Question about Rheem RTG-53PVP Indoor Liquid Propane Tankless Water Heater for 1-2 Bathroo
Rheem rtg-53pvp ignites then goes off .Flashes C2 11. Checked for proper ground and gas supply. really need a repair manual.
SOURCE: tankless water heater error code 11
I was having the same problem untill I reallized it was my venting system. Test the water heater with no vent on top. Disconnect the vent pipe from the water heater and try turning on the hot water. the water heater needs a special adapter to vent the direct vent water heater. One other thing you can check is the gas pressure in your home. You have to have between 7 and 8 WC (water Column) for the tankless water heaters. You can call your gas supplier to find out what you have.
Posted on Jul 04, 2009
mrhotandcold
  • 248 Answers
SOURCE: Rheem RTG-74PVN-1 Water heats for abot 2 minutes
overheat stat or fan, on fan check for small pinhole in rubber tube best of luck
Posted on Oct 29, 2009
  • 244 Answers
SOURCE: Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
Posted on Nov 01, 2009
peterrance19
  • 399 Answers
SOURCE: Problem for Rheem Paloma PTG-74PVN / RTG-74PVN
hi pete here ill try and help this could be 2 things check the sensor on the unit the outher one is a qustion has the gas company changed your meter latley and turned off you gas and not come back to light your poilet because this code also means not enough gas or wrong type of gas
Posted on Nov 18, 2009
SOURCE: replaced mother board due to
http://www.palomatankless.com/owners/homeowner+trouble.lasso#28-11
The Controller displays error code "11."
Gas is inadequate. Open the Gas Shutoff Valve all the way.
Posted on Feb 25, 2011
Rheem rtg-66dv error code 12
Troubleshoot and error codes following link:
http://waterheatertimer.org/pdf/RTG-error-codes-3.pdf
Not getting gas, low gas pressure, air in gas line, igniter not aligned with burner, wires disconnected, unit not grounded ...
Nov 10, 2017 | Rheem RTG-66DVN Direct Vent Natural Gas
I have a paloma tankless water heater ptg-74pvn-2 that gives me the error code c2 11. looks like everybody has a problem with this. what can i do to fix it, surely enough they should have some easy way of...
Easy solutions for C2 11:
Rheem is one of the big manufacturers but has disproportionate number of questions at fixya since they try to funnel problems through service techs instead of posting do-it-yourself service bulletins. People want do-it-yourself service bulletins, as appear on the Bosch site for their products. Easy-fix in this sense would be to buy Bosch, and read service manuals aforehand to see if you have testing skills and equipment to maintain and repair tankless water heater.
Easy solution for C2 11 Rheem problem is don't install gas tankless water heater, since all costs are energy and tankless are expensive to install, maintain, repair, and replace for the mere savings of 1-8 per month.
Third solution for C2 11 no-ignition is to clean burner and combustion parts, and sand carbon off the igniter, on a yearly basis, as recommended in manual.
Fourth solution is to call a qualified service technician each year as recommended in manual, and have technician fix problem and catch water heater up on recommended service. This person can check other causes for C2 11 such as bad igniter, bad gas solenoid, low gas pressure, air in gas line, improper unit grounding, bad wiring, bad sensors, etc.
This check-up can also make sure vent drain is working properly and that acidic water vapor and other resulting combustion by-product are going into the household drain and eventually out to sea instead of dripping down into the heat exchanger causing rust and premature failure of exchanger.
Next solution will not solve C2 11 error code, but can address other error codes before they happen: Maintain water heater on yearly and monthly basis as recommended in manual. This is good for folks who like projects.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
More resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
1-800-432-8373
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Sep 20, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have a Rheem rtg-74pvn-2 tankless water heater installed in 03/09. Intermittently the hot water stops when only the hot water tap is on. No error codes appear. Bill W.
Before calling service technician, open following links for resources including Rheem chat and possible manual:
http://waterheatertimer.org/pdf/No-Error-Code.pdf
http://waterheatertimer.org/Crossover.html
Typical tankless manual says to have yearly service which includes checking household plumbing, gas supply, vent and condensation, check sensors for loose wires, clean and inspect burner parts and ignition factors etc.
Aug 04, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Code 11
Before calling service technician, open following links for Rheem troubleshooting resources including error codes.
Error codes are considered start-point for troubleshooting.
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Error 11 is no ignition.
This problem can probably be solved by routine yearly maintenance shown in instruction manual which recommends: Yearly cleaning, adjustment and inspection of burner and combustion parts.
