Question about HP w1907 LCD Monitor
HP W1907V FLASHING BLACK SCREEN My A6504UK is 2 years old, has integrated on-board graphics Nvidia GeForce 6150 SE nForce 430 and I am using the HP w1907v LCD widescreen monitor. The monitor has recently been flashing to a black screen and then back to the Windows screen showing whatever I have been doing previously. This flashing can last for about 10 seconds and is intermittent, there is absolutely no pattern or warning to it happening. There appears to be no breakdown in the quality of the screen display but I have been having trouble installing drivers from Nvidia for the native resolution of 1440 x 900. When the driver is installed, it doesn't always show the native resolution in the list of choices. Pressing the Auto/Select button on the monitor makes no difference either. I am running Windows 7 Ultimate and this is a full fresh install after the PC has been returned to Vista Factory Settings. Can anyone give me a clue as to whether it's the integrated graphics (most likely) or the monitor? Can I install a separate graphics card and/or disable the on-board graphics easily? Any help or guidance would be much appreciated!!!
costin
  • 12 Answers
SOURCE: Setting up dual monitors with NVIDIA 7300 GS Graphics Adapter
so...
your computer don't recognize your nvidia graphic card in PCI Express slot.
you are runing now with computer's integrated graphic card?
if so then you won't have dualview option. in this case it looks for me like you've installed in the wrong way your graphic card.
your NV GeForce 7300 GS has 2 video output?
if yes then you should have the option for 2 monitors on nVIDIA control panel (i have check my nVIDIA GeForce 7600gt and in my case this option is present but is enabled only if i connect the second monitor, so try do so)
you have installed the latest nVIDIA drivers from the official website? http://www.nvidia.com/Download/index.aspx?lang=en-us
check if your video card is corect installed start/run type in " devmgmt.msc ". it will open device manager and under the display adapter tab you should see what video card you use now.
Posted on Feb 24, 2009
  • 90 Answers
SOURCE: My HP 9311 Tx does not give display on its LCD screen
after loading Operating system just press F5 and wait for 2-3 seconds. if display not appear try 1-2 times. it will come. plz replt if ur problem solved
Posted on Apr 10, 2009
tanusha
  • 7 Answers
SOURCE: HP DV4000 Widescreen desktop image does not fill screen
go on u deksto click with right-properties-display setings and change the resolution.
Posted on Jul 01, 2009
  • 156 Answers
SOURCE: Monitor says No input signal and going to sleep.
Try cleaning your RAM it should be the issue mostly 80%
You can check by rremoving the VGA cable if the system shows no signal mostly monitor should be fine
Posted on Nov 30, 2009
noone
  • 105 Answers
SOURCE: I've got a HP w1907v
If this monitor is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Posted on Aug 21, 2010
Compatible Gateway Motherboard
BIOSTAR MCP6P M2+ 6.X AM3/AM2+/AM2 NVIDIA GeForce 6150 / nForce 430 Micro ATX AMD Motherboard
Jun 09, 2013 | Gateway GT5220 PC Desktop
Does anyone know where to get the schematic for the dv6550us motherboard?
The closest I come to an HP Pavilion dv6550us, on HP Support, or on the internet is;
Pavilion dv6550tx
Next inline is Pavilion dv6560us,
then Pavilion dv6450us
Not available to the public.
Do have a Block Diagram,
Models that use an AMD processor,
http://www.laptops-schematics.com/wp-content/uploads/2011/07/HP-Pavilion-DV9000-AMD-Notebook-Laptop-Quanta-AT8-Schematic.jpg
1) Socket S1 processor socket,
http://en.wikipedia.org/wiki/Socket_S1
2) Motherboard chipset is an Nvidia MCP51M
Which is the mobile version of Nvidia GeForce Go 6100, or Go 6150;
and Nvidia nForce 430,
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#GeForce_Go_6_.28Go_6xxx.29_Series
Graphics chipset,
http://www.ebay.com/itm/NEW-Original-nVIDIA-Geforce-NF-G6150-N-A2-BGA-ic-chip-north-bridge-Chipset-/271010886762?pt=LH_DefaultDomain_0&hash=item3f1981f46a
Conexant CX20549-12 audio chipset
Realtek RTL8101C Ethernet chipset
Models that use an Intel processor,
http://www.laptops-schematics.com/wp-content/uploads/2011/07/HP-Pavilion-DV6700-Intel-Notebook-Laptop-Quanta-AT3-Schematic.jpg
Uses the Socket P processor socket,
http://en.wikipedia.org/wiki/Socket_P
Both use the Fairchild Semiconductor Industries - FDS6679 - Power MOSFET, and Alpha & Omega Semiconductor LTD - AO4407 - Power MOSFET, in the DC - DC circuit; as far as I know.
Both are Obsolete, but there are cross match examples out there.
(FDS6679AZ for FDS6679, for one)
Indicates HP Pavilion dv9000 series, and AMD; but also matches up to the Pavilion dv6500 series,
http://www.scribd.com/doc/89356925/HP-DV9000
Scroll down. (Zoom In icon { + } at TOP to increase view size,
Zoom Out icon { - } to decrease view size )
Asking for a Schematic, do I assume you are attempting
Board Level Component replacement?
What SMD/SMT IC component are you trying to replace?
(Surface Mount Device/Surface Mount Technology. Integrated Circuit)
Motherboard chipset info, and processor socket info, for processor upgrade.
Same thing for Ram Memory upgrade.
