Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I am replacing the transaxle on my Craftsman Riding mower model #917.270750. I need to remove the drive pulley from on top the old transaxle to install it on new transaxle. I removed retainer ring but pulley won't come off.
  • Eldon Allen Sep 29, 2010
    There is a key in a slot down the side of the shaft on the transaxle does itahve to be removed before pulley is removed?
  • 12,061 Answers
Hi, well these can be real hard to remove, there are two ways to do this, with heat, form an oxy torch, or blow torch, or use of penetrating oil .or Use Automatic Transmission Fluid or Acetone to loosen it (Also make sure there are no "Keys" that need to be removed)
Or use a Pully/Gear Puller. See below.
http://cwguy.com/?p=2396
Posted on Sep 29, 2010
Clutch pulley slippage
you are out of Alignment and need to check the Bearings on your Pulley. They go bad due to Water coming down on it through your deck
Oct 02, 2014 | Craftsman Garden
Drive belt diagram model 917-276051
the closest thing to a "drive" belt diagram would be in the owners manual http://www.manualslib.com/manual/487688/Craftsman-917-276051.html?page=38#manual
the horizontal (front) end would be to the pulley at the engine that the deck belt(s) are not attached to. There is a set of mid pulleys where the direction is changed from horizontal to vertical for attachment to the transaxle.
Jul 01, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Automatic transsmission does not work
with your eyes only ck that pulley on top of rear transaxle is turning with engine at idle , if not your drive belt is stretched or broken
Nov 11, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How do I get the lever to shift to lift the mower so that I can replace the belt? 19hp, 42", year unknown craftsman turbo
If it is the drive belt do the following place your mower on a level surface set parking brake, remove mower deck, remove belt from stationary idler and clutch idler, pull belt slack towards the rear of tractor , then remove belt upwards from transaxle pulley by deflecting the belt keepers, then pull the belt towards the front of mower and remove downwards from engine pulley Install new belt in reverse procedure
Jan 22, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Steps needed to change transaxle belt
lift the front of the tractor up at least 3 feet and lower the mow deck to give you clearance. push the clutch pedal and lock it down to release belt tension. remove the mower belt from the engine pulley only. remove the trans belt from the idlers about midway back then from the trans pulley & finally from the engine pulley. put the new belt around the engine shaft above the mower drive pulley but not on the drive pulley then around the trans pulley. now you can put it on the drive pulley and finally on the idlers. make sure you have it under all the various keepers or the belt will shred in like 10 minutes. release the clutch pedal & check the belt again to ensure it is in the correct place. replace the mower drive belt & ensure that didn't come off other pulleys in the process. lower the front of the tractor and test
Oct 14, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I'm having trouble replaceing the motion drive belt on my LT1000 lawn tractor. The mowing deck is off, the old drive belt is off. I can't get the belt around the transaxle pully. Any suggestions?
Often there is a keeper on the back of the pulley, and the belt must go inside the keeper. Get an inspection mirror up in there to look if necessary. Start by putting the belt on the transaxle pulley, then on the PTO pulley, then on the idler, last have someone sit on the mower and depress the clutch pedal while you put the belt over that pulley.
Sep 26, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman riding mower wont accelerate
Have you checked the condition of the belt which transfers power from the engine to the transaxle? It could have slipped off a pulley; or, even worse, it could have broken. This belt is often difficult to access without removing the mower deck.
If the belt is in place, and you still get no movement, you likely have a transaxle problem.
Apr 20, 2010 | Garden
How to remove the drive pulley, and install a new Woodruff Key?
Wayne Train Hi Bobbyak, if you still need to know, there is no key. It is a D shaped shaft, the pulley has the D cutout built in. It is a tight fit to pull off, but it will come off with some wiggling effort. There is just enough room. Remove the belt. Mark the side facing the trans for when you refit. Don't give up and don't drop the transaxle. I just didn't catch the reason you wanted to remove the pulley.
Sep 26, 2009 | Craftsman Garden
What is causing my drive belt to slip off the transaxle pulley on my 2001 craftsman 42'' 15.5 hp mower?
The belt has worn out. You need to replace it. They can look fine, but they stretch over time.
Best regards from someone who's been there,
--W/D--
Aug 15, 2009 | Garden
Craftsman model 917.271814 will not go forward or reverse. Heard a "click" and mower stopped moving; engine and blade still running.
Check the drive belt that runs back to the transaxle,it sounds like it broke.If the belt is in the pulley check to see if the transaxle pulley is turning when the clutch is out.Also make sure both wheel axle keys are in the rear wheels.If all this checks out the transaxle may have broke,look underneath to see if it is broken there.
Aug 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
91 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
