Question about Meade Telescope
Hello, i just rec'd my used meade 125etx ec scope.
Hello, i just rec'd my used meade 125etx ec scope. only to find the scope doesnt move east to west only north to south. called orig. owner and he said the gears are loose. so i called this place up north and he told me to unscrew the screw under the mounting cap. so i did half way as it wouldnt come out all the way. so i retightened it. now i dont hear the motor at all and it doesnt move at all not even up n down. can u pls tell me how to fix this? as it appears to me to be all in that screw in center of base part. thanx, debbie debdayy@att.net
  • 3,186 Answers
Contact Meade directly. You may need to send it back for repairs. Here is the contact web site:
http://www.meade.com/support/index.html
Posted on Sep 30, 2010
I have a Meade ETX-70. When turned on, the handset says there is a Motor Unit Fault: Motor failure detected due to moving handset between scopes, low battery level, obstructed or overloaded scope. I've...
This is usually caused by low battery power-- as the hand controller reported. DO NOT USE rechargeable batteries they do not have enough volts. Use alkaline batteries only.
This can also be caused by a broken gear or a failed internal motor. You can return these to Meade for repair.
Here is the contact number:
Sep 14, 2011 | Meade ETX-70 (240 x 70mm) Telescope
I really need the the battery pack to make work my Meade DS-114AT telescope? or I just need a transformer of 12V to plug in at the outlet to the wall?
You can use a regular deep cycle 12 volt battery-- or any 12 volt car starter battery. All you need is the correct 12 volt cigarette lighter style cable for your scope.
www.scopestuff.com should have the proper 12 volt plug for your scope.
May 01, 2011 | Meade DS114-EC Telescope
When I focus a star in the East and then slew the scope to the West it goes out of focus. I have have had it checked but they say there is nothing wrong.
This is called mirror flop. All SCT type telescopes have this.
TRY turning the focuser all the way in and all the way out 3 or 4 times to spread the grease out on the baffle tube. This sometimes helps with mirror flop.
Sep 21, 2010 | Meade LX200GPS Telescope
Hello. I just bought an older, used Meade LX200 18...
The scope will run just fine on 12 volts. www.scopestuff.com sells the cigarette lighter cord for that telescope.
Call them here:
www.scopestuff.com
May 16, 2010 | Optics
Level a Meade telescope.
You did not say what model, or if it was on a wedge or not???
Model name and number would also help.
LX200 Classic, LX50, LX10, LX90, ??????? Post more information.
Feb 04, 2010 | Meade Optics
Unit does not slew west to east
You never said which Meade telescope you had???
Usually this is caused by either broken gears, or a clutch with grease on it.
It could also be caused by a broken wire in the hand controller cable. Meade has a customer service line here:
Nov 30, 2009 | Meade Optics
My scope goes to everything from the meridian to the west, but will not center on things to east.
Scope is going to do a meridian FLIP-- during the "flip" the gotos can get off a bit-- just center a star on the other side of the flip and SYNC on it using the handcontroller.
Mar 09, 2009 | Meade LXD-55 Telescope
Meade etx-80 sticking
Some (not all) versions have an end stop - it it just reaching that? The scope will rotate only aboit 3 complete turns between the 2 ends.
The 'correct' starting position is as follows: Place scope on tripod or table with control panel at the West. Unlock the declination lock (horizontal slew). Rotate scope anticlockwise until it hits the end stop, Then roate it back clockwise until scope is pointing North (should be about 3/8 of a turn, as the end stop is at South West). Then lock the declination, Set the tube horizontal and continue with the alignment process.
Autostar always thinks you have set the position like that. If you haven't, it will work OK until it tries to rotate past the point it won't go, then chaos results!
Feb 12, 2008 | Meade ETX-90 (48x90 mm)
Meade Telescope Logo
60 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
