Question about Zephyr Venezia ZVE-E30 Kitchen Hood
FAN AND LIGHTS QUIT WORKING ALL AT ONCE - Zephyr Venezia ZVE-E30 Kitchen Hood
    Sergeant:
    Champion:
  • 351 Answers
I would check broker first
Posted on Sep 29, 2010
Cooling fans run continuosly on 2001 alero
When the temp sensor fails, the computer will turn on the fan relay as a precaution to overheating.
Once you find the problem with the sensor you may also fix the fan problem.
If the check engine light is on you should also check the computer for trouble codes.
Feb 21, 2013 | 2000 Oldsmobile Alero
Engine cooling fan has quit working ? at first it wouldn't shut off and now it wont stay on
this is going to sound crazy but remove the passenger side headlight you will see the bucket assembly that the light sits in it,s plastic at the bottom of light bucket trim out a little hole about three or four inch square once removed you will see the fan relay held in by two screws if you don,t cut hole for access you will have to remove front bumper cover assembly alot of work and the hole deal is better it does,nt hurt a thing once headlight is back in you will never know little hole is there this is a tremendous time saver hope this helps
Jul 30, 2010 | 2002 Jeep Grand Cherokee
Motor and fan on exterior unit work once then do
im not qiute sure about this but it sounds to me like you are getting a hard lockout from high or low pressuers on the out side unit
Aug 27, 2009 | Heating & Cooling
Wall switch and remote quit working for fan and light
Simple things to check - sometimes the vibration from the fan will cause the wires to come loose. Drop the fan and make sure both wire nuts are secure - take the opportunity to check and make sure you have voltage (using a voltmeter or a 110v test light) at the junction box. Do you have lights on the fan? Do they come on? If you have power to the fan, something is amiss inside the fan such as a faulty speed switch or connection.
Jul 20, 2009 | Hampton Bay 24750 Huntington III Ceiling...
When I unplugged my Acer PC and plugged it back in, it would not restart. It did this once before, after punching it on and off repeatedly, it finally started. Not so this time...It makes the right noises...
It may be due to CPU Fan problem or other. If u can do, open the cpu cover and go to fan and Open the Fan or Sometimes hitting the fan may work. Don't hit it badly do gently okey. If solved thums up!
Jun 24, 2009 | Acer Aspire T690 (AST690UP820A) PC...
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
Toutside a/c unit fan quit spinning
sounds like starter on a/c is going out you need to replace it as it starts the fan and compressor as well good luck (thats assuming toutside means outside)
Aug 23, 2008 | Heating & Cooling
Zephyr Venezia ZVE-E30 Kitchen Hood Logo
197 people viewed this question
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
The Vanguardian
The Vanguardian
Dale Copeland
Dale Copeland
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
