Question about Sony Handycam DCR-HC30 Mini DV Digital Camcorder
Camcorder turns on but will not record - Sony Handycam DCR-HC30 Mini DV Digital Camcorder
    Genius:
  • 1,812 Answers
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Oct 03, 2010
Camcorder wont record for longer than two minutes
hi Keven.
all i can find is the manual.
if you go to this link go to the 7th one down and that should be your manual.
plus at this link there is forums you can go in to that might help you out.
Hitachi DZ BX35A DVD Camcorder stops recording and says disc error Google...
Nov 24, 2017 | Hitachi DZBX35A DVD Camcorder
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
SONY HANDYCAM DCR-DVD105 ERROR MSG C:13:02
Try to use a cotton swap to 1st clean the recording lens or blow gently on it. Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
Jun 28, 2009 | Sony Handycam DCR-DVD105 DVD Camcorder
Sony HDR-SR10 Camcorder
Yes, vibration seems reason to stop it recording as its hdd camera.
Sep 09, 2008 | Sony HDR-SR10E HDD Camcorder
Choppy Video
I had same problem. Don't buy a cleaner. Look inside camcorder and make sure both reel turners are equal in height...they can slide down. Turn both of them...one of mine was down and also did not turn to make contact with tape. We got it to turn and the message C31:23 and the dinging quit. Camera instantly worked like it used to. Good luck.
Jan 31, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
How to Record From a TV Using PV-GS13?
connect a lead via your tv video out audio out jacks. Select tha appropriate channel (You may have to go through the av channel on you tv and tune in the channel you want to record) or, video or dvd player audio out video out jacks. connect other end to your camcorder. Select on the camcorder menu video in audio in. Turn on tv. If connected to video or dvd player, press play. Press record on your camera. When finished recording press stop. Presuming the camcorder is tape, you can buy a tape adaptor to play or record your mini tapes in a standard video recorder, then take them out of the adaptor and play them back on your camcorder. You can also do all this via a computer. Also if the camcorder is disk or hard drive it can be used the same way as a regular dvd recorder to record tv programmes once connected to you t.v. Let me know how you go 26 red
May 08, 2007 | Panasonic PV-GS31 Mini DV Digital...
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Can't read the date/time
There may be a simple explanation. Here are two possible reasons this is happening: * You may have disconnected the power source before turning off the power to your camcorder. If you remove the power source from the camcorder while the power is on, all settings and selections will be erased. Make sure to turn the camcorder's power off before disconnecting the power source. * This is particularly an issue for some early VHS-C camcorders – those with model numbers beginning with a "6" and ending with a "2" or "3" (i.e. CC6xx2 … CC6xx3). These camcorders have a consumer-replaceable clock battery that may be exhausted. If that battery runs dead or is removed and the main battery or AC is not connected, the camcorder will lose all its Date and Time settings. * In some models, the date and time display is designed to do this. When you turn on many VHS-C and digital camcorders, the Auto Date mode will display the time and date. When recording begins, the date is recorded on the tape for 5 seconds and then disappears. In the viewfinder, the date will then be replaced with the words AUTO DATE but they will not be recorded. They remain in your viewfinder so that you know this feature is on. On full-size or VHS camcorders, the Auto Date feature is very similar. When you first turn on the camcorder, the date along with the word AUTO and a Clock icon appear in the viewfinder. When recording begins, the date is automatically recorded for 10 seconds and then disappears. In the viewfinder, the Clock icon and the word AUTO remain but they will not be recorded. They remain so that you are aware that this feature is on. When using the Auto Date feature, be aware that the time is only recorded when you first turn on the camcorder and begin a recording session. It does not record each time you press the record button. There are a number of time and date display and recording options. Since these vary by model number, please refer to your owner’s manual for more details.
Sep 06, 2005 | RCA CC-432 Camcorder
I can't start recording.
# You may not have turned on the camcorder to record properly. For camcorders that feature both Automatic and Manual recording, make sure you press in the LOCK button while setting the POWER switch to the desired setting, either "A" (Automatic) or "M" (Manual) record mode. # Automatic recording places the camcorder into Auto Shot™ mode, while Manual recording mode allows you to control many of the camcorder's special features, including accessing the menus and setting the clock. # For many other camcorders, make sure the CAMERA/OFF/VCR switch is set to CAMERA. Make sure the Erase Protection tab is in the position that allows recording. If not, slide the tab. Some tapes have removable tabs. If the tab has been removed, simply cover the hole with adhesive tape or use another tape.
Open Questions:
See all Sony Handycam DCR-HC30 Mini DV Digital Camcorder Questions
Sony Handycam DCR-HC30 Mini DV Digital Camcorder Logo
18 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
