Question about Xerox WorkCentre M20i All-In-One Laser Printer
How to copy 2 single sided papers to 1 double sided
    Sergeant:
  • 270 Answers
Please goto this link for the info you need,
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=M20_M20I&Xlang=en_US&Xcntry=USA
good luck and don't forget to vote!!!
Posted on Sep 29, 2010
How can I print single sided copies?
There should be a copy options button on the screen (often the left hand side). If you are copying a double sided page to make single sided copies choose 2 sided to 1 sided.
Or if you are copying 1 sided to 1 sided, make sure this option is selected (it is usually the default). Hopefully this helps!
Mar 21, 2017 | Office Equipment & Supplies
Two side copy ka tareeqa tell me
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printer cannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn the page upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for the rest of the document.
I suggest you try a test page first, to get the printing the right way up on both sides of the page so it reads correctly.
May 02, 2013 | Office Equipment & Supplies
Duplex copying on xerox phaser 3300mfp
I have the same problem and was told by the telephone helpdesk that the machine cannot copy double-sided to double-side. The duplexing referred to is copying 2 single-sided documents onto one single sheet on both sides....Like whoever does that! This is misleading on Xerox's part . Colin B.
Jul 08, 2012 | Xerox Phaser 3300Mfp/X Mono P/C/F/S 30Ppm...
How do you scan a double sided document?
You put your papers into the document feeder, then on the LCD screen there is a button that says 2 sided. Touch that button and select what you need. If you have a bunch of single sided pages that you want 2 sided then select 1,1-2. If you have a bunch of double sided pages that you need copied then select 2-2 and then puch the copy button.
Oct 11, 2011 | Sharp MX-2700N Color Copier
DOUBLE SIDED COPYING
First normaly copy first side, then take copied paper and set it in bypass tray, when you do thath, the copier ask you for paper size and type, choose correct sett. and confirm with OK.The side on wich you want to print must be face down in bypass tray.
May 11, 2010 | Canon iR 1600 Laser Photo Printer
How to make duplex copies from toshiba e-studio202L
I am going to assume you have a document feeder (ADF) on the copier.
Insert originals into document feeder and press the 1-1 simplex button on the LCD screen. If have single page documents that you want to turn into double sided documents then select 1 - 2 button. If you have double sided originals already and want to make double sided copies then select 2 - 2 button. Then hit the green copy start key...done.
Jan 17, 2010 | Toshiba e-Studio 202L Copier
Double side to single copy w/o paper feeder
Try this.
Set the copy for duplex.
Put the drivers license on the glass.
press the start button.
Turn drivers license over.
Press the start button.
Should copy on both sides of sheet.
If you copier has a booklet setting on it in the duplex. Page the front and back of the drivers license will appear on the same side of the page as well.
Jan 13, 2009 | Minolta DI2510 Black and White Copier
Single copy out of double original w/o using paper feeder
Does your machine have double siding capabilities?
If so on the control panel under original / copy. select 1:2, this will give you a double sided copy from a pair of single originals even off the glass.
EP 4000 Drawer Duplex
The duplexer is for 2 sided copies. You can take 2 single sided copies and make (duplex) them into 1 double sided copy. You can take double sided copies and make more double sided (2 sided) copies with the duplexer. You can also take double sided copies and make single sided copies. Hope this helps.
Jan 12, 2009 | Minolta EP4000/5000 CS/PRO Copier
Xerox WorkCentre M20i All-In-One Laser Printer Logo
18 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
