Question about Sharp LC52SB55U LCD TV
Screw size for mounting sharp 52 lcd model LC52SB55U to Sanus wall mount model VMAA26
SOURCE: wall mount hardware
The bolt size you need is: M8-1.25 X 20.  20 is the length that I used and it works well.  You could also use 25 (which is a little longer) if you would like.
It took about 5 trips to Home Depot and Lowe's and a few hours searching the web before we got it right.
Posted on Oct 11, 2007
jerryg50
  • 1667 Answers
SOURCE: wall mounting emerson lc320em9 television
I don't know the model in particular, but most of these sets can be wall mounted if you have the screw holes for the mounting plate in the back of the set.
What I believe the tech was telling you would be that it is best to not wall mount the set. The reason is that we found that we have been seeing a higher failure rate from sets being wall mounted. This is because the surface of the wall reflects some heat back in the set, and thus causes it to internaly run warmer. This is also the same from running a set inside of a cabinet. The complete surface area behind the set being very close to the wall surface blocks cooler air circulation. It is best to run these sets on a stand that is out in the opened at least 1 foot away from any wall surface.
Jerry G.
Posted on Jun 28, 2008
dsacco86
  • 1077 Answers
SOURCE: HAVE A SHARP 52" LCD #LC52D65U AND I CAN'T FIGURE OUT HOW TO REMOVE THE STAND SO I CAN MOUNT IT ON MY WALL. PLEASE HELP ME
On the back of your TV, there are 4 long hex bolts. It should have triangles pointing towards the holes. Take the 4 long hex bolts out and the stand itself should slide out with no problems.
Posted on May 21, 2009
SOURCE: I need to purchase an owners manual
If it is not on the Sharp usa web site, try the Sharp canada web site. I found mine there.
Posted on Jun 09, 2009
  • 92 Answers
SOURCE: what size screw for holes on back of set
go to this size to figure out the screw size. http://www.tvwallmountguide.net/
Posted on Jun 18, 2009
What wall mount do I use for model LC320EMXF
There are several that have universal applications for mounting. The best, in my opinion, is Chief Mount. Sanus is a workable mount but I would steer clear of the Peerless mounts. The mounts will come in a one size fits a certain field (ex. fits 20 to 32 inch).
Aug 15, 2014 | Emerson LC320EM9 32 in. LCD HDTV
Size of wall mount for GPX LED HDTV
Not sure what you are asking. Are you looking for the screw for the attaching the mount to the TV or the mount to the wall.
If you are looking for the screw size for the back of the TV, it could be metric size M6 or M8. Just be careful of the length. Too long and you will ruin the TV. Maybe google the TV model and it might show in the owner manual the exact screw to use.
Apr 18, 2014 | LG 42LG50 42 in. LCD HDTV
Screw size for mount and tv un32f5500af
This TV is VESA mount compliant with a spacing of 200MM x 200MM. the mount holes are M8 1.25 and about 23MM deep. 3 of the holes are recessed and one hole is near surface. Adding a 2-3 MM margin for a typical washer and the mount itself, M8 1.25, 25MM screws might be the best to mount this TV.
I am using the Sanus simplicity SMF3 mount (bought from costco). The spacers provided with this mount are 22MM which makes the supplied M8 35MM screws too small with the spacers. Without the spacers, the supplied M8 16MM screws are too small. With spacers, I think the screw size should be M8 45MM and without spacers it should be M8 25MM
I am thinking a vinyl washer might be a good addition to the assembly (with my sanus mount).
Found this site useful to understand the screw dimensions.
http://www.fastenermart.com/html/metricsizes.html
Dec 22, 2013 | Samsung Televison & Video
I need a wall mount bracket
Most if not all tv's are VESA compatible. All wall mounts are VESA compatible, meaning you can buy any wall mount you see fit to mount your tv.
I'd look into Sanus brand mounts, they're pretty decent.
Mar 08, 2011 | Emerson LC320EM8 32 in. LCD TV
What is the size of the 4 screws on the back of the lg 32ld350 tv?
Remove the 3 screws from the base, these screws are mostlikely metric M4/.70 pitch 3/4 inch long. these are the screws are the matching screens for the wall mount. You will have to buy 1 more. Also 1/8 mini fender washers maybe required to hold the bracket to the back of the TV due to the slots.
Hope this helps.
Jun 30, 2010 | Sharp LC52SB55U LCD TV
May 21, 2009 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Jan 18, 2009 | Sharp LC52SB55U LCD TV
Attaching 26 " lcd to stud wall
12 inches is the minimum for mounting the unit to the wall. I mounted a 42 inch LCD using a Sanus tilt (non-swivel) mount from Best Buy. We mounted it on wooden beams exactly 12 inches apart. Works great!
Mar 05, 2008 | Televison & Video
Sharp LC52SB55U LCD TV Logo
294 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
