My Westinghouse washing machine lt609s is showing the code PU and has stopped washing. What does that mean?
4 Suggested Answers
RixsFixes
  • 2200 Answers
SOURCE: Model LT609S Washing Machine Bad Smell After Washing
A problem like this can be difficult to resolve using cleaning solutions alone.
See this FixYa Tip for some strategies that work well in eradicating mold which is the main cause of this problem.
If you find the solution helpful please leave a vote for it. Thanks.
Posted on Apr 17, 2010
caroldon
  • 17129 Answers
SOURCE: westinghouse lt609s Washing machine has
Possible fault in the main program controller unit. It is important to test the sequence and output of the program , the voltages to the motor during the wash cycle drive motor, the input valve and output valve voltages at the point of cycle to confirm the program controller.
Posted on Mar 23, 2011
rickyrt441
  • 4399 Answers
SOURCE: Washing machine will not drain
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Make sure you check all your drain hoses. Make sure the pump is not clogged up. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging. I want to thank you for reading and I hope this helps you
Posted on May 03, 2011
My usually trustworthy Westinghouse LT609s won't start cause it says the lid is open when it's not. Is it done for?
not necessarily
it could be the out of balance lever on the wrong side of the lid switch
lid switch or program board
before you make a decision to junk it ,have a technician check it out and get a quote to fix
Dec 28, 2015 | Westinghouse Washing Machines
My washing machine goes fine until half way through wash then comes up with error code PU and beeps until I turn it off...will not drain out the water? Simpson encore 556
simpson encore pu Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/simpson_encore_pu
Unsolved problems for simpson encore pu question. Get free help ... My simpson encore 757 shows PU error code. What is this? ... Simpson encore 556. Aug 22 ...
Sep 10, 2015 | Simpson Washing Machines
I hve a simpson aquapulse every time I do washing pu comes up can sme 1 plz tell me wat it means thx
PU code is the drain pump/\, This code can mean a bad pump, but most often there is some kind of restriction or blockage in the drain lines from the pump to the drain. Check for clogs/restrictions and clean them out and try again.
Dec 31, 2014 | Simpson Washing Machines
Westinghouse lt609s Washing machine has stopped and will not progress HC error
Mar 23, 2011 | Westinghouse Washing Machines
UE displayed on panel westinghouse 708 washing machine near end of cycle shows 6 mins left on spin then shows UE, cannot go into normal cycle.
I WOULD TRY TO LOOK AT THE DRAIN PUMP ASSEMBLY ON THE UNIT.... IT IS EITHER STOPPED UP OR NOT PUMPING FAST ENOUGH OUT DUE TO DEBRI IN THE PUMP AREA... GAIN ACCESS TO THE DRAIN PUMP AREA AND REMOVE HOSES AND LOOK INSIDE AREA.
the code data base for this is saying ue = drain failure... hope this helps you out
Jan 06, 2011 | Westinghouse Washing Machines
Apr 06, 2010 | Westinghouse WWS833ES Super Capacity Top...
Washing Machine 8kg - Westinghouse LT8195A is showing fault code 1f. What is the full description of this code please?
I was unable to figure out any error which says 1F. I suppose you wanted to say F1.
Check the fault code status :
http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-washer.html
F1 means Water supply/low water fill .
Thanks
Mar 02, 2010 | Washing Machines
Westinghouse washer lT609s - tap problem
if I understand you correctly ... your washer keeps filling with water and you must shut them off at the wall to stop the water from coming into it?
this is a stuck water valve .. there may be something in your water valve keeping it open...
unhook your hoses and check them..
hope this helps
Apr 05, 2008 | Washing Machines
Washing Machines Logo
91 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
