Question about Sharp AQUOS LC-32D43U 32 in. LCD Television
Re: K displayed and Volume control
Two issues.
I have a "K" in a smal box displayed on the screen at all times.
and my volume control is locked into three settings. 0, 30 and 60
  • jackdaddy May 25, 2008
    Thanks you very much.
  • 372 Answers
Hi.
Do this it will remove your set from factory mode.
  1. Unplug the AC power cord of TV set .
  2. While holding down the “VOL (–)” and “INPUT” keys on the set at once, plug in the AC power cord to turn on the set.
  3. The letter K should have disappeared from the screen.
Your set will now work correctly.
http://dysonmanuals.llc.nu/
Posted on May 25, 2008
How do I factory reset my lg7530 ?
  1. Turn the phone off.
  2. Press and hold the following keys at the same time: Volume Down Key volumedn_key.png + Power/Lock Key powerlock_key.png on the back of the phone.
  3. Release the Power/Lock Key powerlock_key.png only when the LG logo is displayed, then immediately press and hold the Power/Lock Key powerlock_key.png again.
  4. Release all keys when the Factory hard reset screen is displayed.
  5. Press the Power/Lock Key powerlock_key.png to continue or either of the Volume Keys volume_keys.png to cancel.
  6. Press the Power/Lock Key powerlock_key.png once more to confirm or either of the Volume Keys volume_keys.png to cancel
Jun 24, 2016 | Tablets & eReaders
I cannot hear any sound out of my Polaroid TDX-01930B television.
Hello
First make sure that the "Mute" function is OFF. If it is set to "ON", no volume will be there.
Your TV has a volume lock function included [Global Volume Lock].
The remote comes preset to allow independent volume control of each selected device (Global
Volume Unlock). However, you may change the Volume Lock setting to Global Volume Lock so that
one device's volume will control volume in all other modes. After that, you can perform Individual
Volume Unlock on a selected device to set its volume control for independent operation or Global
Volume Unlock to remove all volume locking.
Locking Volume Control to One Mode (Global Volume Lock)
[1] Press and hold SET UP until the red LED blinks twice; then release.
[2] Enter 9-9-3 and then press the mode key for the device you want to control volume (for
example,TV). The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected
device (for example, TV) will control the volume regardless of the current mode.
Unlocking All Volume Control (Restoring Global Unlock)
[2] Enter 9-9-3 and then press VOL+. The LED blinks four times.
Volume is now independently controlled for all programmed devices.
Unlocking a Single Device's Volume Control
[1] Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
[2] Press and hold SET UP until the red LED blinks twice; then release.
[3] Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
independently controlled for the selected devices.
OK
May 06, 2011 | Polaroid TDX-01930B 19 in. LCD HDTV
No any sound from the pc
Step 1
From the Task bar located at the bottom of your computer click once on the "Volume" icon.
Step 2
Uncheck the "Mute" box. If this does not resolve the issue, proceed to step 3.
Step 3
Right click on the "Volume" icon.
Step 4
Select "Open Volume Control."
Step 5
Uncheck all of the boxes next to "Mute" in the Master Volume, Wave, SW Synth (short for synthesizer), CD Volume, Mic Volume, Line Volume and PC Beep selections. If this does not resolve your sound issue, proceed to step 6.
Step 6
Right click on the "Volume Control" icon.
Step 7
Select "Sounds and Audio Devices Properties."
Step 8
Under the "Volume" tab, slide the "Device Volume" indicator to High.
Step 9
Under the "Speaker Settings," click on "Speaker Volume."
Step 10
Slide the "Left" and "Right" volume indicators to "High."
Step 11
Click "OK." If this does not fix your sound issue, proceed to step 12.
Step 12
Step 13
Step 14
Go to the "Hardware" tab and select the "Driver" tab.
Step 15
Make sure you are connected to the Internet and then, Click on "Update Driver."
Step 16
After the driver has been updated, Click "OK."
Step 17
Exit.
Please rate me if this solution works for you
Thanks......Have a great time.
Aug 01, 2010 | Intel DG31PR Motherboard
I cant get any sound on my computer. it is telling meno audio output device installed. and is pluged in
Please just follow the steps to fix the problem
  1. Step 1 From the Task bar located at the bottom of your computer click once on the "Volume" icon.
  2. Step 2 Uncheck the "Mute" box. If this does not resolve the issue, proceed to step 3.
  3. Step 3 Right click on the "Volume" icon.
  4. Step 4 Select "Open Volume Control."
  5. Step 5 Uncheck all of the boxes next to "Mute" in the Master Volume, Wave, SW synthesizer, CD Volume, Mic Volume, Line Volume and PC Beep selections. If this does not resolve your sound issue, proceed to step 6.