The yearly maintenance would check incoming gas supply, venting, wiring and grounding, and burner and ignition parts.
All gas water heaters today require same maintenance: tankless require yearly, and tank-type require periodic (1-3 years)
Jul 03, 2011 | Rheem Tankless Hot Water Heater...
No hot water. Constant beeping at the tank. Tempature gauge flashing 11.
Before calling service technician, open following links for Rheem troubleshoot resources including Rheem chat and typical service manual and typical product manual.
Error codes are start place for troubleshooting:
Error 11 is 'gas is inadequate' or 'ignition failure'
Open gas valve so handle is parallel with gas line.
Bleed air from gas lines.
Check that appliance is grounded.
Check igniter wires and harness for damage.
Check that vertical vent length does not exceed limit.
Other causes: Gas inlet solenoid valve, bad igniter, solenoid valve, flame rod.
Jun 14, 2011 | Rheem Tankless Hot Water Heater...
C2 11 code
Before calling service technician, open following link for Rheem error codes and troubleshooting resources:
Error code C2 11 is 'no ignition'
Ensure you have gas to the appliance.
Ensure gas type and pressure are correct.
Bleed all air from gas lines.
Ensure gas line, meter, and regulator are sized properly.
Ensure appliance is properly grounded.
Check gas solenoid valves for open or short circuits.
Ensure igniter is operational.
Check igniter wiring harness for damage.
There is no service bulletin covering how to perform these actions.
Rheem will ask that you call qualified service technician, who can give you tips and tricks for keeping the unit working, including opportunity for yearly service that will eliminate the expected $1-8 monthly savings from owning tankless.
Read manual for yearly maintenance needed to keep unit working at prime efficiency.
Apr 18, 2011 | Rheem Tankless Hot Water Heater...
My paloma tankless gas has a error code c2 11 c4 12 why
Open following link for useful troubleshooting information:
Error code 11 is 'No ignition'
http://waterheatertimer.org/pdf/Paloma-Tankless-Error-Codes.pdf
Error code 12 is 'Flame Failure'
Ensure flame rod wire is connected.
Check flame rod for carbon build-up.
Check power supply for loose connections.
Check power supply for proper voltage and voltage drops.
Disconnect remote control.
Disconnect and re-connect all wiring harnesses on unit and PC board.
Ensure proper venting material was installed.
Ensure condensation collar was installed properly.
Ensure maximum vertical vent length does not exceed allowable limits.
Ensure maximimum horizontal vent length does not exceed allowable limits.
Range of causes are part failure, gas pressure loss, air in gas line, improper installation of gas line or vent, 120V power to unit is disrupted or unit not grounded, circuit problems, venting problems, remote control, wiring to PC board, board failure, carbon build-up on flame rod, short circuits on gas valve solenoids.
The fact that you have error code tends to eliminate your plumbing as culprit, the error code does not mention air supply, otherwise it looks like every possible cause is on the table.
Add a comment with your experience so other with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 25, 2011 | Rheem Tankless Hot Water Heater...
I have error codes "C2"
Open following error-code link in downloadable pdf for your files:
Error code 11 has to do with ignition/gas/gas pressure/electrical grounding.
This can be caused by internal part failure or combination of internal or external factors.
I suggest reading pdf, and then calling service technician who specializes in your brand.
Open typical manual to review required regular maintenance for tankless on page 29
The word maintenance is used throughout manual, indicating that tankless are a yearly budget nuisance
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
Open following link to view fixya questions on 1 model of Rheem tankless
Some older questions have information that is useful, and varied
This will give you cross section of problems that are faced by others with same/similar product as yours.
http://www.fixya.com/tags/rtg_74pvn
All costs are energy.
You can also add simple tank-type water heater that can be turned on when tankless is on the blink.
Mar 02, 2011 | Rheem Tankless Hot Water Heater...
Oct 16, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem RTG 53 PVN with fault codes C4 or C7
I had the same problem with my tankless waterheater (flashing c4 76 alternately). I called Rheem
tech support and they had me 1 power down the remotepanel 2 unplug the unit from the wall 3 remove the cover 4 remove the wires for the remote panel from the circuit board and pull the twisted pair that goes to the remote out from the bottom of the unit. 5 reinstall the cover 6 plug the unit back
into the wall and turn on the hot water see if it works. It did in my case and they are sending me a new remote panel. I hope it helps.........
Nov 21, 2008 | Rheem RTG-53PVN Indoor Natural Gas...
Rheem RTG-53PVP Indoor Liquid Propane Tankless Water Heater for 1-2 Bathroo Logo
71 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
