SOURCE: wont record only on dvd+rw
Sorry but your laser is going! +R disks need a slightly higher burn power. Eventually you will have the same fault for RW disks.
SOURCE: panasonic sa-ak25
the problem is F61 is speaker protection mode on.
fault with your audio power amp section.
i can help you.
nuwan.
SOURCE: SC-BT 100 Error Code f61
Had the same problem. Found that the code refers to the cooling fan. Could be that the fan is dusty or not running when the system starts up. I removed the fan with the two screws and reseated the plug. Make certain that the short, black wire (that seems to go to nothing) is securing the plug to the board.
SOURCE: I have a panasonic sa-ht855
Your sound/power stage is not working. Set needs to be taken in for repairs.
