Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Timer controls an outdoor light. Light comes on during day and off during nighttime. Rotating the dial does not change the operation to reverse the situation.
  • 56 Answers
Are you sure that the correct time is set for A.M or P.M. as well as the trippers
Posted on Sep 29, 2010
I have been using EH 711 for three years without any problem. Lately, the timer does not switch off and there is no way I can switch off the light during the day.
1) Hagar EH 711 analog timer has 24 month warranty
http://waterheatertimer.org/How-to-program-Hagar-timer.html#700-series
2) Check if dial is rotating and keeping good time.
Check if electric source is 80% rated value.
3) If dial is rotating correctly, change override switch, and possibly reverse all segments so segments that were pushed down are now up, and segments that were up are pushed down.
Dec 24, 2012 | Hardware & Accessories
Cant figure out which outlet is which number on Zilla timer. Turned on the yellow switches and then they turned back on at the time I have set for outlet 7. I thought the yellow ones were 1 and 2 or 1 and...
Open following link for Zilla timers
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
Zilla timers are unique for home-type timers.
They are two-channel timers, which means that timer has 2 independent programs.
In the case of Zilla, 1 program controls yellow outlets for daytime hours (6am to 6pm). Once daytime hours are over, the yellow outlets are OFF.
The other program controls blue outlets for nighttime hours (6pm to 6am). Once nighttime hours are over, the blue outlets are OFF.
So if you have a light for example, and light is plugged into yellow outlet, then you can program light to turn on-off during the daytime hours only. You cannot also set a nighttime program for the same light unless you plug light into blue outlet.
Zilla timers are for aquariums, where day and night plays important role in life cycle and activity of different types of aquatic beings.
Add a comment and say exactly which Zilla timer you have, and say what specifically you have done so far, and where you are stuck, and what loads you want to control.
May 02, 2011 | Coralife Zilla Aqualight Power Center
What dose 3 blinks on a fujitsu asta18lcc
Return air sensor short circuit. Replace it. Thanks.
Feb 04, 2011 | Fujitsu 18C1 Air Conditioner
How do I set the woods outdoor timer model #59730
Woods 59730 is24-hour 6-outlet yard stake with dial located on top
This timer is identical to GE15107 yard stake
Manual.
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
If this is not your timer, look at following page to identify your timer
http://waterheatertimer.org/Woods-timers-and-manuals.html
Add a comment any time
Timer instructions.
Set current time by rotating dial until time lines up with arrowhead located on inner dial
There are segments located around dial.
Look at inner dial > segments are located just outside the inner dial.
Timer comes with segments pushed inward.
To set timer to turn ON, pull segments outward for hours you want timer ON.
All 6 outlets are controlled by timer.
Last step:
There is override switch located on inner dial.
Move switch to TIMER for timer to operate.
Dec 09, 2010 | Woods Outdoor Lighting Timer
How do you program a Tork 602A timer? I can't get mine to cycle on and off at a desired time.
The Tork 602A mechanical outdoor timer with 2 grounded outlets.
Tork 601A and 602A manual
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Manual has images of timer that will help.
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or ink pen to set timer on-off functions.
With Tork timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
To double-check pin setting, manually rotate timer to watch when lights turn on-off.
Set multiple ON/OFFs each day.
Change on-off times by resetting a pin or two.
Timer repeats every 24-hours.
Manual ON/TIMER switch is located on inner dial.
Set Manual switch to TIMER for programs to operate.
To override time and turn on Load, move override to ON position.
Dec 09, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
How to set a GE outdoor timer product ID 51587 ?
GE 51587 has same instructions as Tork 601A single-outlet outdoor 24-hour mechanical timer.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
With GE timers, usually when pins are out, timer is ON.
Manual ON/TIMER switch located on inner dial.
Set override to timer for program to operate.
