Question about Amana Refrigerators
Refrigerator dosen't work but the freezer does
    New Friend:
  • 50 Answers
Try to unplug your unit for 1 -2 hrs to defrost all ice at the back of the panel,open the panel on the freezer. use hair dryer to defrost the ice easily. check you fan if it is working properly..check also the resistance of the defroster..
Posted on Sep 29, 2010
Where can I get the magnet(seal) for the freezer door
Locate your model number on the fridge. Google that model number and put parts after the number
Find a wholesale parts dealer who has parts for your model. Appliancepros.com is one. If you don't see the part listed you may have to call them.
Dec 27, 2014 | Refrigerators
Danby DPR2262W propane refrigerator stopped cooling
OK-to make this short-you either have a boiler tube blockage or Hydrogen diffusion.If your cooling unit quit suddenly,you more than likely have a boiler tube blockage due to precipitation of Sodium Chromate.If your cooling unit gradually quit working it's Hydrogen diffusion.This process is not easy to understand,and I won't bother you with the details as to why.By the way,burping is a myth,it dosen't work.If there is a blockage in your cooling unit turning your refrigerator upside down won't dislodge it.Danby dosen't make stand alone Propane refrigerators anymore,and since the cooling unit is foamed into the box,it's a throw away refrigerator.You will have to get a Servel RGE 400 made by Dometic.It's the same size as the Danby and I have those for a very good price.Go to: www.marvinspropanerefrigerators.com
Aug 20, 2012 | Danby DPR2262 Top Freezer Refrigerator
Freezer ices up on back wall and dosen't stay cold .stops making ice and refrigerator starts to warm up. If I unplug deice unit it works fine for two or thee months befor it freezes back up and...
If your unit is frost free, then you have a defrost circuit failure, which is made up of the defrost heater, defrost thermostat and defrost timer. The defrost heater and defrost thermostat are located in the freezer compartment next to the evaporator coil and can be checked with an ohmmeter (anything except an open is good). The defrost timer is usually located in the free food side or in the compressor compartment.
Suggest you go to the www.searspartsdirect.com website and insert the model number off the equipment id tag on your unit and find the parts.
Aug 16, 2011 | Refrigerators
Magic Chef MCBR445W1 seems like it dosen,t stop
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Check on the cold control if faulty, replace the cold control, not having found any other problem, do check on plastic air deflector at the top rear of the frig had been knocked off. replaced it if faulty. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, which is now functioning properly.
Good luck.......
Aug 01, 2010 | Magic Chef MCBR440 Compact Refrigerator
My kenmore top freezer doesnt work my
the refrigerator may need some refrigerant, it might have a leak.
Mar 06, 2010 | Kenmore 64722 Top Freezer Refrigerator
Moved fridg to new house pluged it in dosen,t get coled at all!!!
If you had to lay the fridge down to move it? Then you have to let it stand upright for at least 24 hours before you can plug it in and use it or it won't cool, as oil will get into the coolant lines and foul the works.
If you didn't have to lay it down, then check for a switch and or harness under the front grill that may have got bumped out of adjustment of knocked the plug off.
I hope this helps you, and good luck.
Sep 16, 2009 | Maytag MBB2256GES Bottom Freezer...
Freezer on the bottom model # PBF2555HEW Freezer works refrigerator not cooling at all
I replaced my evaporator fan behind panel in freezer this was not spinning had to remove ice maker and panel to access got parts list emailed from kitchen aid and picked up part at local appliance dealer
Dec 24, 2008 | KitchenAid Architect KBFA25ERSS Stainless...
might sound stupid but is the fridge controled by a separate thermostat inside the fridge
Jun 26, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
