Question about Hotpoint RGB745 Gas Kitchen Range
Hotpoint gas range oven ignighter lights but oven never lites up
    Sergeant:
    Champion:
  • 351 Answers
Igniter is bad
Posted on Sep 29, 2010
Testimonial: "THANK YOU"
The oven doesn.t go on, I see the ignighter turn on but the gas won't light.
Hello Jim,
Believe it not the igniter is the problem,yes indeed it is coming on yet it is not getting hot enough to allow the gas valve to open. By replacing the igniter with a fresh strong one, the oven will work just fine.
GENE
Nov 14, 2011 | Kitchen Ranges
Piolt lites but will not stay lit for hotpoint RGB524pph2wh
If you are referring to the oven pilot lite, you will need to replace the "Oven Pilot with Thermocouple". Here is a link to the part you need.
Sep 29, 2011 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint gas stove with electric ignition, model # RGB745GEV2WH -- oven will not come on -- I played with the knobs and got it to come on once tonight but can not duplicate that. Oven will simply not turn...
That's you ignitor. They get weak. If it has a glow that is dim orange that is a sign. Another sign of a weak glowbar is you can kick the oven and make her lite off. themobilian_467.jpg
Dec 17, 2010 | Hotpoint RGB535 Gas Kitchen Range
Hotpoint gas oven 5yrs old pre heats fine but then doesn't keep temp up.
You have either a faulty oven thermostat, or your oven door seal is faulty. You can check the oven door seal by doing the following (you will need a A4 piece of paper):
Open the door put the paper against the seal, close the door. Now pull the paper slowly out, if there is resistance then the seal is fine.
The oven thermostat test is as follows (you will need a stopwatch):
Turn your oven on to the lowest setting,when it goes to high flame start timing it the oven should cut down within 8 minutes, if this doesn't occur your stat is faulty.
I hope this helps
Jul 06, 2009 | Frigidaire Gallery 30" Self-Cleaning...
Pilot lite for the oven need it located
If you remove the bottom panel inside the oven you will see pilot and burner that heats the oven.
Jan 01, 2009 | Hotpoint RGA520 Gas Kitchen Range
Ligthing the oven glow bar
you need to replace the oven glow bar take out the oven racks in the bottom of the range you will see two screws remove them remove the bottom oven pan under that is the flame spreader shield under that under it you will se the ignighter at the back of the burner bar just follow the instruct sheet with the ignighter to install and reverse just because the old bar glow-es don't mean its good just replace it
Jul 16, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven & broiler not working
you ignitor is going out you will need to replace it the ignitor needs to draw a min of 3.2 amps in order to open the gas valve coil if short of this it will not open at thimes it may just have enough to open
Jun 28, 2008 | Hotpoint RGB528 Gas Kitchen Range
Magic chef oven
change the bottom ignighter just because it glowes doesn't mean its getting hot enough to open the safety valve you should see two screws at the bottom of the floor of the oven cavity after removing the racks remove those and remove the floor then you will see a deflector shield remove that to get access to the ignighter take out the two screws and install the new ignightor and reassemble
Jan 21, 2008 | Magic Chef 31100 Gas Kitchen Range
Oven does not light
even if the ingitor glows, and the oven wont lite, the odds are that the ingitor is bad. it must draw 3.2 amps to open the gas valve. the only way to test the ignitor is with an amp probe. replacing the ingnitor is about 90% a sure thing.
Dec 08, 2006 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
428 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
John Tripp
John Tripp
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
