Question about Lexmark X6150 All-In-One InkJet Printer
X6150, does not turn on with power button
When the machine is plugged in short vertical bars appear across the display. The power button changes nothing in the display. I checked the transformer and it is putting out 30 V. The previous owner said that it worked when she last used it. It is not connected to the computer.
  • educaterdan May 25, 2008
    The machine has been sitting a few months. The cartridges are in place, but the carriage does not move.
I can't figure out where to plug in the power supply
to the Printer for the X6150. On the back there is a
big square hole that looks like something is missing
and I can't find a manual On line.
btracy4567@aol.com
Posted on Jul 24, 2008
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Sony bravia kdl-46w4100 moving vertical lines
Check the main filter capacitors at its power regulator board. Replace if found bulged or damaged. Replace all secondary side supply rails' filter capacitors too. The fault is with damaged electrolytic capacitors at the power regulator board itself.
Jun 06, 2012 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
HP 640 fax only displays bars nothing else will work
while the printer is powered on.....unplug the power module and then press and hold the # 3 button at the same time......while holding the two buttons reconnect the power module......will fix the problem.
Jun 01, 2010 | HP 640 Inkjet Fax Machine
Vertical black bar across the screen
sounds like the screen settings are out, try changing the screen settings, not sure which button it is though i rarely play around with laptops
May 19, 2009 | Dell Latitude D800 Notebook
Windows Vista freezes while loading up& Blue Vertical Bars appear
Hi
Reflashing the bios doesn't make any difference.
Check in the BIOS Screen whether notebook scree has the same issue if it is the same then it is a hardware issue if it is fine in the bios screen then need to run the hdd and memory test
After the test result we can decide next steps
> If hdd and memory test passes - then reload the os.
To login to bios - Reboot the system and keep tap on f10
Apr 28, 2009 | HP Pavilion dv9000z Notebook
Hoizontal Bar across RCA Model 24F501TDV Color TV
you may need to change your resolution on tv settings as well as cable or satelite settings if you have one of those
Dec 12, 2008 | RCA 24F501TDV 24" TV
Dark Grey Vertical Bar
1. try connecting laptop to an external monitor and check if this vertical dark gray bar appears. if yes it means video is the problem. you need to boot in safe mode then uninstall the video driver. boot to notmal mode then download and install the latest video driver. if still same problem then replace video card. if video is built in with motherboard you need to replace motherboard.
2. when the vertical dark gray bar did not appear in the external monitor then it means issue is with the LCD panel. Do this turn off laptop. press and hold D key then press Power button at the same time or Press and hold on the Fn key then Power button check if the test will run. Color displays full screen when you keep pressing on N key when the colors appears check the vertical dark gray bar if still exist in the test, this means LCD panel and LCD cable needs to be replaced.
Oct 31, 2008 | Computers & Internet
MP780 - LCD Display off
Same problem - for a few days the LCD screen showed garbage intermittently , then machine wouldn't power up and out of warranty. Good machine til then.
Oct 12, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Lexmark X6150 All-In-One InkJet Printer Logo
52 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
