Question about Casablanca Fan Versa Touch2 W-72 Remote Control
How do you program your remote control for a casablanca fan versa touch 2. model w-72
3 Suggested Answers
MN_Jack76
  • 45 Answers
SOURCE: my casablanca fan versa touch 2 does not respond to remote control -
I believe there is a dipswitch, and a non- dipswitch version. To sinc the remote to receiver, shut power off to the fan receiver by either a switch or breaker for about 10 minutes, turn power back on and press Hi, Medium, Low on the remote in that order. this should get them "talking" again. If this does not work, contact toll-free Jason at Fan Man Lighting 1-866-600-3267, he has 30 years experience with casablanca
Posted on Oct 17, 2009
caroldon
  • 17129 Answers
SOURCE: Casablanca Fan/Light Remote (Versa Touch #W-42)
Possible that the drive to the IR LED is low and it can be due to poor output from the driver or a weak IR LED.
Please check this link below for some tips.
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
Point your remote to your camera in the phone and see if there discharge is good enough . If not check the voltage at the IR, check if there is break in the printed circuit board or a possible open circuit from a SMD resistor...use a multimeter to check continuity.
Look on the PCB using a good magnifying lens to confirm.
Posted on Feb 22, 2011
Casablanca Visa-touch fan
most problems solved with new batteries
Jul 31, 2013 | Casablanca Fan Versa Touch2 W-72 Remote...
W-72 remote won't work
1) change by new batteries alkaline
2) clean the contacts batteries with isopropyl alcohol
3) tight the springs contacts for better contacts with pliers
4) open the remote control, and clean the keypads switch from dirty, oxide, corrosion.bad contacts, or open contacts. This will NOT trasmitt the infrared signal to the receiver.
5) Otherwise you must go to the repair shop TV for fix it
see the block diagram
Jul 26, 2012 | Casablanca Fan Versa Touch2 W-72 Remote...
Remote works fine for fan and uplight however, lower light goes bright then dims to off.
there seems to be a problem try pressing and holding the light button see if that helps if not there is an issue with the module on the fan itself
Jan 02, 2011 | Casablanca Fan Versa Touch2 W-72 Remote...
How do you program a casablanca fan remote control to work for the fan?
Howdy,
Casablanca control systems are specific, for instance Inteli-Touch (4 button wall control with power fan light and reverse buttons) uses power line signals to a computer board inside the fan's motor housing and a remote control using RF will not work. However, you do not state what control you have, or what specific control you wish to attempt to use with the fan. Some will work some, will not.
Thanks and Reply so I can better help you!
Sep 14, 2010 | Casablanca Fan (3845T) Brushed Nickel...
Remote control doesn't work. Small red light stays lit.
First check the remote control with a similar TV.
By keeping a MW radio receiver you can check the functioning of the remote by pressing the keys. Radio will give garble sound!
If remote is OK , TV has to be checked.
Apr 05, 2010 | Casablanca Fan Versa Touch2 W-72 Remote...
Casablanca fan stopped working suddenly, both fan & light
You must 'reset' the remote. I've had it happen quite a few times.
1. Turn off power to fan. Then back on.
2. Using remote cycle the following fan buttons from high to med to low, then from low to med to high again. That 'should' fix the problem.
Sep 29, 2009 | Casablanca Fan Versa Touch2 W-72 Remote...
My casablanca fan versa touch 2 does not respond to remote control - batery is fine, breaker fuse too. I recall having a same problem some time ago, forgot, how I fixed it - I know it was something with...
Sep 04, 2008 | Casablanca Fan Versa Touch2 W-72 Remote...
Casablanca Fan Versa Touch2 W-72 Remote Control Logo
87 people viewed this question
Top Casablanca Fan Televison & Video Experts
Steve
michael vanier
Are you a Casablanca Fan Televison and Video Expert? Answer questions, earn points and help others
