Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Help The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. Please help!
  • JamaalJamaal May 30, 2008
    I HAVE THE SAME PROBLEM. THE CAMERA WAS WORKING FINE 5 DAYS AGO AN NOW NOTHING
  • Anonymous Jun 08, 2008
    the camera whon"t turn on
The camera canon ixus 6.0 was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. Please help!
Posted on May 29, 2008
  • Canon Master
  • 4,738 Answers
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Posted on May 26, 2008
3 Suggested Answers
SOURCE: Canon Ixus 75 not charging
The camera was working fine 2 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. Please help! bob
Posted on May 25, 2008
SOURCE: help
after my battery died, I replaced a fully charged battery and try to turn my camera on.
for some reason it wont turn on!!! I have never dropped my camera or anythingelse that could damage my camera! please help!
Posted on Sep 30, 2008
Worked fine put new battery in changed nothing wont work just clicks at relay box
The new battery was charged before you put it in? Or you just assumed it was charged?
When was the last time everything ran fine? yesterday, or half a year ago? because in a long period, lots of things could have corroded or just got defect.
Mar 14, 2015 | Boating
Camera wont turn on
Very odd that both cameras would stop working at the same time, has someone else abused them?
Removeing the batterys for a while is a good enought reset, check the battery connectors and contact your dealer if they both have warranty you will get them repaired or replaced for free. other than that I can recommend you a repair man if you provide me the city you live in.
Jun 12, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
Headlights won't turn off on 1993 ford tempo gl
Will they go off if you unplug the headlight switch ?
Jan 25, 2014 | Ford Tempo Cars & Trucks
Fujifilm battery fully charged but camera says no charge or very little. Just bought a new Duracell Battery and Charger for my Fuji FinePix J10 Camera. Used the charge on the battery in the camera from...
Well you mentioned that it worked fine yesterday with the battery out of the box. That should tell you that the camera and the battery are both fine. The issue is likely the charger itself. Try recharging it again, and double check that you inserted the batteries correctly, and that any switches (such as for 2 or 4 battery charge) are set in the correct position on the charger. If this doesn't work, take the charger back to the store for exchange/refund as defective.
Jun 11, 2011 | Fuji FinePix J10 Digital Camera
The laptop was working fine a couple of days ago, yesterday it wont switch on. i thought the battery may be flat so plugged in the cord, the light where the cord plugs into came on but no charging light...
Found this on the web. Good Forum link below. If you find this helpful, pls rate me.
http://forums.techguy.org/hardware/556796-solved-cmos-memory-size-wrong.html
try resetting cmos, make sure you put the battery in the right way also, to reset look in your motherboard manual, or there should be 3 prongs with a jumper on 2 near the battery (shuold say cmos) just unpower the computer completely, change the jumper to the other prong plug back in the power were only the motherboard is getting power, and then unplug-reset jumper- restart and see if that clears it up.
If the laptop does not hold a charge, and if the adapter wiggles, more then likely, you need a new motherboard. You can call manufacturer and see what one would cost.
Good Luck.
Jan 14, 2010 | Office Equipment & Supplies
Help
Wow, this is trully amazing. I went to do a search on why my camera wouldnt turn on the past couple of days, even after i charged all THREE of my batteries and found similar complaints within the same time frame!! WOW. We need to get together and fight this, cause its suspect!!! I bought mine in Mass, anyone else?
Jun 30, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
My camera wont turn on
1.See what the camera manual suggests.
2. Charge the batteries fully before using them. New ones are often not charged up. They could have been in a warehouse for months.
3. The electrical contacts on your camera, the ones that interface with the batteries, may be a little corroded. If you can access them easily, try cleaning them with the eraser on the end of a pencil. Same with the batteries themselves.
4. If exposed to prolonged high humidity, electrical problems may include not only the power supply, but other electrical switches, such as the reset button., which you cannot address on your own.
5. call the manufacturer
Jun 17, 2008 | Olympus FE-190 Digital Camera
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
HP Photosmart M425
camara has been working fine till yesterday, poewer won't turn on, to take pictures, but it turns on when i moved the tab to brouse pictures, bur when I switched it back power won't work
Oct 29, 2007 | Fuji FinePix E550 Digital Camera
My Exilim camera!
If this happens allot of the times you have to remove the battery from the camera for 24 hr so the camera's compositors can discharge all the way and not it is not the circuit board. Some time the circuit over loads and has to be discharged because of the polarity the electricity is travailing thought the circuits now I know diodes are suppose to prevent this but it is a common problem. hope this helps.
Aug 31, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
131 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
