Question about Asko W6222 Top Load Washer
I have just had my Asko W6222 installed and I can't get the door to shut properly - the red light beside the start/stop button is flashing and the door is not fully clicking shut even though I am using a lot of force
  • 11,896 Answers
Sounds like the door lock is on. Unplug it and press the stop or cancel or pause button for 20 full seconds. Then wait a half hour and plug it in and see if the machine resets.
Posted on Sep 29, 2010
My asko w6222 shows F3 and stops. What is an F3 - some kind of error?
Drainage error
If F3 is flashing on the display, there is a
drainage problem. Check:
• that no objects are stuck in the drainage
hose outlet.
• that the drain pump is not blocked by foreign
objects. Clean the pump (see the
"Care and cleaning" chapter).
• that there are no kinks in the drainage
hose.
After taking the necessary action, run the
Drain program or press the Door Opening
button (key symbol) to empty the machine. If
the problem persists, contact the Customer
Care Center at
1-800-898-1879
www.askousa.com
May 30, 2008 | Asko Washing Machines
My ASKO W6222 won't drain
Sounds like the inlet water valve is not seated properly and is letting water in when it shouldn't .
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 20, 2012 | Asko W6222 Top Load Washer
During the washing circle the machine stops and F3 appears in the time window and machine cant restart
If F3 is flashing, then you are having a problem with drainage.
Check that there is no object stuck in the drain hose outlet. Check that the pump is not blocked by foreign objects and clean the pump. Check that there are no kinks in the drain hose.
After making these corrections, run the drain program or press the key button (door open) to empty the machine.
Feb 10, 2011 | Asko W6222 Top Load Washer
Hi, I have the ASKO W6222 front load washer, my
if the valve was stuck open it would run all the time the washer was on i would say that there is a power short running to the valve turning it on when not selected
sonic boom electronics australia
Jan 04, 2011 | Asko W6222 Top Load Washer
How do you remove the agitators on the asko w6222 front loader(not the "use and care guide" book respose please)
dont be afraid to use pressure and lean the screw driver to the left as you pull down on the agitator goodluck
Apr 08, 2010 | Asko W6222 Top Load Washer
Power on Press Start.Lights flash. Close door . Fails to Start
Possible causes
1. Main switch is OFF.
2. Door not properly closed.
3. Fuse has blown.
4. Power supply plug not plugged in.
5. Water tap not opened.
Please check these and let me know if any have worked.
And please remember to rate me.
Feb 02, 2009 | Asko D1996SS Built-in Dishwasher
Open Questions:
See all Asko W6222 Top Load Washer Questions
Asko W6222 Top Load Washer Logo
147 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
