Question about Dishwashers
My dishwasher fills with water and then stops. it thinks that it is washing but never actually washes anything. It dumps the detergent out and everything but the spray wands never spin and water never circulates. Does the problem lie with the circulation pump or motor? Thanks in advance.
Take the filter off the top of the spinner assembly. Take the cover off the motor shift down in there . spin the shift by hand and see if it spins freely. If it doesn't you may have broken glass or other hard objects that prevent the motor from spinning. That worked for me anyway.
Posted on Aug 18, 2014
I have a kitchenaid dish washer that fills with hot water, then stops doing anything.
Posted on Jun 30, 2011
How do I stop baumatic dishwasher leaving a sticky residue on glasses and other articles on the top shelf?
Make your dishwasher more effective with these quick tips: 1. Check the sprayer arm. When I opened the dishwasher door during a wash cycle, I learned that some of my utensils are too tall, and they blocked the sprayer arm from rotating. Problem solved! Also look at the holes on the sprayer arm to make sure they are not clogged. Use a toothpick if you need to dislodge anything.
2. Check the drain. Look inside the bottom of the dishwasher and remove any food or objects from the filter. Run the garbage disposal to clear it out before turning on the dishwasher since they share the same drain.
3. Don't overuse detergent. It's a mistake to assume you should always fill up the detergent cup. Check the manual and your detergent. On mine, filling it to the first line (about a third) is enough. Too much detergent can leave residue and etch your glasses.
4. Check your water temperature. If it takes a long time for the hot water to reach your kitchen sink, that means the dishwasher isn't getting enough hot water at the beginning either, and that makes it harder to wash away the food particles and grease. If you need to, turn on the dishwasher after you've used hot water at the kitchen sink.
5. Clean the inside of your dishwasher. Grease, detergent residue, and calcium deposits build up inside your dishwasher. You can use vinegar to wash them away. On a regular basis (every few months or so), run a wash cycle while your dishwasher is empty. Don't use detergent, but turn on the dishwasher and let it run for a few minutes until water starts to fill up the bottom. Then add one or two cups of white vinegar to the water and let it finish the cycle.
Sometimes using a dishwasher is an experiment in finding the right combination for hard or soft water, the detergent, and a rinse aid.
Best of luck
BBBBB
Nov 30, 2014 | Baumatic Dishwashers
It is leaving a white film on everything.
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Sep 03, 2010 | Kenmore Dishwashers
What causes white powdery residue on glassware in the dishwasher. I think it is lime deposits. Can I use lime remover in dishwasher to eliminate the buildup?
If your dishes or glassware appear with a white film or a white powdery residue or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Sep 03, 2010 | Hotpoint Dishwashers
Maytag quiet series 300 dishwasher leaves glasses on top rack with film on it. What can I do??
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you’re using and adjusting your hot water heater’s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you’ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn’t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don’t use extra-hot settings such as “Power Scrub,” and use the “Energy Saver” dry cycle.
3) Don’t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading—dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home’s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20–120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn’t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals—the more grains per gallon you have, the more detergent you’ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn’t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn’t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn’t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren’t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Aug 26, 2010 | Maytag 24 in. MDB9750AW Dishwasher
ALL OF MY DISHES ARE COVERED IN A WHITE FILM. i'VE USED CLR, RUN BLEECH THROUGH THE SYSTEM. ...HAND WASHED ALL DISHES BEFORE PLACIING INTHE DISHWASHER. I USE CASCADE ONLY. SMALL AMOUNTS...
Please rate the solution if you feel I've helped you
Aug 22, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher leaves a film of soap on dishes. what needs to be cleaned inside as far as mechanics or is this dishwasher done?
Aug 05, 2010 | GE 24 in. GSD1000G Built-in Dishwasher
Film on glasses
May 07, 2010 | Whirlpool 24 in. DU1148XTP Built-in...
Dishwasher not cleaning the dishes anymore, leaves a film on
Apr 10, 2010 | Kenmore 24 in. 16299 Built-in Dishwasher
My profile dishwasher leaves a film on the glasses.
Oct 31, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
White film on glasses after a run.
Apr 18, 2009 | Thermador DWU244 Dishwasher
Dishwashers Logo
230 people viewed this question
Top Dishwashers Experts
