Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
I somehow locked my wd extrenal hard drive. Can you help me?
  • Western Digital Master
  • 27,725 Answers
If you can see your external hard drive on your computer
During the boot up process you will see on the screen press delete to enter set up
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
hope this helps
Posted on Sep 29, 2010
My WD element extrenal hard drive won't open. i can see it in my devices, and the blue light stays on. it also makes the sound saying it's connected but I can't see the device in my comput
First thing, try to change the cable, try a different one, then if it does not work, try to connect the hard drive on another computer, and changing cables as well. This will help you to narrow down the problem to find out exactly what the matter is. If the Hard drive spins properly and it does not produce any click-click sound then it is fine. If all the above fail, then you have to slave the hard drive using its internal SATA connection. You have to open up the hard drive and remove the pin that connects the hard drive to the cable. This will enable you to see the SATA connection. Slave the Hard drive on a desktop computer and see if you can gain access to it. If you can, then consider replacing both the cable and the pin that connects the cable to the hard drive. If your hard drive just spins and you can not access it while its a slave to another computer, then the hard drive has a problem.... Try the methods above, i believe your hard drive did not go this bad...
Mar 26, 2012 | Western Digital Elements powered by WD 320...
I HAD Western Digital My Book Essential 1TB External USB 2.0 Hard Drive ON M PC AND I CONECT WESTERN DIGITAL MY PASSPORT AND RUN THE AUTO FROM THIS SOMETHING LIKE WD SMART.... AND NOW MY Western Digital My...
Your WD HDD have been attacted by viruses for your computer or outside computer where you used it last. Make sure that you have an up to date antivirus software, scan your computer or the external hard drive, explore your computer, go to tools - folder options under view files & folders select show hidden files and folders apply and ok it.
May 18, 2011 | Western Digital My Book Essential 1TB...
Somehow my WD Passport became a generic volume and I cannot have access to it with the message I/O device error. What should I do?
Get a new one: the I/O error happens when the control board of the hard drive is dead and this cannot be repaired.
Jan 08, 2011 | Western Digital WD Passport 250GB Portable...
Wont recognize usb anymore
if the external hard disk drive powers on, perhaps replacing the USB cable could help ?
i had WD extrenal, and it crapped out on me -- i had so much vital information that i lost . i finally discovered that the power modeul inside the housing that encases the drive was bad.. i coul not get the PC board replaced.
i hope you can resolve this with new USB cable.
have you tried another computer -- see if that PC recognises the WD external drive
let me know how it works out for you
Nov 03, 2010 | Western Digital WD Passport 250GB Portable...
I broke the part of my WD mybook can i replace it
What part? in most cases extrenals are not fixable You may be able to retreve some data if the disc is not broken
Feb 26, 2010 | Western Digital 320GB MyBook External USB...
My computer restarts recognaizing WD external hard drive!
I suggest you check the power management on the device. You can right-click the disk in the Device Manager and see if it is allowed to be powered off, or you can check the power settings in the control panel.
Most likely it is turned off, and when it resumes, the computer somehow thinks it was not plugged before.
Jules
Apr 19, 2009 | Western Digital Passport WDXML800UE...
Extrenal cd rom will not boot
Go into the setup menu on boot (before the windows screen appears) by pressing F2 or F10.
Go to the Boot Options and check that the CD-ROM/USB Device boots before the hard disk drive. Save and Exit.
Mar 05, 2009 | Dell Latitude C400 LCD DIsplay Bezel -...
Bought extrenal hard drive WD
Right click on my computer.
Choose manage.
Then choose disk mangement.
Then you will probably have to assign it a drive letter.
Aug 11, 2008 | Computers & Internet
My mac g5 is not recognising my WD elements extrenal hard drive, this is the first time I have plugged an extrenal hard drive of this sort into my mac. Thanks
My computer does not recognize the Drive.
A: First, check to make sure that all of your connections are secure. Then check if your External Hard Drive is listed in the Apple System Profiler. If the driver listed is “USB Authoring Support” or “Toast USB Support”, disable this Extension(s) in the Extensions Manager. These Extensions can cause a conflict with the Drive.
Jul 19, 2008 | Computers & Internet
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
179 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
