Question about Avanti DER24CSS-1 Electric Kitchen Range
I have an Avanti 20 inch gas range and the oven will not stay lit, what can I do? I live in Canada and there are no parts here.
5 Suggested Answers
solveditnow
  • 39 Answers
SOURCE: Avanti DG241BS - oven will not stay on
There has to be a protection system in the burner assembly to cut the supply of gas to the burner if it does not light. For the case of an oven the supply must be cut off immediately if the burner and its pilot go out. For that gas control system to work the burner control must "recognize" with a sensor when the burner is lit and when it is not. Pushing the knob "in" momentarily on this model bypasses the protection system momentarily to allow a burner to be ignited in the first place. If releasing the knob extinguishes the flame the control system is not "seeing" the flame. I tried to find some detail info on you particular ignition system but to no avail so all I can offer is a general approach to these kinds of problems . You need to find and clean or replace the sensor used to detect a flame. It could be an optical one (doubt that) or a temperature flame sensor, a thermocouple sensor, or some other kind I haven't thought of. Fixing this problem involves first determining what kind of sensor it uses. A copy of a service manual for this model can help you determine that. Try to clean the flame detector, and if that doesn't work you have to replace it or the gas control assembly it is a part of. If you have a spark ignition and its not sparking when it should first clean it --carefully--. Spilled food can short them out. Unplug the range before doing this. The owners manual shows it to be under the top burners which can be removed for cleaning this.
Posted on Jan 03, 2009
SOURCE: Avanti DG 241 BS gas range oven burner goes out and wwill not rel
You need to order parts from AVANTI.
http://www.avantiproducts.com/
Very disappointing customer service.
I have been waiting 6 weeks for a new thermostat. It will not
arrive from China until June -- I was originally told it would come in April. All AVANTI parts are from China and AVANTI in Florida is the
only dealer. I will never buy AVANTI again.
Posted on May 05, 2009
Maytag317
  • 1136 Answers
SOURCE: how do i adjust oven pilot light on vulcan range
hi, there is an orfice for the oven located on the gas valve. If you are using LP gas, the orfice should be turn down all the way (counter clockwise). If you are using natural gas, the orfice should be turned out about 2-1/2 turns. Was this oven set up to be used with one gas and noe is being used with another? If so, you will need to do more then adjust orfices. Please let me know if I can assist you further.
Thaks
Vic
Posted on May 13, 2009
blueextc3221
  • 15935 Answers
SOURCE: Frigidaire gas range error message....F1
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
#$%Tf
Posted on Oct 01, 2010
Can I replace the rubber seals inside the oven?
sorry never saw any rubber parts in any ovens .call a local repairman .
Feb 11, 2016 | Avanti Elite Series DG201BS 20"...
Oven does not stay lit
Probably something that should be checked by 'GAS SAFE' QUALIFIED ENGINEER. May be that the safety shut off is faulty? I believe that all gas work must, by law, be carried out by qualified personnel now, at least in the UK? could be wrong.
Jun 12, 2015 | Avanti DG200W Gas Range - DG200W
Oven broiler wont stay lit
sounds like the valve (at the knob) is bad.
Jan 31, 2013 | Avanti G20AW-1 Gas Kitchen Range
The dial on my Avanti 24" oven is hard to determine which way to turn. When I hear the clicking sound, as the burners do, next I hear the lighting, whoom. Shall I start it at a low temp and then in a few...
It sounds like you are having an excesive buildup of gas pre-ignition. You should hear no "Whooom" sound.
The ignition assemble likely needs to be cleaned of rust, dirt, grease etc. That is the typical cause if improper ignition, gas buildup pre-ignition etc.
The problem of not staying lit is caused by either the flame sensor not sensing flame, (which may need to be cleaned or replaced.) or that the flame is simply being blown out by the air movement as a result of the sudden combustion of excessive gas build up.
So, to summarize, the ignition and burner assemblies need to be cleaned, and the flame sensor may need to be replaced.
Oct 12, 2009 | Avanti DG241BS Stainless Steel Gas Kitchen...
Feb 19, 2009 | Avanti DER24CSS-1 Electric Kitchen Range
HI, i am in need of a replacement knob for a avanti ss stove-20 inch model #DG201BS. the part # is 2183442323
hi!!!! call 1-800-323-5029 or 1-877-359-6409 for service tech questions and parts.Good luck..128bc2f.jpg
Jan 27, 2009 | Avanti DG-20CSS-1 Gas Kitchen Range
Oven will not stay lit
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
hklhlk
Jan 03, 2009 | Avanti DG241BS Stainless Steel Gas Kitchen...
Aug 07, 2007 | Avanti DG241BS Stainless Steel Gas Kitchen...
Lighting the oven
I have similar problems with several 20-inch Avanti ranges. Solution(s); Get a new range, different brand. Cool the range between lightings.
Dec 21, 2006 | Avanti DG241BS Stainless Steel Gas Kitchen...
Avanti DER24CSS-1 Electric Kitchen Range Logo
Top Avanti Kitchen Ranges Experts
Craig Butler
Craig Butler
ray gallant
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
