Question about Refrigerators
Refridgerator constantly beeping. I have a Samsung SRS615DP about 3yrs . Constantly beeping on fridge side. Seals look very clean with no dirt etc. Looked at Samsung site but no help. I live in Mandurah WA
  • Tevita4285 Oct 05, 2008
    I have the same problem. keeps beeping and the temperator number changes from 7 down to -1 all the time. its as though the fridge door is open all the time....
I had this exact same problem. I replaced the PCB on the freezer. Cost approximately $100.00. Problem solved. No flashing door light, no fluctuations in temperature. Installation is really easy so do it yourself and save yourself money on a tech. Remove the whole panel, from freezer door, with something like a thin spatula and prise off gently. If you work around you can feel the clips and unclip them one at a time. (That's the hardest part) Replacing the PCB is easy. Just one plug.
Posted on Apr 04, 2010
  • 828 Answers
Look to the freezer side for the possible problem. If the freezer evaporator coil is freeing up due to a defect in the defrost system the refrigerator temperature will be the first place it will show. Look for frost build-up on the freezer back wall.
Posted on May 25, 2008
My fridge freezer is making a beeping noise and im not sure why its beeping The model is Elba ER169TRWH1
If the fan on the back is constantly running check to ensure it is not clogged, also make sure the door seals are not torn.
Dec 29, 2014 | Refrigerators
Samsung fridge freezer mod SRS615DP door open warning comes on and alarm is beeping then temp reading will fluctuate . But the door is not open not even a little all the seals are in excellent...
HI,
First try a reset by unplugging all the cords of your unit and leave it for 4 hours.Also open the refrigerator door.After that plug in all the cords,close the door and let me know the result.
Sep 14, 2008 | Refrigerators
I have a samsung side by side fridge freezer model SRS539HW, the alarm keeps beeping every minute to say the doors are open however they are closed. If I manually pust the door closer button it will...
Solved beeping problem.........Samsung SRS539HW . Have one of these and it is 6 years old. I had to replace the bottom hinge on the fridge side(right). Easy job but now constant beeping as if door is open, and light is intermittent. Found that there is considerable wear on the cable through top hinge of door and one of the wires from a magnetic reed switch in door had broken. I discovered this by shorting the two fine wires (white and pink/white) going to internals of fridge.No more beeping due to door opening and light now working correctly. Of course I no longer get a beep for a valid door open to long but cheaper than getting a refridgerator expert in.
Jan 13, 2012 | Refrigerators
Freezer working fine the fridge is not
The motor running constantly means the fridge is not sealed properly so that it is losing cold to outside. Check if the door of the fridge seals properly.
Jul 05, 2010 | Maytag MSD2756G Side by Side Refrigerator
Fridge constantly dripping wet
water inside, too much condensation from humid air entering fridge from bad seals. replace the seals. could also be that the condensate drain is clogged. if it's leaking from the bottom of the fridge, make sure the tubing is still inside the condensate pan underneath the fridge.
Aug 24, 2009 | Whirlpool Freezers
Door not closing properly
Hi: The Kitchenaid refs. us a gravity close along with the magnets in the door seals. Magnets getting weak seals getting old and what you told me you checked can cause this. The easy fix is to raise the front of the fridge by lowering the front wheels. Pull the grill off the front and find the leveling screws (usually labeled.) Raise the front of the fridge until the doors swing shut with a gentle push. Before you replace the grill make sure the fridge dosn't rock side to side as you want it even. This is what they call leveling a fridge. Not cabinet level. Just sturdy. Hope I helped, Jeff
May 31, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
Door open signal flashing -
First check to see that the door switch is closed fully when the door is closed. Tape it fully shut to make sure
Jul 17, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
429 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
