Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Have the badger 5. I try pushing the reset button and still wont work. Can I try something else
    President:
  • 1,796 Answers
Hi!!
In the bottom center of the disposer (by where the reset button is). there is a hex shaped hole, where you insert the garbage disposer too, usually attached to the body of the disposer. If the tool is not there, use an Allen wrench, 1/4" I believe, to turn the disposer first counter clockwise to get it loose, and then clock wise to check if it got loose. Some times, you have to insert your hand in the sink hole and remove wherever object is making it stuck. Before you do this, unplug the unit from the wall outlet to avoid possible injury.
Don't forget to rate this post!!
Posted on Sep 29, 2010
Badger 5 just clicks when I try to turn it on. It is only 4 years old. We tried reset button, checked blades for something lodged in it, and unplugged and re plugged.
Use broom handle and see if blades turn freely.
If blades turn freely, and disposal makes clicking sound to indicate that you have power, and reset button is not tripped out, then disposal has gone bad.
If unit still looks new, then buy identical disposal from store, replace just the disposal body, and return defect in new box.
I wrote ez disposal replacement steps from when I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jun 18, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a Badger 5 (5-81A). The motor is humming when it's turned on, however, the blade does not turn. The blade does seem to move freely. Tried reset and hex key but still nothing.
you have something stuck in it more than likely,, use the key ( unplug it first) and turn it backwards,, keep looking inside with a flashlight for the lodged object once you see it,, remove it,, sometimes the key won't work if its something caught in the blades themselves, so use the handle end of a broom or plunger with a wooden handle to push on the blade itself to turn the unit over
May 02, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 1 1/3 insinkerator not grinding
Hi, Sounds like motor went bad..
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
May 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
DOES RESET BUTTON PRESS AND RELEASE TO RESET5?
it should pop out,when motor over heat's. you push it up and you may or may not feel a slight click when button is pushed.it should stay in when pushed.
May 12, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Our SinkErasor Badger 5 doesn't work.Wrenchette can't be rotated
MAKE SURE THERE'S NO STUFF INSIDE THE DISPOSAL. PUSH RED RESET BUTTON, (USUALLY UNDERNEATH OR ON SIDE) IF THERE IS ONE. THE DISPOSAL ALSO CAN BE TURNED USING A 1/4INCH ALLEN WRENCH. USUALLY INSERTED IN BOTTOM UNDERNEATH OF DISPOSAL.
Dec 15, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Is there a reset button on the Badger 5
Yes, on bottom a little recessed button should be pushed to reset the device. If the blade is stuck, the reset might not work but just keep tripping the breaker so you have to free up the blades with a broom stick or other item stuck into the disposal (with the power off of course) to turn the blades manually. Then try the reset button again. and hit the switch. Otherwise, check your kitchen's electrical breaker to see if it has tripped as well.
Aug 02, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Disposal wont work
The reset button might be around the back, depending on which side the outlet is located on. It takes quite a good push to reset it.
Feb 15, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage Disposable won't work.
If the cutter plate will turn freely, look for a reset botton. Some units have them and depending on how it was installed, it will be around the back. It should be a push button, about 3/8" diameter. It takes a good hard push to reset it.
Jan 03, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
191 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
