I need upgrade the bios of my laptop LG E500-S.AP19B. It runs Windows Vista and I want to change my hard disc in order to have more capacity. The new hard disc is a Seagate ST9320325AS 320GB 2.5" 5400rpm 8MB SATA-2, but the old bios only recognizes 280GB. At this moment the bios is American Trends A1636IL1 V1.17. Where can I download the most recent bios? Thanks.
skatz
  • 47 Answers
SOURCE: upgrade vista home premium to bussiness edition
Upgrading from home to business edition in vista, we have to loss fewer things. Because home edition does not support for the domain functions. But its very fast and easy
here, you have a link. it may be useful for you..
http://www.microsoft.com/uk/windows/products/windowsvista/buyorupgrade/windowsanytimeupgrade/faq.mspx
Posted on Jul 23, 2008
rajeshmb
  • 38 Answers
SOURCE: SECOND HARD DRIVE NOT RECOGNIZED
Change the settings of you IDE drives in your BIOS. Set your secondary boot device to HDD1. Also make sure that your primary HDD is set to master and the secondary HDD is slave. The jumper is found at the back of the hard drive where you connect the power and IDE cables. Try this and post back as to how it went..
Posted on Nov 11, 2008
Witchunter
  • 98 Answers
SOURCE: windows does not see full size of new Hard drive
Is your disk correctly partitioned?
  1. Right-click My Computer.
  2. Click Manage.
  3. Click Disk Management.
Find your newly installed disk and see if there is any unpartitioned space on it. If there is, just create a new partition, or delete the previous one so you can create the partition which will consume full size of the disk.
Posted on Jan 15, 2009
Thunder55
  • 318 Answers
SOURCE: western digital usb hard drive doesn't work with windows vista
Windows Vista is still playing catch up with compatabilty of devices.
Makes you wonder why you left XP doesnt it? i do this for a living, and i will not touch Vista for a few years yet, while they work the bugs out.
Posted on Jan 19, 2009
SOURCE: Cannot install Windows XP,Vista on Compaq Laptop(FreeDos) V3607TU.
I have two solutions for this problem. the first one is to change the bios settings. the solution is here:  http://techrena.blogspot.com/2008/10/how-to-install-your-own-wndows-xp-in-hp.html
but for some laptops this setting is not available. so you can try another solution i.e. integrate the SATA drivers in your windows XP cd. this solution is here: http://techrena.blogspot.com/2009/01/integrate-your-own-drivers-or.html
Posted on Jan 30, 2009
Operating system not found
No, you won't get the OS to automatically install on the new drive. The OS is not stored in the BIOS chip (or a similar permanent location inside the computer). You will need an OS install disc (not an upgrade disc). Windows Vista Home Premium or Basic was the original OS on most of the Acer Aspire 4530 series. Acer appears to have drivers for the system for XP through Windows 7 to get the hardware to work. You will need to have these most of these ready before you install your OS. Put them on a flash drive or optical disc using another computer.
This computer may work with Unix as well. However, driver issues may be a factor. You can try most versions of Unix from a CD (LiveCD) to test it out.
When you get a new hard drive, install it into the laptop. Then put the OS disk in the optical drive bay. Boot to the optical drive. Follow the directions for formatting the hard drive and installing the OS. (Of course you will need a drive that doesn't have a higher capacity than the BIOS supports.) The motherboard needs to recognize the drive.
If you find a member of a Windows User Group, they may have Windows install discs available. The license number on the label of your computer will probably work as your license key. (The key for a computer like this is locked to the CPU and motherboard; unless someone upgraded the OS to Windows 7 or downgraded to XP, this should be the key you need.) Use the information on the label to obtain the correct version of Vista (the Basic install disc may not work for installing Home Premium). You also need to match the 32-bit or 64-bit install disc (and the service pack you need).
I hope this helps.
(An Acer recovery disc wouldn't help you. Most of those are completely locked to the original hardware (including hard drive) and look for the recovery partition that was on that hard drive.)
Dec 05, 2012 | Computers & Internet
Tip
Windows Installation Disc VS Windows Upgrade Disc -NOT THE SAME-
Having Trouble Booting To Your Windows Upgrade Disc?
...Upgrade discs aren't bootable discs. To repair a windows installation, you must use either a system repair disc or, better yet, a windows installation disc (genuine Retail/OEM discs are pretty much your only option to completely reinstall your windows operating system, unless you own a previous full installation disc of a previously released Windows version (such as XP or Vista), in which case you could install that windows operating system and then upgrade to a newer windows OS like windows 7. however if you ever need to reinstall windows 7, you would either need to reinstall the older windows OS, then upgrade to the newer one.
If that isn't clear, I'll sum it up....
Let's say you bought a computer, that computer had windows xp home edition. Maybe you wanted to upgrade from Windows XP/Windows Vista or Windows 7?
Well in order to switch from Windows XP/Vista to Windows 7, (or even from Windows 7 home premium- to windows7 Pro or Ultimate), then you must either:
A) Buy an upgrade disc and upgrade to the newer desired version.
