Question about Cameras
My exilim casio ex-280 camera says memory locked.IT is not locked it is unlocked,i have tried a new memory card and it says memory locked.Is there a number of the manufactures that i can call to report this problem and send it back?
    Brigadier General:
  • 3,006 Answers
This is such a common question that I hope you don't mind if I paste my generic answer below. Note that cards may appear to be unlocked when they're not. The answer also covers what to do if the card is faulty.
Your camera uses SD memory cards. On one edge is a slider switch: towards the electrical contacts is the unlocked position and away from them is locked.
Unfortunately, the switch is easy to move accidentally and it's also easy for it to appear to be unlocked when it isn't. Like any mechanical component it's also possible for the switch to fail.
If the switch is in the locked position then slide it fully to the unlocked position; if it's already in the unlocked position, slide it fully to the locked position and then fully back again. There should be a soft click at each end of the switch travel, if not then the switch is definitely faulty or obstructed.
If that fails, then try looking closely at the switch in both positions to ensure that there is no debris obstructing its movement, if not then check the electrical contacts to ensure that they're completely clean and grease-free. Don't touch the contacts with your bare skin, but if the contacts need cleaning then a cotton bud (Q-tip) moistened with a little alcohol or methylated spirits can be used to clean them.
If you still have no fix, then try a different SD card as yours may have an irreparable faulty switch. If the card does prove to be faulty then on most major brands you may be able to return them to the manufacturer for exchange: I've found that they will often do this on a goodwill basis even if the card is out of warranty. Just check the manufacturer's website for support details.
If all options regarding the memory card are unsuccessful, then you have a faulty camera and further remedies require either a professional repair or replacement of the camera.
I hope that my answer has been of use and has given you additional options to fix your problem. Please take a moment to rate my reply.
Posted on Sep 30, 2010
How to unlock "card lock" on a Exilim EX-V7 camara
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 07, 2013 | Casio Exilim EX-S500 Digital Camera
How to unlock card on CASIO Exilim EX-Z700 camera???
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 01, 2011 | Casio Exilim Zoom EX-Z700 Digital Camera
Kimly may -casio exilim the card is locked
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 05, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Casio exilim ex-80 always shows SD card as locked
the SD card should have a small switch on the upper left side it slides from lock to unlock if this doesnt work Look in the card slot - there may be a small bit of plastic sticking out over where the card's locking switch would fit when the card's inserted.
Oct 25, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Exilim memory locked
its or child lock ,check manual or firmware damage ....software in the camera check how to fix in manual..
Aug 30, 2009 | Casio Exilim EX-S500 Digital Camera
Card locked but its not
Memory cards are funny things that can sometimes currupt for various reasons i suggest you just buy a new memory card.
Try to retrieve the pictures you can get on your computer before you dispose of the old one.
Good luck
Apr 12, 2009 | Casio Exilim EX-S600 Digital Camera
Camera says card locked
1) Try to unlock it by the lock/unlock switch on the side of the memory card.
2) If step 1 does not work replace memory card with new card.
3) If step 1 & 2 do not work the problem is internal (inside the camera). Go to www.ecasiorepair.com to get a quote for repair. Cost will be anywhere from $39-115 to fix it (if not under warranty). You could even ask if this is a defective camera (lemon) they might even fix it for free? I've seen this issue with the Casio a lot.
Dec 17, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio exilim EX-S880 8.1.mp memory card locked
there should be a little swith on the side of the card. switch to the opposite and then try
Sep 27, 2008 | Casio Exilim EX-Z40 Digital Camera
Card locked
1) If you take out the memory card there will be a small unlock/lock switch on the side of it (that may be the problem?)
2) If step 1 does not work, than it's an internal issue w/camera and you will have to send it to Casio for repair. Here is the link www.ecasiorepair.com. They will charge $39-115 if the camera is not under warranty.
Jul 31, 2008 | Casio Exilim Pro EX-P600 Digital Camera
Cameras Logo
170 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