Dec 06, 2010 | GE 51587 MultiEvent Timer
I didn't get any instructions with my timer. It is a tork 601A I don't know how to set it. I think it looks great and just what I'm looking for. The case was sealed but no instructions. Thanks J Seel
Tork 601A outdoor timer manual:
Timer has 1 125Volt receptacle located on bottom of timer
96 captive tabs located around timer dial allow times to be set each 15 minutes.
Minimum time setting is 15 minutes.
Maximum time setting 23 ¾ hours.
Dial is divided into daylight and nighttime hours.
Nighttime PM hours are on dark background.
Daylight hours are on light background.
To set timer, rotate dial clockwise until current time lines up with arrowhead located on inner dial. Reset time after power outage.
To override time and turn on Load, move override to ON position. To use timer functions, move override to TIMER position
Dec 02, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
I have ge model 15119 24 her timer and need help on how to set
GE 15119 timer is a 24-hour plug-in dial-type timer.
Dial rotates as time passes.
Plastic segments located around outer edge of dial control on-off operations.
Each segment represents 30 minutes of 24-hour day.
Timer comes with segments down.
Each segment can be lifted up using small screwdriver under edge of segment.
Segments down, timer is ON.
Segments up, timer is OFF.
So if you want timer to turn on at 7pm and turn off at 11pm, then lift all segments around dial except segments between 7 and 11.
Dial is divided into two parts > day and night.
Nighttime hours are shown by numbers with dark background >> notice small crescent moon where 12 midnight is located.
Daylight hours are shown by numbers with light background, and sun symbol shows at 12 noon
To set current time, so timer knows what time it is right now:
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
There is override switch located on one side of timer.
Move switch to Timer ON position and timer program will function.
If you want to turn lights ON using override switch, move switch to OUTLET ON.
Last steps:
Turn lamp on.
Plug lamp into timer.
Plug timer into wall.
Dec 01, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
I need instructions on how to use the GE Ge 15107 24Hour Yard Stake Timer
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Outdoor-15107-Manual-eng-spn.pdf
Above is link to GE 15107 manual
This is a 15amp timer that can handle up to 1440 watts
How to set timer
Rotate center dial to set current time
Line up current time with triangle on inner part of dial
The timer dial shows nighttime hours on dark part of dial, daytime hours show on light part of dial
The timer dial rotates like a clock after it's plugged in
The outside edge of timer dial has 48 segments
Lift up these segments for times you want timer OFF
Segments down for timer ON
5c24d6c.jpgSegments up, timer OFF. Segments down, timer ON.
Segments in photo are on the GE 15207 timer
Oct 21, 2010 | GE 15107 24Hour Yard Stake Timer
Hello I lost my instructions for theej351c, can you help?
1. Move control lever to OFF-CLEAR for at least 5 seconds; red indicator light will go
off, and all previous time settings will be cleared from memory. (If timer fails to set, leave in off
position for 15 minutes.)
2. Move lever to ON. RED INDICATOR will start FLASHING.
3. Check a clock; then rotate time dial clockwise at least one click, stopping at the half
hour nearest to present time. NOTE: When rotating time dial, do NOT accidentally PRESS at
the same time. (While rotating dial, keep pressure, pulling out on the dial to avoid accidentally
setting an incorrect time.)
4. Press pushbutton once to enter present time. RED INDICATOR will go OFF, present
time has now been recorded.
5. Rotate time dial clockwise to desired ON time; RED light will PULSE momentarily
with each click.
6. Press pushbutton to enter ON time; controlled light(s) will turn on.
7. Rotate dial to desired OFF time.
8. Press pushbutton to enter OFF time; controlled light(s) will now be off.
9. Repeat Steps 5-8 for each addition ON/OFF period.
10. Continue to rotate time dial for at least 24 hours from the first ON time to complete
this program, at which time the RED INDICATOR light will come ON and stay ON,
indicating timer is in AUTOMATIC mode. NOTE: Dial does not rotate automatically
after setting to indicate time of day.
Oct 26, 2009 | Intermatic Programmable 24 Wall Switch...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
