Question about Brother SE-270D Computerized Sewing Machine
The bobbin winder does not make contact with the drive gear
The solution is to replace the rubber gear that engages with the drive gear. It has melted. Where do I find the part and what is the part number
Posted on Oct 17, 2010
Bobbin winder not working
For ~$30, you can purchase a stand-alone bobbin winder (Sidewinder) that you can use to wind your bobbins. Saves wear-n-tear on your machine and you can wind bobbins without unthreading your machine. Just be sure to verify your bobbins are compatible with the Sidewinder.
Amazon com Simplicity SideWinder Portable Bobbin Winder
Simplicity Sidewinder Portable Bobbin Winder
Simplicity SideWinder Bobbin Winder Walmart com
Simplicity Sidewinder Bobbin Winder
Jul 18, 2017 | Sewing Machines
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
https://www.youtube.com/watch?v=Fh52_ndkSKs
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ...
www.shopyourway.com > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
Dec 29, 2015 | Sewing Machines
Bobbin won't wind, how do I remove case to inspect gear?
If your bobbin winder is not working, for ~$25 you can purchase a stand-alone bobbin winder from the local fabric store (JoAnn's or Hancocks) or Amazon.com.
Nov 11, 2015 | Sewing Machines
Bobbin winder won't spin. I've had the machine for several years and this is the firt time this has happened. Help?
Hi Margaret, your issue indicates that the gear mechanism is not connected when you push the engagement lever. there are small gears built into the machine that works like a car gear. Modern day sewing machines have plastic parts and can wear over extended use. The parts can be replaced but you need to gain access to them to identify the damaged part.
Nov 09, 2015 | Sewing Machines
Designer 2. Why isn't bobbin winder working?
For ~$25 you can buy a stand-alone bobbin winder from the local fabric store (JoAnns or Hancocks) or even online (Amazon.com).
Oct 24, 2015 | Husqvarna Sewing Machines
Bobbin problems winding
Does the bobbin winder have a rubber o ring on it so that when the winder is in the winder position are the two making contact to wind
Mar 14, 2014 | Sewing Machines
Singer 648 has recently been cleaned, serviced. Has previously been winding bobbin fine, now it will not wind.
Ensure that the bobbin winder tyre is in place and not contaminated with oil, causing it to slip. Look to see that the mechanism also moves across far enough to let the two wheels contact to drive the winder.
Jan 16, 2011 | Singer 8280 Mechanical Sewing Machine
Problem with winding thread onto the bobbin (small free- arm Singer 100 sewing machine). Once bobbin winder shaft is pushed to the right nothing happens-bobbin rod does not start turning so I cannot wind...
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
Aug 18, 2008 | Singer Featherweight 140Q
Brother SE-270D Computerized Sewing Machine Logo
99 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
