Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Setting date on fotos
I want the date are displayed on the fotos that I have taken. How do I set the camera?
Thank you for your help!
  • 2,016 Answers
Date will only be displayed if the recording size (L, M1, M2, M3, S, Postcard) is set to Postcard.
You also have to set Date Stamp to ON in the Recording Menu (Menu button, select tab with camera silhouette, go down to Date Stamp).
Posted on May 27, 2008
How do I set the camera on postcard setting?
Go to camera menu when camera in shooting mode.......settings........check.......date/time display...
Dec 01, 2014 | Cameras
How do I change the date and time on a vivcam8225
Hello and welcome to FixYa!
This following steps allows you to set the system time which will be displayed on the photos.
  • Press the Up or Down buttons to select the Date option in the Setup menu.
  • Press the OK MENU button.
  • Press the Up or Down buttons to select a Date option from the menu that appears
On selecting "On" the date will appear on the photo once it is taken.
On selecting "Off" no date will appear on the photo.
On selecting "Set Date" the Set Date settings screen will appear. You will be able to change the date settings that will appear on the photo once it is taken.
To Set the date:
  • Press the Up or Down button to enter the Set Date option.
  • Press the Right/Left button to select and highlight the Year, Month, Day, Hour, Minute, Second and Date Format type.
  • Press the Up or Down button to set the Date and Time digits.
  • Select the first option of the Date format and press the Up or Down button to set the date format that appears on the top line: YY MM DD; DD MM YY; MM DD YY.
  • Press the OK MENU button to confirm, save the changes and exit.
You have done it.
I hope this solution helps you
If you have any more query or issue regarding your problem do inform me.
Thank you for using FixYa!
May 16, 2011 | Vivitar Vivicam 8225 Digital Camera
I have a Lumix DMC Z57 and would like to set it so when I take a picture the date the date will appear on the picture. Is this possible?
HMMM, I know the date is recorded on the digital file when it was taken and what the camera settings were. I know when I transfer mine to the hard drive i organise bu the date taken. so this info is there in the meta data recorded with each exposure. It sounds like you want it displayed on the pictures Too?
In Picasa( the free google software) File info is displayed at the bottom of each phota and a right click on the image and selecting properties reveals the meta data Camera date, date digitised, modified ect.
Feb 20, 2011 | Panasonic Lumix DMC-ZS3 Digital Camera
How do i get the date and time displayed on the fotos (print) Model DSC-W180
Select Print Setting with arrows key then select date/time to display on image
you can find the user manual from here
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCW50
Nov 05, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Hello, Does anyone know if this camera datestamps the .jpg files it creates (date taken, date modified - also the date taken attribute in the exif data)? Thank you Trevor
hi Trevor
yes most digital cameras put on the date n time set on the Camera om the .jpg files and also on the exif data
hope this helped
cheers
PS if you felt this was any bit helpful then pls rate the solution
Jun 19, 2009 | Cameras
Date display in photos in IXUS40
here is the solution:
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
To set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
your date and time are set now
congratulations!
Rate this answer if it is working with you
thank you
with all my best regards
huetrichard@gmail.com
May 09, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Using my memory card, i check my photos display with out date & time.
You will find a setting that will date/time stamp the actual image when it's taken. Please take a look in your manual. Most cameras have this feature.
May 09, 2009 | Sony Cybershot S650 Digital Camera
Canon Powershot SD 1100ES - display problems
My mother has this model camera. I believe there is a setting in the main menu that will allow an energy saving mode that sets the display time or no display. If not it's under warranty and your retailer should replace it if it is within 30 days of purcase date.
I hope this helps, goood luck!
Nov 20, 2008 | Canon PowerShot SD1100 IS Digital Camera
Hi thank you so much
I AM GLAD THAT I WAS ABLE TO HELP YOU. IT WAS A PLEASURE WORKING ON YOUR PROBLEM AND WORKING TO CORRECT IT. PLEASE FEEL FREE TO REPLY ANYTIME YOU NEED HELP!
ARCLIGHT1217
Nov 05, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Show the Date stamp on the picture
One reason why the date stamp is not showing would be that you have not set the system date/time. The date/time resets everytime you take out the battery. Please go to this link and download the userguide... http://alpha02u.c-wss.com/inc/ApplServlet?SV=WWUCA900 file name : PSS500IXUS500CUG-EN.pdf ...Go to page 26 which will tell you how to set the date/time and then go to page 109,113 for the date/time to be displayed on the photographs. Please tell me if this helps
Mar 09, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
110 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
