Question about Schwinn Mist Girl's 20 Inch Bike
Falcon CF-E10 rear hub on Schwinn 20 inch bike makes grinding noise when coasting alone. Why?
4 Suggested Answers
goalie39
  • 469 Answers
SOURCE: How to disassemble crank bearing on Schwinn Mesa Mountain Bike
You wil need a couple of special tools, or be fairly creative with the tools you have.
  1. remove the dustcovers in the crank arms at the crank axle
  2. loosen the crank retaining nut/bolt.
  3. thread in a chank puller and pull the crank arms.
  4. remove the lock ring on the adjustable side of the crank axle (Requires lock ring wrench)
  5. remove adjustable bearing cup.
  6. remove axle and bearings
  7. replace or repair as needed.
Once you have it opened up ou can determine if you need new bearings or crank axle.
to assemble, reverse above procedure, insuring bearing play is minimalized.
Hope this helps.
Ed
Posted on Apr 19, 2009
  • 1138 Answers
SOURCE: cant get rear hub back together
Try going to www.sheldonbrown.com/repair/index.html. I think what you need is there. Hope this helps.
Posted on May 23, 2009
dunnbiker
  • 8546 Answers
SOURCE: Need a parts or owners
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 12, 2011
I bought a meridian trike from schwinn, my kids took a hammer to the chain guard and my wife is upset, is there any way I can just buy a new chain guard for this trike? Also want to put a motor plz
Schwinn Meridian chainguard - schwinnbikeforum
www.schwinnbikeforum.com > ... > WELTERWEIGHT PLUS
Oct 20, 2012 - 5 posts - ‎5 authors
A little help please... My daughter needs a new chainguard for her Schwinn Meridian. She loaned her trike out, to be used in a parade, and ...
I need a new chain guard for a Schwinn Meridian Adult - Fixya
www.fixya.com/.../t10679393-need_new_chain_guard_schwinn_meridi...
Oct 16, 2011 - SOURCE: Meridian Adult 26-Inch 3-Wheel Bike: Schwinn Meridian Tricycle rear brake adjustment... ... Schwinn Meridian Adult 26-Inch... ... Have a manual for Schwinn Meridian Adult 26-Inch 3-Wheel Bike?
Brian riding on his new Schwinn Meridian 24-inch 3-wheel ...
Dec 26, 2015 | Cycling
How do I correct the clanking noise in the rear of my Schwinn 24" Meridain Tricycle?
It could be that the chain needs tensioned, or if it is a coaster brake, the hub may need serviced. The noise could be coming from anywhere and your best bet is to have a qualified mechanic look at it.
Oct 31, 2014 | Schwinn S4025 Meridian 24" Single Speed...
Huffy boys bike makes clicking noise
does it make the "clicking" noise when coasting, pedaling or both? If it is only when pedaling, check to make sure the cranks are not rubbing on a chain guard or hitting the frame, if not then the chain is probably too tight and it is the gear cog teeth meshing with the tight chain. Loosen the rear axle nuts and slide the rear wheel forward slightly, this should take care of it. If the noise happens while coasting then one of the wheels could be rubbing on the frame intermittently, or the hub bearings could be too tight (also making it difficult for small legs to pedal) and the bearings are crushed and flattening making the "clicking" noise as they are being ground up.
Apr 21, 2014 | Huffy Pro Thunder Boys 16-Inch BMX Bike
When coasting the pedals keep moving so you have to continue to pedal and when peddling backwards the bike goes backwards, how do I stop this?
I assume that this bike normally has a coaster brake. If so, your coaster brake mechanism (inside the hub of the drive wheel) is jammed or broken. You will have to disasssemble the wheel hub. This bike might have a coaster brake on both rear wheels or maybe just one side. Lift both rear wheels off the ground and turn them independently to determine which side the problem is on.
Sep 18, 2012 | Schwinn Meridian Adult 26-Inch 3-Wheel...
The rear wheel on my schwinn delmar spins fine while pedalling, but when I'm coasting, it makes a grinding noise. I checked and it's not grinding on any parts (frame, fender, etc). It makes the...
Same thing happenes to mine. i called customer servive and they sent me a new set of complete wheels for free. They told me i had bad bearings.
Sep 21, 2011 | Cycling
It doesn't roll smooth there's a grinding when it's coasting and it's worse when im pedaling. What the problem. I just bought it too. How do I fix it?
Diagnosis first.
I'd advise you to apply your eyes and ears to the problem, paying particular attention to parts that move. A coasting noise is tire rub somewhere or some really bad bearings.
Pedaling adds the chain, pedals and crank bearings to the mix.
Feb 16, 2011 | Schwinn Meridian Adult 26-Inch 3-Wheel...
When freewheeling, is the clacking noise normal ? i've never had a trike.
Being a one-speed bike it should be virtually silent when coasting.
Determine what's hitting by walking the bike along a driveway and observing where the sound is coming from.
This might help, too, for general purposes.
http://tricyclesforadults.net/schwinn-meridian-assembly.html
Feb 05, 2011 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Cant get rear hub back together
May 20, 2009 | Schwinn 20 Inch Girls Starlet Bike
Schwinn Mist Girl's 20 Inch Bike Logo
1,115 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
