Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Need to get out old motor rotor assy so we can put new one in.
  • 552 Answers
This video will wok you through your Fisher Paykel repair, how to fizz a f1 error code and how to replace the rotor.
http://www.appliancerepairlesson.com/shop/dishwasher-videos/fisher-paykel-dishwasher-repair/
Posted on Feb 26, 2011
Any used Toyota diesel engine available for sale in UK ?
Hi Friend,
There are many online portal they provided used engine and Automotive part in UK. for your reference you can visit below given website.
Feb 02, 2015 | Toyota rav 4 rotor assy, alternator
How to replace distributor on 2000 Chrysler Cirrus
Clear any other components in the way. Take the distributor cap off, leaving the wires attached. Note or take a picture of the orientation of rotor to the motor. unbolt the distributor and pull it out. Do not crank the engine while the distributor is out. I think yours cannot be put in wrong but no need to tempt fate! Install the new distributor with the rotor in the same position as the old one. install your new cap and transfer each wire from the old cap, one by one. Put all the other stuff back on. While you do this job think about a new set of plugs. All done!
Jun 05, 2014 | Mitsubishi Electric Automotive 1995 - 2000...
We have a maytag neptune washer and it is suddenly not working and displaying a code of LU it kinda looks like>?
perhaps and lr??? LR--- means locked rotor assy. you will need to replace your motor control board and motor assy, comes as a kit not a bad repair (NEPTUNE REPAIR KIT) if thats indeed the issue you seeing that is
Oct 09, 2010 | Maytag Neptune Washer
Nissan ca20 e distributor replacement. How do I replace dizzy in correct timing to line up with tdc
if you take old dizzy out,wherever motor is stopped,just put new one in,taking note of position of rotor,to where the old rotor was pointing.pick a spot on the motor or bonnet when you first take cap off,to where rotor is pointing,then note where dizzy sitting in relation to clamp bolt.OR,get timing pulley on TDC,then note where rotor pointing
Jul 06, 2010 | 2004 Nissan Sentra
Installing the flexible drive shaft from the motor to the rotor head. I pulled off the rotor head thinking I had to do this to replace a new plastic line assy. Now I can't get the flexible shaft to...
At the motor drive end, (where the engine is).. the end of the flex drive should mate with the clutch housing. You may just need to remove the clutch-housing cover in front of the motor to access it and turn it until it accepts the flex drive.
Jul 04, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
How do i change the driver side front hub assembly
The vehicle will need to raised on the left (drivers) side and supported. Remove the tire, then the brake caliper assy. Remove the rotor, then remove the axle nut located in the center of the hub assy. Remove the hub/bearing retaining bolts, and then the hub assy. Some times it is corroded into the steering knuckle assy. and will not seem to come out. If this happens, install the axle nut, and wearing safety glasses, pound onto the hub flange from the inside to the outside, until it comes out of the knuckle assy. Then remove the hub assy. Clean the knuckle hole where the bearing with 120 grit sand paper, so the hub/bearing assy will go into the knuckle without damage. Torque the axle nut to specs. Clean the inside of the rotor, where the hub meets it, so it sits flat against the new hub. Install the rotor, caliper assy. Install the wheel and torque the lug nuts to 100 ft pounds. Road test about 5 miles and recheck the lug nuts.
Jan 19, 2010 | 1998 Ford Explorer
How do you get the hub off?
hi from uk to remove rotors/ discs as in uk remove wheel then remove the sprung clip that holds caliper to mounting remember how fitted ! then remove the 2 x bolts securing caliper to the carrier these are at rear of caliper then remove caliper carefully as not to put undue strain on hose ? the rotors/discs are simply secured to the hub assy with 2x countersunk crossheaded bolts/screwed into hub then you may need to tap disc/rotor firmly from b/hind to remove off hub ? reassembly is reverse proceedure just one bit of advice ! these contersunk bolts can round off the x/head but if you use a good driver and hitimpact the driver in bolt it usually frees em or if you have impact driver ? no problem ! if the bolts fail to come out? do not worry ! just drill off the head of bolt and remove disc/rotor these bolts are onle fitted to keep the wheel bolt holes in line with rotor when wheel is removed so play no part in braking !hope this explains clear to you remember !new rotors new pads! not old ones and make sure you bleed the both brake calipers to rid of old fluid from calipers this will make a dfference to your brake feel and operation/travel of pedal good luck
Nov 15, 2009 | 1996 Hyundai Accent
Stuck Brake Pad Pins
I suggest pulling the axle out a bit to allow the caliper assy more freedom of movement. Then see if you can get the pins out. If not, you can put something (like a piece of wood) between the pistons and the rotor on the outside and gently pump the pedal to see if that does in fact loosen the pins. But a more fundemental question: is the new floating rotor the EXACT diameter as the OEM (or whatever was on there) rotor? It sounds to me like the rotor is jammed against the pins. If it is the same size, are the new pads the same shape as the old ones (same profile on the metal backing)?
Nov 20, 2008 | 2002 Harley Davidson FXST Softail Standard
Neptune Washer
lr is a code for a locked rotor assy, on the motor itself, depending on age of machine you might have warr on the motor(part anyway) check your user guide and warr info. probably gonna need to install a "neptune repair kit" which includes new motor and new motor controller
Nov 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Replacment of wheel lug bolts on rear wheels
The bolts can be replaced 1 of 2 ways w/o pulling axle. Need to take rotor off and either press bolts out with an arbor press or can be tapped out with a copper or brass hammer. Once out, the new ones can be pressed in by putting about 4 or 5 washers on and then tightening the lug nut down until the lug is pulled snug into the roter. Once snug, the roter can then be reinstalled on the wheel and brake assy put back. Caution!! Brake assy needs to be supported up out of the way with wire or coat hanger while removing rotor. Undo force of weight on brake pad assy can damage hose or unit itself.
Jim Pochurek
Aug 07, 2008 | 1999 Dodge Durango
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
296 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
