Question about Plustek OpticBook 3600 Plus Flatbed Scanner
My scanner is only scanning black / blank - Plustek OpticBook 3600 Plus Flatbed Scanner
I got a completely black image after scanning, what is the solution? I am using hp scanjet 3400c.
I got the same problem "showing blank page"
It will be the hardware problem or scanning bulb may not work.
help..
Sep 19, 2011 | HP Scanjet 3400c Flatbed Scanner
When I use the automatic feed a blank line appears in t
BLANK or BLACK?, if it's Black, clean the SCANNER GLASS.
Aug 05, 2009 | HP LaserJet 4345mfp Printer
Scanner is recognized but document scanned is a
Try and scan something again, but with the lid up just a little. I am betting that the light for the scanner is not working. Call Canon to find out if your unit is still under Warrany if that is the case. They will be help you fix it, or replace the scanner, depending on the Manufacture's warranty policy.
Aug 02, 2009 | Canon PIXMA MP180 All-In-One InkJet...
Can only scan simplex or duplex
The scanner can scan in either simplex or duplex mode only. If blank page is scanned, then it will appear BLANK, else someone would say, my scanner is not scanning properly! Remove balnk pages using software or sort on file size and delete the small sized files. Take care to ensure they are really blank.
S. Mohan, India
Nov 20, 2008 | Fujitsu fi-5110C ScanMaker Scanner
"Skip Blank Page" but still inserts one
I have two of these scanners the only way that i have found round this is to scan the pages duplex then remove the unwanted afterwards!
Aug 26, 2008 | Canon DR-9080C Path-Through Scanner
Only scans and copies black blank
please check if the exposure lamp. or the ligth that runs when scanning works if it does not turn on change that parts
Jun 16, 2008 | HP PSC 1510 All-In-One InkJet Printer
Blank Scan from HP Scanjet 5590 Flatbed Auto Feed
Scanning is possible in 'Text' mode and 'Picture' Mode. In text mode, which is simple 'Black & White", this can happen, particulalrly if the text is in color. Either you increase the contrast settings or scan the document in Grey/color and convert it to B&W using the software. By this you need not check if there is output!. ( I am assuming that otherwise the scanner is performing okay). File size in B&W is very small as compared to Grey/color.
S. Mohan
Apr 04, 2008 | HP Scanjet 5590 Flatbed Scanner
Plustek OpticBook 3600 Plus Flatbed Scanner Logo
66 people viewed this question
Top Plustek Office Equipment & Supplies Experts
Gareth Cockram
Gareth Cockram
Jax Planet
Jax Planet
Are you a Plustek Office Equipment and Supply Expert? Answer questions, earn points and help others
