Question about Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair
How do i remove the chair. I want to change the batteries
  • 692 Answers
Bob First unplug both connectors from the rear of the chair. Then on the right hand side under the seat push the small handle forward until it stops, then rotate the seat and pull up at the same time the seat should lift off the seat post. Carefully place the seat on the floor next to the base. Remove the shroud pulling upward to release the velcor fastners and voila!! the batteries. Now if the seat is hard to pull up try twisting it back and forth to help get it loose from the seat post. You might need some help in lifting because this seat and attached parts are heavy. After replacing the batteries grease the post to help getting it off easier next time. Hope this helps you
Posted on Sep 30, 2010
I changed the batteries in the jet 3 ultra. Chair will work but batteries will not charge
Wall outlet bad? Charger not turned on/plugged in right? Something disconnected? Bad battery connection? Blown fuse in chair or charger? Bad battery or batteries?
Aug 09, 2014 | Jet 3 Ultra Power Chair
How do you remove the back cover over the motors?
Usually remove the chair by easing it up and off. The battery cover (shroud) is usually lightly velcroed on just grasp and gently pull it up.
May 07, 2014 | Pride Jazzy Z-Chair Z-CHAIR
Go Chair goes slow
check the breaks are not sticking on.
slacken off or remove to try if this is the fault
Jun 02, 2013 | Pride Mobility Pride Go-chair Travel Power...
Changing battery or is it batteries
lots of questions how old is chair, how old is batteries, it has 2 by the way 12v connected in series giving 24v , always change both not just one, check for loose connections first and be sure charger is good try on another chair and/or try another charger on yours if possible they are 95% interchangeable
Nov 29, 2012 | Jet 3 Ultra Power Chair
How do i connect the 35 amp batteries to my ultra 3
with the battery cables vic seriously I'm gonna assume you have removed the seat and shroud cover over the batteries. Unplug the battery cables from the wiring harness and remove each battery remove the wiring harness from the battery and attach to the new batteries like they were to the old red on positive and black on negative and reinstall in the chair plug the joystick cable back into the chair turn on the chair to make sure you got it right unplug the joystick cable replace shroud and seat plug the joystick cable back in and you should be good to go. charge the batteries before use and then charge them nightly when you go to sleep and unplug in the morning if you use the chair daily charge everynight If you have to stop using it for a while always put it up fully charged and charge weekly Hope this helps you
Apr 09, 2011 | Jet 3 Ultra Power Chair
My mom has a Jet 3 Ultra and by reading other comments it sounds like we need a new battery, so I have 2 questions: 1 - where do we buy the battery 2 - how do we replace/install the battery - can we...
Did Medicare pay for Mom's chair? If they did then they will pay for 80% the repair to the chair. You can contact Repair Express @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 they are both excellent repair companies and will schedule a tech to pick up mom's chair leave a loaner and fix the chair for her. Now if Mom bought her chair then she will have to pay for the batteries and all other repairs needed (lets hope not). The chair needs 2 U1 sealed batteries and they can be purchased through the provider where she got the chair or at any good battery outlet like Interstate Battery. I would avoid Internet stores because of the shipping costs. Do not get them from Wal Mart or any other chain store because they do not sell sealed deep cycle batteries required for your chair. The batteries will cost you around $200.00 for both. The provider will probably charge you more. You have to unplug the joystick cable, remove the seat from the base and take the shroud off the base and there you will see the 2 batteries. Remove the wiring harness and remove the batteries reinstall the new batteries wiring them like the old ones, replace the shroud and the seat hook up the joystick cable push the on/off switch and pray that it comes on (lol). The old batteries can be recycled through any battery dealer in your area Hope this helps. If you have any questions you can reach me @ lennieg2000@yahoo.com
Mar 15, 2011 | Jet 3 Ultra Power Chair
Seems like no power is coming form the battery. Even after much charging
You may have a battery with a dead cell which is keeping your chair from charging right.
If you have a load tester on hand ,load test both battery's they should show the same
if they dont show the same this tells you the one that fell to a lower reading is your dead cell battery make sure when you do change out the battery's you change both.
Good luck hope I was helpful
Tech
Jan 17, 2011 | Electric Mobility Invacare Pronto M41...
I change batteries. took out one at a time so I didn't mess up wirinng. When I put the pack back on the chair, I get no power at all. What did I do wrong?
mcdevito75 here, If the chair wirked fine before you changed the battery--ies you:ll have to double check your work, remove 1 battery and note the + and - terminals as indicated where you place the battery--ies in the chair. The Dome side of the battery is + or positive and the flat side of the battery is - or negative, double check battery--ies in the chair for proper placement.
