Question about Philips HTS3410D/37 700W DVD Home Theater System System
My HTS3410D DVD Home theater system just went dead the standby button on the left front blinks but nothing else works I can't even open the DVD drawer I've unpluged unit and let set for servel hrs repluged same thing
  • pauldigerola Sep 30, 2010
    Thanks Tim not what I wanted to hear. The unite is four years old. Bought is at Home Depot with their credit card. Is it cost effictive to have it repair? Thank you Paul
    President:
  • 2,777 Answers
That's not good at all, this indicates major hardware failure, probably the power supply of the receiver / dvd. How old is this unit? Did you happen to buy it using a major credit card like American Express?
Thanks
Tim
Posted on Sep 29, 2010
  • Tim Grayson
    Tim Grayson Sep 30, 2010
    I am trying to find a little bit more info on this particular unit before saying if it's worth repairing, but chances are it is not. The only way it may be worth repairing is if the speakers that came with it are the type that actually "plug" into the back of the system, as opposed to having wires that just simply connect in. If it is the wired type (which I hope it is) and doesn't have some proprietary Philips plug in system, you can just use it with any regular receiver and dvd player, which would be much less expensive than trying to repair this unit, and will actually work better, as most standard (even low end, used ones from ebay for example) receivers have much more power and range than this unit has.
    Thanks so much, so sorry about the bad news :(
    Tim
I have a HTS3410D Home Theater system. I cannot
a blinking or pulsing power light usualy means a problem with the power supply. Check for burned resistors or swallen capacitors on the power board it will be the one with the one with the main power running to it.
Nov 17, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
HTS3410D power light keeps blinking
This seems to be a common problem with this model. It seems as though there are about FIVE electrolytic capacitors in the power supply PC board that have failed or dried out.
They can be replaced by someone that has the dexterity, knowledge and tools to de-solder and re-solder PC board components. Otherwise you may seek a local electronic technician. The parts cost about $5.00. Labor may run you $30 or more.
Hope this helps. I also am looking for a remote for mine, if someone has a dead HTS-3410D.
Thanks!
Jun 30, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
How do I get my house dvd tray open it stuck and not dvd or cd is in it.
First attempt is to turn off the DVD Player, unplug the DVD player power cord from the electric supply, wait about 5 minutes, plug back the power cord, turn on the DVD player, press the open/close button.
If this does not work, the DVD player cover will have to be removed and the tray manually operated to determine the cause for it not being opened electronically. This might require the services of a technician.
Please rate this solution - Thanks
Feb 28, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Philips HTS3410D home theatre system. DVD is stuck inside - won't play, won't open. any ideas?
Power off the system
Unplug the power cord
Wait 5 minutes
Plug back the power cord
Power up the system
Press the open/close button
Load a DVD and play
If the tray still will not open, the cover will have to be removed and manually operated. You may have to have a technician look at the unit.
Dec 27, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
STANDBY LIGHT KEEPS BLINKING
Unplug the power cord, wait for 5 minutes, plug the power cord back in and try to operate the unit.
If this does not work, you will have to get a technician to look at it for you.
Please rate this solution - THANKS
Dec 26, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
The power button on my Philips DVD player blinks.
The Front PCB might be damaged. Check the front PCB
Jan 10, 2008 | Philips LX3000D System
194 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
