Question about Bosch Nexxt WTMC 3300 Electric Dryer
I have a Bosch Nexxt electric dryer. The lint light is blinking but dryer will not start, no clicking no nothing. completely cleaned out lint filter with vacuum cleaner. took top and back of dryer off, appears to be a red reset button, but feels loose. No wires loose, belt looks great. Please help, not sure what is wrong and would like to have fixed before my husband comes home.
  • robynp80 Sep 30, 2010
    Did the belt shut off switch, didn't seem like it did anything when I pushed it, but, did that and somehow was able to get ALL the lint out of the lint trap way down deep and it is up and running. I believe it was the belt shut off switch. Thank you so much, got it fixed right as my hubby walked through the door, and he thinks I am woman of the year! Thanks!
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
There are a couple of scenarios which may prevent the dryer from starting, but I can narrow it down to two probabilities based on your description.
To save time and back and forth dialog, I`ll mention the most likely and what to do about it.
**Unplug the dryer before attempting any repair tips suggested here please...safety first**
There is an auto shut off or emergency kill switch next to the motor which will prevent it to start in the event it was tripped for whatever reason.
It will look like this image below and all you need to do is push it to the right ( from the back )...
i.e.
If you`ve already taken the back of the dryer off to gain access you should have no problem.
Either Scenario I alluded to ( the other would be resetting the hi-limit cut out you already referred to, you can see through the back vent opening when the vent is removed and then by pushing the red button in...shown below ) will require the removal of that panel so let me know if you require further assistance to do this.
i.e.
Keep me posted how you make out or if anything is not clear.
Thanks for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on Sep 30, 2010
Testimonial: "Got it working!"
  • 1 more comment
    the red button will not push in, so does that mean something needs replaced??
  • Mark MacDonald
    Mark MacDonald Sep 30, 2010
    Do it means it is ok is all. If it where tripped you`d be able to push it in, since you cannot, it means it isn`t tripped.
    I`d try the belt shut of switch I alluded to in my first picture. It is at the back of the motor behind the belt pulley, push it to the right to set it to the "closed" position.
    Keep me posted.
    Macmarkus :)
  • Mark MacDonald
    Awesome, that's great news ! Glad I could help.
    I hope you'll take a second to rate the solution I wrote.
    Thanks again for visiting FixYa, spread the word.
    Regards,
    Macmarkus :)
Bosch dryer won't run
bad air flow switch,check wire diagram.
Mar 04, 2014 | Bosch Dryers
MY BOSCH NEXXT 500 ELECTRIC DRYER IS RUNNING ON 20 MIN AIR DRY BUT WITH NO HEAT. SOMETIMES BY SLOWLY MOVING THE DIAL WILL ALLOW THE HEAT TO RUN FOR A FEW MINUTES. THEN LINT SENSOR GOES ON. HAVE CLEANED...
Did you check this FIXYA LINK below? Appears to have lot's of answers!
Also I WATCHED the YOUTUBE video I recommended and NOTICED his DRIVE BELT is WAY too loose! Methinks THAT is why his dryer has problems!
Be SURE your belt is not to aged because they can STRETCH and then TRIP the "RESET SWITCH" he's talking about. Note the way his PULLEY shakes so violently... AND the action of the belt itself...
20 Most Recent Bosch Nexxt 500 Dryer Questions Answers
Here is another Link!
Bosch Dryer Won Heat 3 min FIX
And yet another!
(DON'T waste your time with the FOUR oval Links to the right! )
Dec 22, 2017 | Bosch Nexxt WTMC 6300 Electric Dryer
Bosch Nexxt Dryer gets warm but laundry doesn't get dry. Dryer stops after about 10 min of running and starts ''beeping''
this could be a faulty moisture sensor. try running the dryer in a timed dry mode and see what happens.also be sure to make sure all the duct work is free and clear and that the lint filter is clean
Jan 14, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer not working, indicates "lint filter" When I try to use the dryer (Bosch Nexxt), i first turn the dryer to the setting desired (regular or perm press, and time) it immediately has the "lint filter"...
This is a common complaint with this dryer.The probe generating this problem,is at fault.It likely has a film on it,from the dryer sheets.Remove the lint screen,and wipe down the probe that sticks into the air box.Should fix the problem,if not ,replace the probe.
Sep 01, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch dryer not workin
Sounds like the dryer needs a good cleaning inside the workings area. Have a technician take it apart, and have a vacuum handy to **** up all the lint. While in there, he can check the working parts.
Apr 24, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch dryer lint light flashes
My Bosch Nexxt electric dryer had the same problem with the lint filter light blinking and the dryer not running. It turned out that the door switch was not engaging. The service technician informed me that there is a plastic tab (available only by opening the top access panel) that was not fully snapped in place. When he snapped the tab back in place and then secured it with a screw, the door switch fully engaged, the lint filter light went out, and the dryer ran perfectly! I hope that helps you!
Feb 28, 2008 | Bosch Dryers
Bosch Nexxt WTMC 3300 Electric Dryer Logo
517 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
