Question about Ovens
We have a Whirlpool RF365PXMW electric range. The oven temperature is running up to 125-150 degrees higer than selected. Is the the temperature sensor?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
Could be the temp sensor or the control board. This kind of offset is too high to be calibrated for. Check the oven sensor resistence, if you have a meter, and it should measure about 1000 ohms at ambient temp. Most of the time, in instances such as yours, I find the control board bad. Hope this helps,
Posted on Sep 29, 2010
    Sergeant:
    Champion:
  • 351 Answers
Yes it is the sensor
Main Oven does not reach required temperature
check gas pressure and burner if ok bad temp sensor
May 19, 2017 | Electrolux EOD5330 Ultrafan Electric...
My oven does not heat to the correct temperature. If I set it for 325 degrees it will heat to 390 or so degrees. It always seems to be about 70 degrees too high. Accross all ranges of temperatures from...
The thermostat is the cause of the problem, normally the the only cure is to replace the oven thermostat,completely, or alternatively, compensate by setting a lower temperature when cooking.
this will work o/k if it is always the same variation in temperature across the range .
Dec 25, 2010 | Electrolux 30" Built-In Single Electric...
I turned on the self cleaning and the door locked but is the heat supposed to go on and off
Yes. It is maintaining a temperature hot enough to burn off residue but not overheat and burn the house down. It should be running somewhere around 500 degrees f
Sep 16, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I have an accubake system electric oven and stove. When I tried to set the temperature on the oven the degree number kept rising to 500 degree on its own. Now it is displaying E0 F2 on the screen. Whats...
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%$#
Aug 09, 2010 | Whirlpool RBS275PD Electric Single Oven
Temp cycle span from on to off is 32 and 33 degrees respectvly
Obviously the thermostat calibration is out, most manufactures allow a tolerance of + or- 10%, so yours is outside this range.
You can compensate by setting the temperature lower by say 20 degrees, this will then bring it within accepted tolerances.
Hope this helps you.
Dec 16, 2009 | Whirlpool RBS305PDS Electric Single Oven
Error F5E1 after self cleaning
Hi There
I have read the codes you are looking for,so I'm sending them to you and i hope this will help.
F5 E1 16 Door latch not operating Check that door switch is completely closed. Check latch, solenoid, and actuation switch for electrical or mechanical malfunction.Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
My new oven runs about 50 degrees hotter than the temperature I set, is this normal
No,but it can be calibrated through the control push and hold the Bake button it should come up 0 F you can go plus or minus 35 degrees with the up and down keys.but make sure your thermometer is accurate.Whirlpool will send someone out to check it out for free for the first year.
Aug 29, 2009 | Whirlpool RBD305PD Electric Double Oven
How to remove the control panel on Whirlpool double oven Model RBD305PDS14
Remove the doors by turning toward you a little toggle apparatus located on each hinge. Locate a small screw on the lower inside edge of the left and right hand trim and then slide off the trim. Remove the lower trim then raise the upper trip and put the left end of the panel inside the top opening. This allows you access to the control panel. Test both the keypad part #8300440 and the control panel part #830219 to see which one needs to be replaced. Order the replacement part, plug it in, reverse the precess above and it should work like new..
Oct 02, 2008 | Whirlpool RBD305PDS Electric Double Oven
Oven doesn't reach temperature
Page 6 of the owner's manual:
Adjust the temperature calibration.
Jun 26, 2008 | Whirlpool RBD305PD Electric Double Oven
Ovens Logo
258 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
