Question about SanDisk 2GB microSD Memory Card
Cannot format micro sd card tried diffrent holders
    Top Expert:
  • SanDisk Master
  • 76,109 Answers
The only answer is the card is defective. they do fail, see this smae post often
Posted on Sep 29, 2010
My palm centro wont recognise my micro sd
First of all check the SD card on your PC by using an adapter for the micro SD. Once this is confirmed we can be sure that the fault is within the phone. Try and format the SD card as some malwares or corrupt unrecognised files can fault the phone memory. now make sure that the Sd card holder is contacting, if there is no result before the phone can be taken for a consensus to the service center, try with another card.
Nov 08, 2011 | AT&T Palm Centro Cell Phone - White
My lg t300 isn't reading my micro-sd card, so what should i do to fix it?
Try checking locky micro SD card on hand just in case locked. Next do an anti virus scan on your PC, usually data files have Headen infected due to virus, or did the format but not before first copy the existing data and save it on your PC. Next copy and paste data on the micro SD card. nex on a micro SD card input, and open menu phonsel phonsel, next select memory. if still not read, error mean micro SD card, and replace with a new
Aug 22, 2011 | Gomadic Car Cup Holder for the LG T300 -...
How I format micro sd card if MSDC write sector error?
Do this click my computer>right click icon of your micro sd card>choose format (don't check quick format) need full format to recovered bad sector. if finish formating, right click icon of your micro sd card >properties>choose tools>choose error checking and click check now.
To fix your micro sd card.
Also try to scan using anti-virus sometimes virus became write sector error.
Jul 15, 2011 | Computers & Internet
When I try to put music on the micro sdcard I cant.Then I try format the sdcard and it tells me the sdcard is write protected.
Hello!!
I suppose you are using the card via inserting it in the CAP ( Holder) that came with the card to be able to make it used with card reader.
So, the Micro SD card gets locked only through it's CAP (Holder)
Steps to Unlock :
Insert the card into the CAP (Holder).
Please check the Upper Left side of the CAP (Holder).
There must be One switch which will slide Up and Down.
Push that switch to Upper side. (Pushing to downward will lock while the reverse will Unlock the Card).
Now Insert it to Card Reader to use it.
Hope it Helps..!!!
Jul 06, 2011 | Samsung Propel SGH-a767 Cell Phone
I have an 8GB micro sd card for my blackberry storm when i put it in. It says media card has inserted contains errors. to correct the errors use a disk error-checking utility on a computer. what do i need...
The chances on any micro sd card showing errors can be either the files stored in it are corrupted or the card is simply bad already. You may try to identify the problem by performing the following steps.
1· Access micro sd card through a card reader. May it be built-in in a computer or an accessory that needs to be plugged-in to a computer.
2· Wait for a few seconds for the computer to read the micro sd card.
a· If it asked you to "open the folder to view files", do so then copy all contents in a new folder on your desktop. This is to make a backup copy of your files. Then, format the micro sd card with FAT32 format. Copy all files back to your micro sd card.
b· If it asked you to format the micro sd card, most likely all files are corrupted. Try to format the card for re-use. If not successful, your micro sd card is bad already and needs replacement.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
Onknown format
The SD card format only goes to 2Gb, anything after this, is an SDHC.  You are obviously trying to use this with an R4 card or similar... These will only accept micro SD, and not micro SDHC
Jun 15, 2009 | Nintendo DS Lite Console
Formatting micro sd card
i'll make a try:
i) remeber u must have kept any password to micro sd card when the card was in samsung mobile g600 and keeping password to the micro sd card will prevent it from using in other device or even in other mobile phone
ii) so you have remove the password of micro sd card by keeping the card in tsamsung mobile g600 and use the option remove password(the way u kept password or by clicking 'option' when u highlight ur memory card)
Thanking you
M. Sridhar
Dec 31, 2008 | Electronics - Others
Micro SD card
try to format it using your computer.
Connect the card with computer using a card reader
Then go to my computer right-click the micro sd-card and select format. Format it using FAT.
May 24, 2008 | LG Shine KE970 Cellular Phone
An Error from a smart phone from an SD micro card
Try
1. by putting it again into palm top
2. try Formating the memory card ( if you fail to even after format your Mcard has a internal problem )
PLEASE RATE ME ( FIXYA )..................................
May 23, 2008 | Electronics - Others
Memory card micro sd cannot format
Definitely your Micro SD Card has a problem. might be ita a virus problem.
Try to format it by your Computer not by your Phone. If you have a AntiVirus scan your Card and then try to format it.
if you are not successful in one chance Don't afraid at all, try it three or four times by removing and then inserting the Card again in the Computer........
Mar 19, 2008 | RIM BlackBerry Pearl 8100
SanDisk 2GB microSD Memory Card Logo
225 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
