Question about EliteGroup P4M800PRO-M Motherboard
Problem with the EliteGroup P4M800PRO-M Motherboard Will not boot
  • EliteGroup Master
  • 27,725 Answers
Test your PSU or replace it
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Posted on Sep 29, 2010
  • discales1 Sep 29, 2010
    What's a PSU? also I forgot it stopped working when I put in a new dvd writer a HPdvd840 so I took it out and it still does'nt work.
  • Brian Sullivan
    Brian Sullivan Sep 29, 2010
    (power supply unit) if your computer starts but will not boot into windows replace all leads that are attached to your hard drive from *********** board IDE,SATA and include electric extensions from the power supply unit PSU and test all leads from your drives cd\dvd\3 1/2 floppy one bad/faulty lead will lead to a no boot up
    hope this helps and good luck
map9966
  • 2351 Answers
SOURCE: Lag Booting
This is a shot in the dark, bare with me. Disconnect everything from the back of pc except the video, mouse & keyboard. Enter your bios. Still have lag? Reset the bios by clearing the cmos jumper pg. 9 in your manual & remove the battery & check it for 3v if you can. If the lag went away by disconnecting the other devices than re-connect one device at a time with a reboot inbetween. When the lag returns you will know which device is not right. Everything applies when doing this kind of search. If you have two dimms remove one. Check for lag. Than swap memory/check. When you boot to the bios it involves the cpu, motherboard, video, memory & power supply. Your hard drive is also an issue but only at booting to OS. Did the pc encounter a unexpected shut down? Did you replace a device like a mouse or a keyboard? Here it the link for your board. ESC shows very little in regards to FAQ's. I hope something above helps you find a answer! http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=674&DetailName=Bios&MenuID=1&LanID=9
Please vote...
Posted on Jan 30, 2008
  • 4 Answers
SOURCE: EliteGroup P4M800PRO-M Motherboard Problem
Install PC wizard address below. Run & find out your Elite driver number.
Visit Elite home page search for that driver.
Install.
If you can't get, it visit Driverguide listed below. Become a free member & download the driver & install.
I was in a similar situation,& was helped by a kind supporter inWhat the tech.com.That option is also available.But it takes 2 / 3 daysbefore u can run it. Best of luck.
Source(s): http://pc-wizard-2008.en.softonic.com http://members.driverguide.com/driver/
http://forums.whatthetech.com/
Posted on Oct 02, 2008
siawolf
  • 749 Answers
SOURCE: will this ram support my motherboard?
your motherboard supports • Supports DDR2 533/400 DDR SDRAM DIMMs
• Accommodates two unbuffered DIMMs
• Up to 1 GB per DIMM with maximum memory size up to 2 GB
that ram may or may not work, most likely not as the motherboard was designed for slower memory.
Posted on Apr 10, 2009
  • 26 Answers
SOURCE: how to reset this motherboard?
remove power lead and internal battery for 5 mins then replace all and it will be reset to manufacturer date and settings
Posted on Oct 21, 2009
bronk50
  • 27725 Answers
SOURCE: I have an elitegroup p4m800pro
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Posted on Apr 20, 2011
I have an elitegroup p4m800pro m v 2.0 motherboard with an intel 6300 cpu. I am trying to install Windows 7 with no success. I keep getting the message "Reboot and select proper boot...
hope this helps
Apr 20, 2011 | EliteGroup P4M800PRO-M Motherboard
Which vga card compatible wit P4M800PRO-M2, Pci or AGP?
Hi. Thanks for your question.
Video card compatible with your motherboard is an AGP 8x.
Hope this helped. For more info about your motherboard please see this link------>http://www.dealtime.com/Elitegroup-ECS-P4M800PRO-M2-2-0-Via-Socket-775-MicroATX-Motherboard-Audio-VGA-AGP-8x-10-100-Ethernet/prices
Thank you for using FixYa.
Dec 17, 2010 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Sound driver not found
Please try the following website http://driverscollection.com/?H=P4M800PRO-M2 (V1.0)&By=ECS (Elitegroup)
Dec 15, 2010 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
ECS P4M800PRO-M2 2.0 MOTHERBOARD NO VGA INSTALLED PLEASE HELP
I think you should post a detailed information of your problem.
What the problems you are getting?
Have you Install VGA graphic driver? or
Have you not getting display?
Where you getting this message?
Your operating system boots or not?
Post all ans and problems then only it will be possible for me to solve your problem. Thank you.
Nov 25, 2009 | EliteGroup P4M800PRO-M Motherboard
How to reset this motherboard? P4M800PRO-M2 (V2.0) from elitegroup.thanks
Oct 21, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Power swith order
It does not matter -- pressing the "power" button on the front of the computer closes the circuit, and the motherboard boots itself.
May 19, 2009 | EliteGroup P4M800PRO-M Motherboard
Please give me a copy of installer of my motherboard?
you can download the drivers at : http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?DetailID=673&CategoryID=1&DetailName=Feature&MenuID=44&LanID=9
Jan 06, 2009 | EliteGroup P4M800PRO-M Motherboard
Problem with ecs elitegroup P4M800PRO-M2
Hi, Based on your post/description, it appears to be a hardware issue. Check that you have a 300watt PSU (or higher) preferably with 24 pins (ATX v2.x). Perhaps you can try to do an R&R, remove and reinstall everything especially the power connector, memory and video card (if add-on). It may also be worth your while to reset the BIOS/CMOS to default and try again. If problem persist, then perhaps it will be to your advantage to have the motherboard replaced. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 03, 2007 | EliteGroup P4M800PRO-M Motherboard
EliteGroup P4M800PRO-M Motherboard Logo
62 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
