Question about Dryers
I have a Kenmore Dryer m#110.62922100 It works at one house but not at our new house. We took it back and forth..works at one house not at other. I checked voltage at back on dryer at the terminal block and it has 118 on each hot to ground and I am showing 230 from one hot to other....please help.I have all the voltage required at the plug..I don't understand what the problem could be.thanks,Joe
  • j_m_nvestmen Sep 30, 2010
    I didn't notice if the light was on...I even ran a whole new wire and connected directly to the dryer....once again voltage was still 220...push button no motor start. what would I look for if it was in the supply of electricity from company. the dryer has a 3 prong but like I said it works at my house...thanks, again JOE
    President:
  • 1,554 Answers
When you say the dryer doesn't work at the new house, do you mean no function works at all? How about the drum light?
The dryer works at the old house therefore there's nothing wrong with it. The problem is therefore with the power outlet at the new house unless you did some modifications of the dryer power cord such as conversion from 3-prong to 4-prong or the other. It can also be an issue with the power utility your new house is connected to. Verify any of these conditions by plugging the dryer in a neighbor's house and if the same thing happens.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. But accepting a solution will not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 29, 2010
  • Jahn27
    Jahn27 Sep 30, 2010
    The only thing you can look for if it's in the supply of electricity from the power utility is the frequency since the voltages are correct. Also closely inspect and compare the power outlet at both houses on how the voltages measure including the circuit breakers. The neutral/ground circuit breaker for the dryer or the house itself may be the issue here.
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
Took out the thing that holds the screen for the dryer to clean out the dryer lint that gets past the screen, now my dryer will not heat.
Hello
As other things are working fine but the dryer won't heat so the issue is with the Thermal fuse and needs replacement as they cannot be reset. Thermal fuse is located on the heater element housing and you can check it for continuity as well with a ohm meter. Please check this picture:
Please get back to me if you have any other questions.
Kevin
Nov 16, 2010 | Kenmore 85871 Electric Dryer
Kenmore electric dryer, won't start and clicks by time dry knob
usually the thermal fuse goes and dryer dies part number 3390719 located in front of dryer on top of the blower wheel housing,when you read anything out you have to pull one of the wires off to get correct reading.also on some of the dryers there is a switch on the pulley that will kill the dryer if the belt breaks
Nov 02, 2009 | Kenmore 62602 Electric Dryer
My Kenmore 697267 dryer is not turning on. I took off the back and the button is connecting. What do I do next? Thank You!
Find your breaker box, reset the breaker to the dryer. If this doesn't work you will need to replace the thermal fuse located inside the dryer on the vent housing. You can go to www.partselect.com enter your complete model number. It will show you a break down of your unit. You will be able to find the part, see where the part goes and even buy it with a credit card. Good luck.
Oct 17, 2009 | Kenmore Dryers
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Cant find heating element for kenmore 80 series dryer
it should be in a housing mounted just inside the back panel. unlatch the housing from its mounts and the element slides out from the bottom
Jan 02, 2009 | Kenmore 63942 Dryer
I have a Kenmore Elite HE3 gas dryer. The dryer worked great. And then we moved to a new house. We had to have a gas line installed for the washer and dryer. Ever since we've been in the new house the...
The first thing to do is check the venting from the back of the dryer to the outside of the house including the venthood make sure it is clear. Blocked airflow can increase dry time decrease efficiency.
Dec 30, 2008 | Dryers
Electric Kenmore Dryer
possible bad timer but first ck thermal fuse ..if top mount filter remove back fuse is small white object on blower housing ..if door mount filter remove bottom panel remove lint screen remove 2 screws each side holing lint screen housing in place fuse is behind it ..if fuse cks good suspect timer ..
Sep 07, 2008 | Kenmore 62602 Electric Dryer
Kenmore Elite Oasis Dryer with Airflow problem
same problem removed back cover cleaned lint found pulley had unscrewed and belt was off.installed pulley rev threded and put belt back on.
Mar 02, 2008 | Kenmore Elite HE4 Electric Dryer
E-1 light
check owners manual should have a code listing. Have you checked the vent and venting
Oct 17, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
46 people viewed this question
Top Dryers Experts
