Question about Miranda Kaleido-Alto-A Virtual Video Wall Processor KALEIDOALTOA
Miramda video wall
I can't get my rcp's menu function on screen,jnr in dept changed UMD to remote,was on disabled before. Also all inputs (12 I'm using) are green screen. was working fine last nght.
any suggestions please?
  • Alan didak May 25, 2008
    oh i should add that the inputs are ok,just not getting displayed and each window is on what inputs they should be on.
  • Alan didak May 29, 2008
    ah ha! it turns out that the key colour had been changed (mysteriously may I add too) so the green screens I was seeing were correct,and the SDI inputs were all ok,it was just trying to key the feeds on a different colour. (sabotage???)
    Problem Solver:
  • 7 Answers
Sounds like a setting got changed. Static maybe? you might want to call a professional to help with this one.
Posted on May 28, 2008
I accidentally changed the settings on my remote control using the on screen menu from dvd1 to dvd2
I'm not sure the question - perhaps your TV is set to the DVD2 input and it's not a DVD issue.
If so, using your TV remote, push the "input" button until you reach your desired input.
Apr 07, 2015 | Televison & Video
Sanyo model # ds19310 16 jnch tv stuck on video chanel wont change to any other chanel volume works pat of menue works but the channel search and two other chanel menue controls are not available tv skips...
If you still have the Sanyo remote, you just need to press the INPUT button on the remote. The channel search and some other functions are disabled when the TV is in video/AV/game mode.
If you don't have the Sanyo remote, but you have a Universal remote which you use with the TV, look for a button labelled INPUT or SOURCE on this remote and try pressing it.
If you don't have any remote for this TV or you are using a universal remote which does not have an INPUT or SOURCE button, please reply to me from within this page for further assistance and let me know the brand and model number of any universal remote you are using. There is no option in the menu for doing this, but there a couple of methods which work on some TVs
Hope this helps.
Regards,
BElectric
Feb 05, 2011 | Sanyo DS19310 19" TV
Hi I left the TV on comp input[TV-AV1-AV2-COMP]. After a while, it switched to blue screen with some sort of menu and does not respond to any function on remote. It plays audio from AV1 but no video. The...
Unplug from the wall, count to 10 and plug back in. If that doesn't work, press Input or Source and change to to the place where your normal signal comes from.
Nov 05, 2017 | Nolo Dealing with Problem Employees: A L...
When i try to run a iso/cso game, the white psp would shoe up and then the screen truns black went back to the psp menu and it said Game could not start 80020148 my psp's system software is 5.00 M33-4
What you need to do is disable the umd from within the custom firmware menu. Completely turn off the PSP (hold the power button up until it turns off). Then while holding the right shoulder button, turn the PSP on. The recovery menu will load. Select configuration and then disable the "no umd" option. Exit from the recovery menu and insert a umd disc into the PSP. Make sure auto start is also disabled in the PSP menu settings. You should now be able to run your game.
Hope this helps and thank you for using FixYa
Jan 06, 2011 | Sony PlayStation Portable (PSP) Console
Today I start my printer canon ir 2520 and i see dept id and password prompt screen, I did not reset any id and password earlier, I cannot go inside the menu or i can't take any copy. Please give solution...
oday I start my printer canon ir 2520 and i see dept id and password prompt screen, I did not reset any id and password earlier, I cannot go inside the menu or i can't take any copy. Please give solution for disable or reset the same.
Oct 23, 2010 | Canon iR 2022 Printer
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
My psp goes right to the menu. It use to go the the game. I can't get to the game anymore. Help!
Are you using a UMD? It could be that the AutoPlay functionality was disabled. You can access it under the Games menu.
Nov 30, 2009 | Sony PlayStation Portable (PSP) Console
Hi good day, my psp is also having the error 80020148 i tried those two solutions you have posted but none of which seems to works, im using version 5.00 M33-6 please help, i need your advise on this...
TO FIX THE PROBLEM FOLLOW THESE STEPS:
1. Goto Recovery Menu (turn off then hold R and turn on)
2. Configuration -> Use NO-UMD (Disable it)
3. Go all the way back to main menu
4. Advanced -> Advanced Configuration -> (Disable all of them)
Configuration Should be Like This ->
.....................1. Disabled
.....................2. Enabled
.....................3. 1.50 (for Phat but needs 1.5 kernel addon) 3.80 (for Slim)
.....................4. Disabled
.....................5. Normal (Needs UMD game to play Isos) if not try Sony Np9660
.....................6. Disabled
.....................7. Enabled
.....................8. Disabled
.....................9. Enabled
.....................10. Memory Stick
.....................11. Enabled
.....................12. Disabled
Advanced->
.................Advanced configuration->
.................................................. .Disabled
i hope this might help you
Nov 28, 2009 | Sony PlayStation Portable (PSP) Slim...
PSP hanged when switch on. The usual screen appears but without the menu icons except for a small circle at the bottom right hand corner which keeps spiinning. Icons will only appear when I open the UMD...
conect your psp to you pc/lap top and find a default setting for your psps this are just like other peoples psp saved dater try that look on game sites and console cheats sites
May 09, 2008 | Sony PlayStation Portable (PSP) Console
Unable to view setup menu on TV screen
I had this same experience and after hours of attepts to fix it (including the suggestions on this site) I found that the company that installed and set up my system literally disabled the "set up" on the remote so that it could not be changed. To fix this (and/or confirm that this may be your problem) reference page 39, "all reset functions" to reset your remote back to factory settings. As soon as I did this and hit "set-up" -- the set up menu popped up and worked appropriately. Hope this works for you!
Dec 16, 2007 | Denon AVR-3802 Receiver
Televison & Video Logo
107 people viewed this question
Top Miranda Televison & Video Experts
Electro Med Services...
Are you a Miranda Televison and Video Expert? Answer questions, earn points and help others