B) Or, Buy a Retail Copy of the version you want to install. (keep in mind that a retail Windows 7 disc can be used to perform an upgrade rather than to competely wipe the hard disc and perform a clean install (delete partitions, reformat, and perform a new windows installation), if you so choose.
The bottom line is, you cannot Install a fresh clean copy of windows using an upgrade disc. OEM (Original Equipment Manufacturer) and Retail Windows Operation System Installation Setup Discs are "Bootable Discs". Windows Upgrade Discs are NOT bootable. (unless one where to "modify that particular disc, which is not legal).
on Jul 06, 2010 | Computers & Internet
Armada E500 PC Notebook: pxe-e61 media test failure, check cable. Turn...
This is often caused by either an incorrect setting in BIOS (usually the boot order) or a bad boot device, such as a bad hard disk.
Go into the BIOS and make sure the boot order is as follows: 1 CD-ROM; 2 Hard Disk; all the other disabled. Once you are sure of that try to boot again; if it's the same then the hard disk has died. If you have on it data that you can't lose boot from a Linux Live-CD like http://pclinuxos.com/ and recover what you can (copy them to a USB stick).
Replace the hd and reinstall.
May 03, 2010 | Computers & Internet
My laptop is LG X-NOTE e500 G.A2H2A2 .Present operating system is Window vista i want to load operating system xp service pack 2.plzzzzzzzzz suggest
You need to have a Windows XP SP2 bootable disc. Just go to BIOS and enable the boot from CD/DVD Insert the Windows XP disc It will boot with the bootable disc and you just need to follow the on screen instructions. You will need to format the HDD and do a clean installation which will result in data loss. Please make sure that you take a backup of all your important data files before changing the operating system.
For any further assistance please feel free to revert with comments.
Thank you for choosing Fixya
Apr 19, 2010 | LG E500 Express Dual Series Notebook PC
How to reformat back to windows vista ?
You need a windows Vista disc. Insert the disc and follow the prompts. I would format the hard drive instead of upgrading do a new install. The best way would be to go into your bios and make sure the boot device order has the cd-rom booting before the hard drive. Then put the disc in and start the computer, when it says press any key to boot from cd hit any key and let it load and then follow the prompts to install.
Nov 27, 2009 | NEC Versa VX Notebook
Why my acer e500 cannot install 64 bit window 7 it say no driver when need to choose hard disk to install
you need to install Uli sata drivers in order for your motherboard to recognize the harddrive and cd drive.
download the drivers here: http://www.soft32.com/download_184082.html
and put them on a cd or memory card, when the system prompts you that you have no harddrive, you can load the drivers from a memory card or cd however if you use a cd you will face other issues. then you will be able to install windows 7 ;)
I did it on my acer e500 and it runs good.
I didn't install the 64 bits version though but the 32 bits.
for all the people saying that his pc is too old: if the pc can run under vista, it runs better under windows 7
Nov 05, 2009 | Acer Aspire E500 PC Desktop
I have LG E500 and I want to instal XP. I cant make changes in bios like boot sequence, so I cant boot from cd and therefor I cant instal XP. What should I do?
I don't recommend downgrading your laptop from Vista to XP but...
According to manual, pressing F2 during boot sequence takes you to BIOS and then you can change
the order of the boot sequence in the BIOS. From the manual:
"...set passwords, change the booting order, and add new peripheral devices to the machine."
If you can't find boot sequence in BIOS setup, talk to a support rep online:
http://ca.lgservice.com/index_b2c.jsp
You may need to use a different server if not in CA.
Jul 08, 2009 | LG Computers & Internet
Can't install new OS
you need to install directly from the vista disc when the computer is powered on, put the disk in and it should ask you to press any button to start from cd..
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter boot menu, it will very likely be button F12 or similiar, it should say on the screen when you power on.
if it doesnt, then you need to go into the bios and change the boot order so that the computer starts from the CD first. the computer should say what button to press to enter bios or cmos or setup when its turned on
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
heres some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
ones you get into the vista setup you can empty the hard drive, getting rid of windows xp and then install windows vista over it.
Let me know how that goes,
Thanks,
Ekse
Jun 03, 2009 | Toshiba Portege R100 Notebook
Upgrade to vista ultimate
If you have a full version of Windows Vista Ultimate, you can just insert the DVD when you logged in your laptop and go to Computer(My Computer) and lauch the installer for Windows on DVD icon (Double Click DVD icon). It will give you the main window for installing Windows and along the way, you should find an Upgrade option. Click that one and it will install windows Ultimate on your system. It Will not format the laptop but installer will just add system files and features to the laptop to run Vista Ultimate.
**If you haven't purhcase a Windows Vista Ultimate Disc, check this link to to purchase just an upgrade Disc (only) of Vista Ultimate.
http://www.microsoft.com/windows/windows-vista/get/anytime-upgrade-overview.aspx
An upgrade disc will also not format the laptop instead it will just install additional features and add additional files on the system to run Windows Vista Ultimate
Oct 28, 2008 | Sony VAIO Digital Studio VGN-AR320E...
Computers & Internet Logo
327 people viewed this question
David Payne
David Payne
