Question about Barbeques Galore Turbo Classic 3-Burner 207795 (LP) Grill
My 3 burner built in has been a great, very hot, grill over the years. lately however it takes forever to heat up and the flame seems very low. ANY HELP OUT THERE
    Problem Solver:
  • 6 Answers
It could be a couple of things. First you could be low on propane or natural gas depending on what you use. The second thing is that over time the little holes in the burners clog. You can poke them clean with a toothpick. Or if they are rusted you will need new ones which you can find from an appliance parts dealer or manufacturers website.
Posted on Sep 30, 2010
I'm aving a low flame issue. I replaced the burneres and heat shields a couple of months ago, worked great for a while, but now the flame on all 4 burners is low. When the heat is turned down to half...
If you're turning off your propane tank after each use (which is fine), you will need to turn it back on very, very slowly. The new OPD valves that are now required on all portable propane tanks, will lock up the regulator if it's turned on to fast. Also, check all the pilot orifices for clogs. And finally, be sure you have enough gas in the tank.
Jan 19, 2011 | Barbeques Galore Turbo STS 4-Burner with...
My Weber Q grill worked great for 5 years but now it won't light on one corner and I can't get a high flame on any part of the burner. Even on "high" the flames are small & blue and the heat level is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 26, 2010 | Weber Q Grill
The first burner seems to burn very low and not very hot
If it was me, I would,first try to clean them and see if that improves the flames. During the course of cleaning you can determine if the burners are corroded and needing replacement or just caked up and dirty. Are the burners stainless steel or cast iron? Cast iron lasts longer, and tends to get smaller in flames when it's seams corrode shut. Plus it is easier to clean. Stainless steel tends to corrode and fall apart, causing flare ups and unsafe use. Douglas
Jul 05, 2010 | Barbeques Galore Turbo STS 4-Burner...
Inadequate flame and heat
I'd change the regulator, clean the burners and the surrounding area. Make sure that the air intakes around the burners aren't blocked , plugged..
Also check the gas orifices for cleanliness... outdoor grilles are nutorious for bug hotels... these little critters move in, lay eggs and it can screw up the burners, orifices... I've several times needed to remove orifices to clean the inside of mini spider nests... Look them over closely..
Jun 01, 2010 | Weber Genesis Silver B Grill
Flare behind temperature knobs on jenn-air gas grill
This seems to be a problem for most Jenn-Air users. The burners are defective, rusted or clogged and allowing the flame to "back up." You most likely have a melted electronic ignitor as well as gas valve damage. The new burners that I received this week for my model 720-0061-LP are 1/2 inch shorter than previous versions. Time will tell if this fixed the problem. I would call Nexgrill and get all new burners and inspect the gas valve area for damage. Since 2004, I am on my 5th set of burners, glad they were free since I have a lifetime warranty on my model.
Apr 17, 2010 | Grilling
Grill lights but flame is low and goes out if control is moved from high. Burner tube is clean, spider screen is clean, and I have a full tank of LP. Grill is Q series about 1 year old and has been working...
Hello. Are you frustrated because your gas grill doesn't get hot enough lately. The problem you are having indicates that you have to go through a procedure called "RESETTING THE REGULATOR". Follow these easy steps:
1. Turn the burners on for one full minute and then off.
2. Next, remove the regulator and the hose from the tank.
3. Then reconnect the tank to the regulator and hose.
4. And very slowly open the tank.
5. Last step is to fire up the burners and start cooking with you new hot flame.
The problem began the first time you opened the valve on the tank too quickly. In the future, always turn the tank valve on s-l-o-w-l-y to prevent this problem.. Joe
Mar 22, 2010 | Weber Q Grill
My charbroil grill isn't running at full power
Your venturi could be clogged up. clean the burner holes with a straightened paperclip, then take the burners out and do the same to the venturi that deliver gas to the burners. If that doesn't do it, you may have a bad regulator.
Feb 26, 2018 | Char-Broil Grilling
Low gas flow - low heat
The only way you can fix the low flame, low heat problem, is to remove the grill, take a medium sized paper-clip (staightened out) and clean out each individual hole on the steel burner, flame tube. (I'm sure there's a technical name for it).
Since they (the holes on the flame tube) face up unprotected, directly under the grill cooking surface they tend to get blocked quickly with continous use and certain foods, like pork ribs. Bad design unless all you plan on grilling is hot dogs.
There are about 500 individual holes, so plan on being there a while. Or in other words, do it close to the cooler.
I've been tempted to toss the thing into the woods a bunch of times over the past 2 years I've owned the dumb thing.
Apr 19, 2008 | Weber Q Grill
Flame not hot
If the propane tank is full, it could be the pressure regulator. Some regulators have an adjustment screw on the top.
If it's REALLY cold outside, the propane may not be evaporating fast enough to keep the pressure up. Also on a cold or windy day, heat is drawn away from the grill very quickly, and it may be difficult to keep the temperature up inside.
(And Happy Grilling!)
Mar 31, 2008 | Vermont Casting The Extreme VCS5005BI...
Uneven heat from burners
I'm experiencing the same problem, the left side has the least heat, and it seems to be getting way worse over time.  Has anyone found a solution for this yet?
Oct 17, 2007 | Weber Genesis Silver B Grill
Barbeques Galore Turbo Classic 3-Burner 207795 (LP) Grill Logo
105 people viewed this question
Top Barbeques Galore Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Barbeques Galore Grilling Expert? Answer questions, earn points and help others