It does use DDR2 Sdram (SO-DIMM), and at 667MegaHertz, to my knowledge.
What usually goes bad on the HP Pavilion dv2000 series, Pavilion dv6000 series, and Pavilion dv9000 series of Notebook PC's?
The cooling for the graphics chipset is inadequate, therefore the graphics chipset overheats, and partially melts the Solder Joints in the BGA surface mount.
Resulting in no graphics.
Power MOSFET's in DC - DC circuit go bad.
Continued in Comment
Apr 07, 2013 | HP Pavilion Computers & Internet
Display adapter corrupted nvidia geforce 7600 GT updates don't help at boot up display screen faded colour with many colums of !!!!, etc. and will only boot to welcome screen in safe mode then restart...
a 12 year old PC !!!
powers on, yes
all fans work, not stated and is 1st ,overheated is bad.
PSU fan, CPU fan and if present GPU fan all working perfectly
and heat sinks not packed lint as ALL DO 12 years old and never serviced. timely.
NO OS stated, you posted an old m7650n , PC. desktop
then fail to say its XP the dead OS and virus magnet?
no screen stated, is the screen old to, Monitor with old Dead
or near dead CCFL tubes (blackground)
what we do on all relics this old
1: test the monitor on a good PC?
or
2; test the PC on know good Monitor.?
easy no/?? simple tests, 1/2 the problem solved.
all that above from word "FADES" (wish could see it and watch)
lets say (i toss a coin) that the monitor is good.
PC bad.
PC needs a good power supply next.
what VGA jack are you using ,most desktop ,or many
have 2 jacks, one is main, board video
other is add-in board PCI card video, which one are you using
i cant see it.
ever see the PC run ok for a week? or just found this at garage sale. for $5?
matters big time as others tend to mess up parts inside guessing.
One error is not using the upgraded video card power aux jack
for 2 reasons, dont understand it, or forgot or the PSU doesnt
have that extra ATX2 wired power cable, rendering the aux vga card useless...... see how easy it is to mess up video.just that.
is the MOBO RTC coin cell good, over 2.9vdc with a meter?
if not get rid if that first. never seen one this old good , me.
then get the BIOS screens working first, forget the OS. for now.
then we can work that.. BIOS screens HOLD good.
no fade in BIOS??????
still has PS/2 keyboard, if yes, HP keyboard? still?
try another keyboard, in cases keys are stuck? !!!!!!!!!!!!!!!
if the screen does not fade in bios, then say that ,
as that is a whole other set of problems and causes.
facts: HP Pavilion Media Center TV m7650n Desktop PC this PC does have onboard mobo integrated graphic. runs the
(NARRA2-GL8E)
as seen here
https://support.hp.com/us-en/document/c01080282/
that GPU there is.
Integrated graphics using nVidia GeForce 6150SE
the page states
*Integrated video is not available if a graphics card is installed.
  • Integrated graphics using nVidia GeForce 6150SE
  • Up to 256MB (with 512MB or more PC memory)
  • Also supports PCI Express x16 graphics cards*
that 2nd bullet means main ram must be good. try swapping ram
if 2 DDR sticks try each one at a time, in bank 0?
if using express video now is the time to say. thanks.
Dec 30, 2017 | HP Pavilion m7650n (RF254AA) PC Desktop
Computer crashes and vista says it is NVIDA Geforce
If I were you I'd wait for the next driver update. ALso, you could try sending Nvidia a complaint about this, so they know they've got to fix it.
I hope this helps,
Yannick
May 29, 2009 | Dell Computers & Internet
Need a better graphics card than the nvidia geforce 6150 se nforce 430 or which graphics cards are compatible with it?
hi,
you may try this geforce 8800GTX. You may need to check also if this geforce video card is compatible with your motherboard.
By the way, may i know what type of system you have?
Thanks
Dec 07, 2008 | Computers & Internet
I need drivers of windows xp for hp pavilion a6110in.
Go to the following website to get the same
http://h10025.www1.hp.com/ewfrf/wc/product?product=3542971&lc=en&cc=ru&dlc=ru&lang=ru&cc=ru
note :This product from HP has been for Microsoft windows vista 32 bit and 64 bit operating system only. You may not be able to find all drivers for the same as they have not been written by the product manufacturer.
Thanks
Proton
Nov 29, 2008 | Microsoft Windows XP Professional With...
Having problem with new games
What is the Name and model number of your motherboard
The nforce 430 is an older chipset model and may not use the full capacity of the Phenom processor ...some boards won't even boot and there are Bios updates available for others ...etc
The onboard graphics (geforce 6150 se) is negated by the 8800 GTX ...good card......the problem isn't your video card
Your also running PC5300 ,,667mhz ram ....if board is capable of PC6400 ...800mhz ....there could be another speedup
The bottlenck seems to be with the board and possibly Ram
(Again MB model and name)
Also make sure you have all the latest drivers for Vcards ...chipsets BIOS etc......
May 27, 2008 | HP Pavilion Media Center TV Desktop with...
Will Princeton monitor VL1918 support NVIDIA GeForce 6150 SE
Hi Alvie
I Just checked the specs on both the card and the monitor. It should work no problem. If for some reason you notice some lag or flicker in the monitor, go to this page and download the updated ForceWare graphics drivers.
http://www.nvidia.com/object/winxp_169.21_whql.html
Mar 27, 2008 | Princeton Digital VL1918 Monitor
HP w1907 LCD Monitor Logo
141 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
