Question about Refrigerators
Error code e6 on beko fridge freezer.. what does that mean
3 Suggested Answers
SOURCE: I own a Beko AP930
Just had this fault fixed on my 930. It is the ice sensor just under the ice cube tray - mine had a broken wire (from rotating several times a day for over a year!)
Fiddley but easy fix yourself with a "leggo" block connector to re join the wire if that is the fault, or ring Beko on 01923 654659 (very helpful company to deal with) for a part.
Part number 4344740185.
The other suggestion about the water filter I respectfully believe is wrong!
Posted on Jul 31, 2008
SOURCE: liebherr frost free fridge/freezer
Try these solutions in these order:
1. Switch off the fridge and leave the door open overnight. Switch it back on in the morning.
Explanation: The sensor inside the fridge gets frozen and cannot control the temperature properly.
2. Switch off the fridge. Unplug it. At the back of the fridge (behind the unit, not inside) there is a large grid. Clean it with a hoover thoroughly. Open the fridge. Dry the back of the fridge if wet (inside the fridge). If frosted wait for it to defrost and then dry it. Plug in the fridge. Switch the fridge back on. This one worked for me.
Explanation: The dust in the grid deprives the fridge from cooling down and the unit can't control the temperature in the fridge section.
3. Switch off the fridge. -Unplug it. Empty it. Turn it upside down. Plug it in. Switch it on for 24 hours. Switch it off. Unplug, return to normal and switch on.
Explanation: This has to do with the pressure of the gas inside the compressor. I have not tried it but this advice as given to me by a qualified electrician when I commented the (in)famous F2 problem in Liebherr fridge/freezers.
Hope it helps. Regards. Albert
Posted on Jan 04, 2009
My Beko BK5200 AirCon has error code E6 displayed. What does it mean?
Barry, check link below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
1 Time Flash E6 error troubleshooting part 3 of 3 for Mitsubishi Electric...
http://homeappliance.manualsonline.com/manuals/mfg/beko/beko_air_conditioner_product_list.html
Mar 04, 2016 | Computers & Internet
Fridge freezer is showing e6 what does this mean
You don't give a make or model, so try this.
http://www.ukwhitegoods.co.uk/help/fault-codes/refrigeration-fault-codes.html
Jun 19, 2014 | Refrigerators
Our fridge/freezer FN240-FG940 was purchased in 20002001. Is it subject to the currently identified overheating problems please?
This article refers to BEKO Fridge Freezers:
According to the London METRO magazine ( http://www.metro.co.uk/news/868330-beko-fridge-freezers-fire-risk-warning-issued-to-homeowners-amid-recall ) The MODEL numbers (not serial numbers) affected by the recall are as follows:
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
From what I can ascertain, the fridges affected were manufactured between January 2000 and October 2006
If you go to the BEKO website, there is a link to check your serial number:
https://refsafety.beko.co.uk/
But I have to say, matching serial number or not, if I had an affected model, I would be checking with BEKO anyway!!
Jul 05, 2011 | Beko Refrigerators
I have a beko fridge freezer. I had an error code
I got the answer myself and thought I would share it.
The E4 code means that the auto defrost is not working. Call beko and tell them the code and they will tell you what part it is. I think the part number is 421445. It is a little black tube with two wires comming out. The part costs about £10. To fit the part you have to go into the feezer side of the fridge and carefully remove the white plastic at the back which is held with clips and one screw. To find where the part goes look for a long white fatish wire. The black fuse or thermostate is hidden in that. You will see where the wires go when you remove the old one. It is easy to do. Once you replace the part the error light will still be on but will go out after the fridge is back to being cold. Don't forget to replace the inside of the freezer when done! Hope this helps. John
Jun 18, 2009 | Freezers
Beko AP930 with Error code E0 in LHS of display .... what does this mean ? .... nothing in manual
Error codes are printed on underside of plastic cover on top of fridge. Warning electrical components inside! Error code E0 is the FREEZER door not being recognised as closed, switches are normally ok may be problem with printed circuit board. Freezer will work as normal but engineer should be called.
May 08, 2008 | Refrigerators
Beko fridge freezer not working... not cooling
yes it can b fixed is the fridge running ? if it is it will need re gasing which is a common fault with beko and you should not pay more than £40 for the re gas if it is not running it will b either your thermastat which again you should nt pay more than £48 4 or the compressor which will b aprox £120 supply and fit none of the above should b done by a novice good luck
Sep 07, 2007 | Refrigerators
Refrigerators Logo
361 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
