Question about AO Smith 1 1/2 HP 115/230V 56C Replacement Motor
My ao smith c48c53a06 jet pump trips the circuit breaker. i replaced the capacitor. now it hums then trips the breaker. could it be the thermal switch. i am having touble finidng a number for it (brt45abm)
3 Suggested Answers
  • 89 Answers
SOURCE: trips breaker, windings not open, no continuity from windings to frame. startsfor split second then trips breaker. Breaker is ok
ASSUMING THIS IS SINGLE PHASE HAVE YOU CHECKED THE CAPACITORS. START CAPACITOR COULD BE BAD OR BURNT LEAD. HAVE YOU MADE SURE THE PUMP IS NOT LOCKING UP. POINTS IN THE PRESSURE SWITCH LOOK GOOD. HOPE THIS HELPS, JODY
Posted on Apr 27, 2009
  • 25 Answers
SOURCE: pump just hums but wont start
Sounds like its frozen and causing a very heavy load on your circuit. If the motor gets hot within seconds, its shot and needs replacing. Have you attempted to turn the motor over by hand ?
Posted on Jun 22, 2009
My A.O. smith pool pump doesnt seem to be getting electricity. It makes no noise at all when you turn it on. We had a storm last night I don't know if it tripped some sort of switch. I have checked the...
VOLT METER TO THE 2 LINES 230 OR SO ? THE MOTOR MAY BE BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY..USE YOUR ZIP CODE ... GOOD LUCK AND VOTE FOR ME...JAY
May 31, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
How to manually reset an AO Smith 2 hp motor?
If you did not press a reset ( and even if you did) the motor is damaged and that is causing the circuit breaker to trip. You need to have the motor inspected to see if the damage is repairable or if you need a new motor. A local electric motor repair shop should be able to take care of that for you. The thermal overload has reset itself if after cooling down the motor is trying to start but trips the breaker.
To be certain it is the motor, disconnect the line leads and be sure they are insulated from ground and one another. Turn the breaker back on. It should stay closed which confirms it is the motor tripping it when connected.
If for some reason the breaker still trips, there is a problem with the electrical circuit feeding the pump.
Jul 26, 2009 | AO Smith A O Smith Motors A O Smith 2hp...
Pump just hums but wont start
Jun 22, 2009 | AO Smith SQ1202 Pool Pump Motor
My pump will not come on
Does it hum at all or make any noise? If not, look for a tripped GFI or circuit breaker. If it makes noise at all, it is getting power and likely needs to be replaced.
For a quote on a new one, get the nameplate information off the motor and contact us at www.arrowmotor.net
Jun 18, 2009 | Smith AO Pool Pump Motor
Overheats and trips off
internal thermal over loads in motor are working properly! how old is the motor? double check all vavles on the intake and discharge line to make sure that they are open? sounds like the pump is pushing against what is known as dead head pressure. obstruction in discharge line! if valves are ok you can take the jet covers off (the piece that helps direct flow of water) which will relieve some of the pressure should allow it to run without tripping tgermal overloads. if none of this works replace motor!!
May 28, 2009 | Smith AO Pool Pump Motor
Where can I find a replace thermal overload protector?
http://www.mypool.com/Products/Catalog/mo.asp for the capacitor.
See if there is another part number for that breaker (CET51 ABM).
Feb 28, 2009 | A.O. Smith SQ1102 Pool Pump Motor
Motor hums when turned on
Try this link for help. They suggest emailing before calling:
http://www.mypool.com/introduction.htm
Feb 24, 2009 | A.O. Smith SQ1102 Pool Pump Motor
AO Smith 1 1/2 HP 115/230V 56C Replacement Motor Logo
570 people viewed this question
Top AO Smith Plumbing Experts
Lawrence Oravetz
Boyet Soriano
Boyet Soriano
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
