Question about Philips 55PP9401 55" Rear Projection Television
Three colors are not together
We have Dishnetwork, and the other TVs work fine. So the problem is not from anything else except for this TV itself. All three colors are not together and this happened yesterday without any disturbance to the TV. Starting about 3 months ago this TV set is giving red pictures sometimes when it is turned on and will become normal after several minutes.
I'm looking for solutions that I can do to fix it at home (by myself of course) because there is no philips service center in the area I live nor is worth it. It is about 7-year-old. Is it the end of the life?
Thanks for any suggestions.
  • 4 more comments
  • jjsummer Jun 18, 2008
    I have the same problem. How to fix it?
  • Anonymous Jul 26, 2008
    Same, virtually, exact problem here in Wichita Falls Tx - Amazing!
  • Michael Roach Aug 18, 2008
    Same problem - EXACTLY. Only theory is that it has something to do with new invisible fence. (Doubt it.....)
    Same problem - EXACTLY!!!
    Did you just install an invisible fence?
  • caspercurlyb Aug 21, 2008
    I have three ghost images all different colors. I think the images just need to be adjusted together somehow
  • DANJANSYDNDE Nov 22, 2008
    HOW CAN I FIX THIS COLOR PROBLEM THE COLORS ARE OFF BY 3/4" . -MISSOURI-
Convergence problem needs two ic 's to fix.
Posted on Oct 21, 2008
I turned the living room tv on this morning and it is black and white and says no signal. The other tvs are working fine. I have turned it off and turned it back on still nothing
Hi my name is Mike Houston of DISH Network and I see youturned on the living room TV and it was black & white and had no signal.Depending if it's a Dual receiver and if the issue is TV1 or TV2 but there issome thing's you can check to make sure it is on the right channel. I will sendyou two links to help with the setup for both TV1 and TV2, if you have anymorequestions or concerns please e-mail me back at Michael.houston@dishnetwork.com;http://www.dishnetwork.com/SupportSection/bbs-screenand http://www.dishnetwork.com/SupportSection/black-blue-tv2.
Sep 04, 2011 | DISH Network 322 DTV Receiver
I am thinking about buying a Samsung 72" DLP (Hlt7288wx/xaa) for $500. The seller says a tv repairman says it needs a color wheel replacement. Do you think this is something that would be difficult to...
Yes,tvs with a colors wheels design into it are more prone to brake down and more quickly than tvs without colors wheels design into it.The colors wheel in the tv spins at 12000 RPM at every cycles to make and let the tv Light Engine shine a beam of light into a colors wheel to make and have a colors spectrums to make it to works for the tv.No projection tv with a colors wheel are not easily to be replaced have go through alot of trouble to replace a colors wheel itself.The tv colors sit way back of the tv have to take out many tv mechanical tv frames bulk heads even than can come to the tv colors wheel itself to replace it.Take ur $500 buck buy a "40 LCD tv less worry less head aches.
Aug 22, 2011 | Samsung HLT7288W 72" HDTV
50" plasma panasonic 720p tv has several colored
Flashing error codes could be the Direct tv box itself.Because tvs have problems within itself don't flashes error codes on the tv screen,the problems,just show up.Tries tv and Direct tv satellite box unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting and the Direct tv box updates it softwares data's.The problems should be solved,if have the same problems,first call Direct tv for a replacement box,see how it work out.Than turn ur attention to the tv.
Feb 08, 2011 | Panasonic TC-P50X1 50 in. Plasma HDTV
Hello ! I bought a hd lcd tv 28" brand hannspree. I connected the cable(dishnetwork signal) into this. I have only black & white image. No color. I connected a dvd player into the rca port and it...
Unplug the tv and the Dish box about an hour,replug it both devices back in.The tv should reset itself back to factory.The dish box,upgraded it software.The problems should be solved,not than the tv Tuner board have problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Jul 09, 2010 | Televison & Video
Cant find code for dish net remote to control emerson 32lc320emx
wwoodzy
Some TVs will not provide all the features of the TV or won't work with out DISH remotes. I have supplied all the available codes for the Emerson TVs. I hope this helps.
TV codes:
541, 544, 632, 537, 526, 534, 536, 590, 627, 636, 642, 648, 652, 654, 655, 657, 658, 659, 660, 661, 662, 665, 666, 667, 669, 670, 677, 679, 682, 692, 696, 699, 720
Program remote:
http://www.dishnetwork.com/SupportSection/remote-setup
Ray Calo
DISH Network
Dec 12, 2009 | DISH Network IR Remote Control
Why does my converter box turn itself on and shut itself off?
set your power down to off most boxes are set to turn off in 4 hours
Jun 10, 2009 | Insignia Digital-to-Analog Converter for...
OK, Time to fix it !!. Replace two Ic's Stk 392-110, and get in service menu settings , and adjust point by point. After replaced stk IC's, check if any resistor look brown or born, if yes, replaced it with 6.8 Ohms. If you have questions? noetvs@embarqmail.com . Good Luck !!
Jul 22, 2008 | Philips 60PP9202 60" Rear Projection...
52" Samsung DLP
It is unlikely that you can do anything yourself.
It sounds to me that there is a power supply problem that has steadily gotten worse and that cannot be confirmed remotely, it must be done on site by an equipped professional.
May 13, 2008 | Samsung DLP HL-P5663W 56" TV
One T.V. snowy on Sat., clear on local channels, others are fine?
if you recently got dishnetwork call the company that installed the system for a repair person, they HAVE to fix it. if you put it in yourself it sounds like the lnb is bad or the dishnetwork splitter is bad or not hooked up right. this kind of problem is a reminder that paying an extra $5 a month for service warranty is a good deal. if something is wrong with anything then, a phone call to dishnetwork will get new equipment sent to you or a service tech sent to fix it. i don't presently work for dish or direct or a cable co but i know that's how things work.
Apr 16, 2008 | DISH Network 311 DTV Receiver
RCA HD52W59 REAR PROJECTION
there should only be three colors.. can they be aligned?
Sep 16, 2007 | RCA HD52W59 HDTV Projection Television
Philips 55PP9401 55" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
