ERROR CODE T98-526 ON MY RISO RP3700 CALL SERVICE IS THE ERROR
  • 4,737 Answers
Please check the Drum and it's contacts. You can clean the contacts with a cotton bud dampen with alcohol or spirit or acetone. This is usually a bad drum connector. There's nothing much you can do, but you can try another tip, turn off the machine, leave it off for few minutes and again Turn back On while you hold down the Reset button.
If this doesn't helpful, try with another drum (maybe with the old one, but working). Also clean the contact on the machine.
In case the problem persists, you better contact Riso (click here : for u.s)
More details here (click here)
Good luck.
Thanks for using FixYa.
Posted on Sep 29, 2010
Riso RP3700 with error code T03-502. Looked it up online and it said Motor clamp locked. How to fix it?
T03-***
!!System Error!!
Press Reset Key
If Recovery has Failed, Call Service
Reset method: Jam reset or switch on power again
Feb 18, 2017 | Office Equipment & Supplies
Riso RP3700 gives A17221 error msg
have you checked you master disposal unit if there were any masters jammed in it?
Jan 29, 2014 | Riso RP 3700
Riso Rp3700 won't print from computer
We suffer the same issue. Have you find the solution?
May 02, 2013 | Office Equipment & Supplies
Riso rp3700 drum is stuck
Assuming that it is still in the locked position. Open the top and observe the position of the drum. Rotate the drum the normally locked position. i.e. The master clamp on the drum is in about the 2 O'clock position. Put in test mode, enter 556 and push start. That may release the drum.
PrntNow.com
Mar 17, 2013 | Riso RP 3700
I have a Riso RP3700 that we have been running NCR paper on. But the pass few months I have been getting jams after a few runs of the NCR it is always the pink copy that get jam on the drum. Can someone...
All you have to do is to ensure the image is pushed down the page. Either on your graphics software or on the RP3700 itself and by using the image offset function. Try 2mm at first.
If the image is too close to the margin the paper has trouble releasing from the drum as the ink makes it stick to drum. The little hook cant then get under the paper hence jam.
I am confident this will work.
Feb 21, 2011 | Riso Office Equipment & Supplies
On riso pr 3700 can not get the full image on landscape mode when I make a master
Maybe you meant model RP3700 ...
These questions may help to find a solution or at least a better understanding of your problem:
Have you set the paper size right?
Is the print drum capable of the desired imaging size?
Mar 31, 2010 | Riso RZ390 Duplicator
Riso HC5500 System Error - Restart!
I need help with the error code. s04-307 in my riso hc 5000
Oct 22, 2008 | Office Equipment & Supplies
612 people viewed this question
k24674
jasbo
jasbo