Jun 23, 2010 | Golden Technologies Alante' Power Chair
The batteries have been changed but the chair is not poweing up
Hello there:
If you have changed out the battery and it is wired correctly i would have to say check out the power
modulator, this controls the power going to the unit also if you get in contact of your chairs manufacture there is a code that they can give you by pressing a series of buttons to get the power back to the chair
This is very common when you change out the batteries in these chairs ok?
Hope this is very helpful for you
Best regards mike
Feb 25, 2010 | NRS Hoveround MPV 5 - Used Power...
Need to remove the bad batteries Jet 3 power chair
Hello Donald ,
You may have solved this problem by now ,but just in case you have not, here goes.
Make sure the chair is turned off and engauged in the drive mode meaning not in the free wheeling mode. This way it will not roll around on you during the battery change out.
Go to the rear of the chair and slightly turn the two black plastic lock pins,one on each side they actually lock the small )) shaped cover in place. Turn these with your fingers or you can also insert a dime in the slot on top of each pin to turn them . You will be able to tell when they have unlocked as the )) shaped cover will be loose. Lift the cover up and under it you will find the battery connector, unplug it and leave the cover off for now.
Next ,move to the front of the chair and just to the rear of the footplate you will find a locking pin that runs through the lower rear bar of the footplate as well as the chair frame itself . Pull this pin completely out. Once done you should be able to pull the entire footplate assembly out torward you, Black plastic front cover included. Once you have it pulled outward lift it upward and it should lift completely off the chair. This done , you should actually be looking at the front battery which is sitting in a black plastic tray. Gently but with a firm grip grab the tray anyplace you can and slowy begin to slide it out from under the chair torward you taking care not to tangle the battery connector at the rear with any other wiring on its way out. Once you have the tray slid out into the open ,you will be looking at both batteries after which you will need to unhook the straps that secure the Batteries to the tray after which you will need grab your wrenches and remove the battery harness itself from each battery. You may want to do just one battery at a time this way you'll have less wiring to keep track of when wiring in the new Batteries. The Batteries in your Jet 3 are a size known as U-1 deep cycle sealed maint. free batts, You can use either Gel Cell or seale3d LA replacements . Though they are much cheaper, you cannot use lawn tractor batteries. Though they look the same the internal technology between medical powered mobility batteries and tractor batteries are entirely different. The latter would only run your chair for maybe a half hour or so before needing charge.
Take great care to make sure your wiring hookups are correct and that you position the rear connector plug to the rear of the tray. This way you will be able to locate it easier once you have slid the tray back in under the chair and it is time to go to the rear of the chair and reconnect that plug. As for everything else ,reattach it in reverse of the way you removed it including remembering to slide the lockpin back into the front footplate frame. Give a tug on the footplate when done to make sure it is locked and secure.
In closing I offer this valuable advice : When working with any of these batteries, always were safety glasses or goggle and gloves (terminals are lead). I also advise removal of metal rings ,watches, bracelets etc that could create a short when reaching in and around the battery terminal. Take great care with your tools and wrenches in making sure you keep and eye on both ends of the tools at all times. This way you will not accidentally cross the posts of the battery. Take your time ,use proper safety technique and you'll do fine. The following is Pride Mobility's step by step for battery change out and is basically the same as I have sent . Can never have to much info but can always find yourself with not enough. Take Care
To replace the batteries:
1. Turn off the power to the controller.
2. Make sure that the power chair is in drive mode. See III. "Your Power Chair."
3. Turn the rear shroud fasteners one-quarter turn in any direction. See figure 6.
4. Remove the rear shroud.
5. Unplug the battery connector. See figure 26.
6. Remove the retaining pin from the foot platform and lift the platform up and away from the power base. See figure 19.
7. Slide the battery tray forward.
8. Unfasten the reusable strap around the front battery.
9. Disconnect the wiring harness from the front battery.
10. Remove the front battery.
11. Unfasten the reusable strap around the rear battery.
12. Disconnect the wiring harness from the rear battery.
13. Remove the rear battery.
14. Place a new rear battery on the battery tray. Make sure that the terminals are facing forward.
15. Fasten the reusable strap around the rear battery.
16. Connect the wiring harnesses to the rear battery.
Apr 30, 2009 | Jet 3 Ultra Power Chair
Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair Logo
318 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
