Question about Whirlpool Duet GHW9150P Front Load Washer
My duet keeps flashing F2,what dose that mean?
  • Whirlpool Master
  • 2,605 Answers
Welcome to FixYa.
The "F02" on your model of washer indicates the machine has detected a fault or obstruction in the drain process.
The same error as the "F21" on the later model Kenmore/Whirlpool units.
Chances are the pump itself is being obstructed by debris or some other foreign object as opposed to being faulty, although the faulty pump can`t be ruled out...yet.
Here`s how to check it and clean it...
Though it being full of water may make it messy. A wet-dry shop vac is handy in this situation.
If it is in a position that allows you too lean it back against something strong or a second set of hands it will help if tilted back almost all the way.
Careful not to hurt the machine or yourself, and undo the fill hoses and drain hose.
**Turn off the breaker at the service panel or unplug the washer from the wall socket...safety first**
1) locate the screws in front at the very bottom of the panel below the door and pull the panel down and forward until it is off. They will be either 1/4" hex head or #20 torx head screws.
2) You will immediately see the drain pump in front of you with a large removable filter. ( **see image below...this is were a wet-dry shop vac and towels come in handy, also the use of the removed panel as a catch pan is beneficial...but you may still get wet )
3) Turn it counter-clockwise should allow you to remove it and inspect it and clean it out. Make a good thorough inspection inside the pump as well not just the removable filter.
4) Re-insert the filter and before placing the panel back run a test rinse/drain cycle to inspect for leaks and to verify the unit drains and spins now.
( If the problem still exist`s the "F21" will re-appear. If so you`ll need to check the hose/rubber bellows from pump to tub...back-flow ball...for other obstructions ).
5) If all appears OK after your efforts, well your efforts paid off...pat yourself on the back. You just saved yourself potentially a couple hundred bucks !
Now You should be good to go. Re-attach the lower panel and you`re back in business.
**NOTE: if this still fails to remedy the F21 or if it returns immediately during the next drain you may require a pump unfortunately...part # 280187 available at "searspartsdirect.com" "repairclinic.com" etc.
**This however can also be caused by the back-flow ball inside the bellows which connects the tub to the pump. There is a large clamp which secures it to the tub, but if you remove it to clean out all the dirt built up inside, make sure you get it good and secure when putting it back.**
Let me know how it goes and if you require further assistance.
Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today.
Good luck.
Regards,
Macmarkus :)
Posted on Sep 30, 2010
Washer is flashing f2
F2 on a Whirlpool Duet means their is a problem with the Drain Pump or Drain Pump Filter. The Drain Pump and Filter are located at the bottom of the Washing machine. You must remove the front, bottom panel to gain access to the Drain Pump and Filter. Disconnect the Filter and Drain Hoses and clear them out. If they are clear, you may need to replace your Drain Pump.
Feb 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Why does my whilpool duet washer flash F2: Its holding water and beeping.
First please verify this is a f2 and not a fo2 error
they mean almost the same thing i have it listed below
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Nov 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Keeps throwing an F2 code
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • If the above does not correct the problem, replace the pump.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer is saying f2 what does this mean
Hi
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
It keeps F2 me or saying suds I can't remember
F/02 Long Drain
Jan 03, 2010 | Whirlpool Washing Machines
I have a kenmore stove and it keeps flashing F2, I have unpluged it, could you please tell me what is wrong with it
is it e1 f2 or just f2. usually f2 means you have a shorted keyboard you need a new keypad.
May 28, 2009 | Kenmore Ovens
We get an F2 error and the machine shuts off.
to long to drain,,,press pause/cancel twice..that should it ...happy new year
Jan 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT GWH9300P Suds then F2
This means that the drain time has exceeded 8 minutes and the water valves have turned off. After 4 minutes the suds error is displayed then 4 minutes later the F2 error.
Potential causes
1.Check drain hose for kinks or cloggs
2.Check electrical connection at the pump and make sure the pump runs.
3.Check inside of pump for foreign objects
4.If none of the above fixes the machine replace the pump.
Nov 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader
F2=Long Drain If the drain time exceeds 8 mins the water valves are turned off and F02 is displayed
Check drain hose
check pump filter for foreign objects
check pump motor for proper operation
Jul 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
177 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
