hold the charge
2 Suggested Answers
SOURCE: The coleman rechargable blender not blending
Rechargeable Portable Blender Model No. 850-870 not blending
Posted on Sep 12, 2010
Does not work
Suspect that the battery has died. If still under warranty, take advantage. A new battery is otherwise fairly expensive. Good luck!
Jul 03, 2010 | Coleman 850-870 Single-Speed Blender
Subject: Rechargeable Portable Blender Model No. 850-870
I was given one of these blenders for Christmas. I charged it through 3
cycles, used it once and the battery was dead. Charged it through another 5
charge cycles and used it once only to then have another dead battery. I
have put it through at least another 8 charge cycles, and it indicates a
DEAD battery. I have managed to blend two (2) 3/4 full pitchers in total. On
trying to start it now the green light 'flickers' quickly on and shuts down.
This is a totally useless device.
I would like to return it for a full refund, including shipping.
Dec 21, 2009 | Coleman 850-870 Single-Speed Blender
Breville blender bbl550 stopps after 5 seconds any setting
Mine does this as well... 5 seconds of operation and then OFF.
My guess is this is a fail safe where the blender is turning itself off to avoid overheating and what could potentially cause this overheating is the blender is struggling to turn the blades. What could cause this struggling of turning the blades I am guessing is a lack of oil in the blades rotating parts.
If you hold the circular blade part and turn it, you'll probably find that its hard to turn? Mine is... and I oiled it up a bit and found I got a bit more usage out of it... although only temporarily.
Ideally I need to pull it apart and oil it properly.
Jan 29, 2009 | Breville BBL550XL 5-Speed Blender
Top part of base broke off
This just happened to me too, and I think I just fixed it.  First you have to get a replacement part called the "blender coupling" (I got mine online from Goodmans for $3.99).  I also replaced the square drive and slinger (two parts come together for $2.99)-that's the little part that sticks up and attaches to the pitcher.
Unscrew the bottom four screws of the base where the rubber feet are.  Remove the rubber skirt to reveal four screws that hold the motor in.  They are way in there so you'll need a long screw driver.  Remove the motor and unscrew the old coupling.  Mine had not been replaced since my grandmother bought this blender who knows when, so the coupling was really stuck.  I did not have a tool narrow enough to get a good grip to apply enough torque to remove the coupling so I had to try a few other tricks.  If your blender is the same, remove the bottom nut, fan blade and two washers.  This gave enough of a rod to grip to get the old coupling off.  (I also had to use some WD40, and heat and cool the coupling a few times to break the old seal).
Good luck!  Hope that helps!
Jan 09, 2008 | Oster 465 Work Top Blender
Stopped blending
Exact same problem.  Turned out the threaded shaft that holds the blades was broken so tightening the nut on the top doesn't really help.  Just ordered a new blade assembly from www.smallappliance.com.  Mine was the Waring 007314W Blender Cutting Assembly but there is also an older one for earlier models.  Don't know if it will work yet (assume it will), but cheaper than buying a new blender.
May 17, 2007 | Waring PBB 25 Professional Work Top...
Coleman 850-870 Single-Speed Blender Logo
141 people viewed this question
Top Coleman Blenders Experts
eyecam
Are you a Coleman Blender Expert? Answer questions, earn points and help others