  6. Step 6 Right click on the "Volume Control" icon.
  7. Step 7 Select "Sounds and Audio Devices Properties."
  8. Step 8 Under the "Volume" tab, slide the "Device Volume" indicator to High.
  9. Step 9 Under the "Speaker Settings," click on "Speaker Volume."
  10. Step 10 Slide the "Left" and "Right" volume indicators to "High."
  11. Step 11 Click "OK." If this does not fix your sound issue, proceed to step 12.
  12. Step 12 Right click on the "Volume Control" icon.
  13. Step 13 Select "Sounds and Audio Devices Properties."
  14. Step 14 Go to the "Hardware" tab and select the "Driver" tab.
  15. Step 15 Make sure you are connected to the Internet and then, Click on "Update Driver."
  16. Step 16 After the driver has been updated, Click "OK."
  17. Step 17 Exit.
Jul 31, 2010 | E-Machines eMachines Desktop PC
Initial setup screen pops up at random times. The
The ability to control volume is often lost do to dirt or wear internal to the remote control. If that's the case then I would try a new remote. I universal one will give you the capacity to control volume, on/off and channel change. Try one of those (you need to program it for your individual model) and if that controls the volume you should replace your remote.
Concerning the spontaneous activation of your on screen display is also possibly coming from the remote. Put the remote in cardboard box or anything non translucent and see if that stops the problem. If it does stop it's the remote. If not your set will have to be seen by a professional electronics technician that hopefully is familiar with TV circuitry.
Apr 16, 2010 | Sony Televison & Video
Volume is too low.
smith,
good day, not so familiar with this model but try this.
1) try to check in your DVD remote controller if it does have a + and - buttons indicating volume , if does have this features press + button to increase the sound output
2) if remote commander doesn't have this features try accessing the " SETUP" menu. most probably there would be a button in your dvd remote indicating this button "SETUP"
3)once you've access the setup menu, there would be a dialogue box indicating ( Video setup, Audio Setup, display setup, parental lock) insome cases it will show you a display picture of all this menu
navigate the dialogue box and look for "audio setup" once you've access this part there would be options and controls where you can change the volume/audio settings .
cheers,
mark
Jan 29, 2009 | JVC HR-XVC25U DVD Player/VCR
No Sound
1) First check the mute.
2) Make sure there aren’t headphones plugged in, that will disable the speakers.
3) Check the audio setup
4) Check your Volume lock
Changing Volume Lock
The remote comes preset to allow independent volume control of each selected device (Global Volume Unlock).
However, you may change the Volume Lock setting to Global Volume Lock so that one device’s volume will
control volume in all other modes. After that, you can perform Individual Volume Unlock on a selected device to
set its volume control for independent operation or Global Volume Unlock to remove all volume locking.
1. Press and hold SET until the red LED blinks twice; then release.
2. Enter 9-9-3 and then press the mode key for the device you want to control volume (for example, TV).
The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected device (for example,
2. Enter 9-9-3 and then press VOL+. The LED blinks four times. Volume is now
Unlocking a Single Device’s Volume Control
1. Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
2. Press and hold SET until the red LED blinks twice; then release.
3. Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
Mar 15, 2008 | Polaroid FLM-2632 Television
Sound Issue
Check the cable box volume. Most boxes allow you to adjust the volume from the box to the TV, and most likely it's gotten turned down. Use the "Volume" control on the cable box to bring the level back up. (Unless the box remote has been set up for RCA, it controls the box volume. Once you get the volume back up, follow the cable provider's instructions for setting the remote to control an RCA. Then the volume control will function correctly.)
Feb 22, 2008 | RCA F27440 27" TV
Picture too large for screen
If the television is connected to a cable box such as Time Warner's HD box, the picture mode can be changed by pressing the '#' on the cable box's remote keypad (where the channel numbers are). This cycles the picture between zoom, normal, and stretch which could be cause of your problem.
Aug 18, 2007 | Toshiba 50H13 50" Rear Projection...
Sharp AQUOS LC-32D43U 32 in. LCD Television Logo
611 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
