Question about Whirlpool Duet GHW9150P Front Load Washer
Where is the most cost efficient place to buy replacement parts. Especially knobs and door lock plastic pieces. Thanks
  • Whirlpool Master
  • 3,361 Answers
Www.repairclinic.com
Posted on Sep 29, 2010
    Problem Solver:
  • 9 Answers
Recently I was looking for the best deal, and return policy for a lock/latch assy. for a Whirlpool front loader. Appliancepartspros.com was the winner out of 12 or so I compared.
Posted on Oct 01, 2010
Sharp r520kst door wont stay shut
If the door will not stay closed it is the spring inside door, or the small plastic piece that holds the spring which is attached to the $80.00 piece called outer door.
To fix it, it is EASY and you do not have to even take the inside cover all the way off. Just remove the three sides of cover by gently slipping a plastic putty knife around rim to release the clips. Then attach the spring to the small hole below where the plastic piece used to be, which is located in the metal on the glass frame piece, use tweezers, hold the other end of spring as you place spring onto plastic door latch and set into place!
Snap the inside cover back on and YAY! FINI!
Mar 23, 2013 | Sharp R-520KST Countertop Microwave Oven...
All the knobs on my lg gas range need to be replaced. the plastic part in the middle of the knob jst did not last and the replacement for all five knobs is at least one third of the total cost of the...
I have a $1.50 per knob solution: 1. Buy a 1/2 x 5/8 x 1 spacer at Lowe's ($1.50 each - get 5 pieces) 2. Clean knobs, remove back cover of knob and connect broken plastic parts with glue (liquid form). Make sure little metal inside the plastic is on front end. 3. Apply glue (gel form) around plastic then slide the metal spacer over. Add more gel glue to fill up space between plastic and metal. Might want to wait 30minutes then apply more glue if there is still space or gap. That's it! I recommend waiting 24 hours to let glue cure until putting it back on range. Now you can put cap back on but would need to make the whole a little wider using a grinder.I used a small flathead screwdriver and a hammer and just chip off small pieces until metal sleeve would fit. However, I think u can do without the cap if you have strong glue. I have pictures. Feel free to contact me for questions: cbraza@yahoo.com My wife is very happy, saved her a lot of money coz new ones cost as much as buying a new range itself! The knobs are very sturdy right now. Wide says it's actually sturider than when we first got the range.1_25_2013_5_53_38_am.jpg1_25_2013_5_54_22_am.jpg1_25_2013_5_54_47_am.jpg
Sep 02, 2011 | LG LRG30855ST Stainless Steel Gas Range
Alternative replacement knob for lg #LRG30357ST, originals are plastic and all broken
Last time I bought replacement knobs (LG) from amazon. Take a look here Amazon com LRG30357ST knob. I hope this was helpful. cheers
Feb 05, 2011 | LG LRG30855ST Stainless Steel Gas Range
The turning mechanism on my triton ivory 4 has broken. The piece of plastic that sit in the cog to turn the power on has broken off. How do i get this repaired?
Hi, just had the same problem if you carefully remove both knobs and swop them over as the bottom knob does not require the T piece.If you get some thin plastic and gently prise each tab out enough to insert the wedges it will pull out. Hope this helps.
Jan 23, 2011 | Home
I have a 93 lexus es300. the door opens from the inside but will not open from the outside. Can you explain or send me a diagram of how the handle operates. the handle appears to be o.k. and the lock is...
There's a short rod held in place with plastic fasteners that goes from the outside handle to the door latch. You need to take off the door panel upholstery panel to get to it. Sometimes you get lucky and only need to put it back in place. If the plastic part is missing, look if it's in the bottom of the door. It's a small piece, but is a dealer item. A automotive glass shop might have them but not likely.
Aug 08, 2017 | 1993 Lexus Es 300
Knobs on range do not work properly. need to replace them
Hi- Give LG a call, I did replace some once on a range and LG sent them out at no cost to the owner. Just have your model and serial number. Good luck
Sep 24, 2010 | LG LRG30855ST Stainless Steel Gas Range
2000 lincoln ls
I just went thru this on my 2002. The silver handle is actually plastic (I didn't previosly realize this) and had broken in such a way that it no longer applied leverage to the door mechanism. Everything still worked fine from the outside.
I got a new handle from the dealer (is one complete piece) for about $70. and took the door apart (much more difficult than it sounds).3 or 4 screws across the bottom - 2 in the flip up portion of door handhold and 1 straight behind the handle itself. Lots of plastic pop locks holding door in place - need to be pulled straight out vice normal slide up - proceed slow - very easy to break plastic pieces. Replacing handle requires you to drill out three rivets and replace them for holding new door handle in place.
Can do in about 1 hr with help and all the necessary tools - flat pry bar, screwdrivers, cordless drill, etc.
Dec 12, 2008 | 2000 Lincoln LS
Broken part on camera
I suspect you won't be able to buy the part. However, you might be able to fashion a suitable piece of plastic and glue it in place using an expoy resin adhesive like araldite. Or use gaffer tape to hold it shut! Samsung may be willing to repair it but it'll probably cost you.
Oct 28, 2007 | Samsung Digimax D53 Digital Camera
Whirlpool Duet GHW9150P Front Load Washer Logo
82 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
