Question about GE Monogram ZISx420DR 42-inch Side by Side Panel Ready Built-In Refrigerator with Dispenser
I have the GE Monogram Z1SB42DY. The front of the wall that separates the freezer from the refrigerator is so hot it can burn your hand! We noticed this starting to happen over the last few weeks. We were having trouble keeping the temps consistent. I turned the temp control to the freezer off and tin about 15 minutes, all of the separation wall was now cold. I then turned the freezer temp up to 4 and within 3 minutes, the front of the wall was hot to the touch. Also, the ice maker stopped working late last week. I cleaned the condenser and coils (I did notice corrosion at the bottom of the big black part (I'm not sure what it is). Also, GE came out in '08 and installed the Icing Kit. Any input would be helpful! Thanks
  • 109 Answers
SOURCE: GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Posted on Mar 31, 2008
docjohn174
  • 943 Answers
SOURCE: GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Posted on Oct 15, 2008
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
Sea Breeze
  • 4655 Answers
SOURCE: My refrigerator is a GE Monogram ZISS480NRGSS S/N SH031008. The temperature in both the freezer and the fresh food sides increased and did not go down. A technician came in and changed a valve (I do n
We need to have a look at the main control board part number WRO2X11838 Tell me if the compressor is running while no cooling or if stopped. Unplug refrigerator and see if the top of compressor is too hot to keep you hand on. My drawing show the control bord in the area of the compressor and inside a box. Let me know if it has burn marks on both sides. Thanks, Let me know, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 21, 2009
aasc
  • 1606 Answers
SOURCE: GE Monogram ZISB36DYB Freezer Not Cold Enough; Burning Center
Pull the refrig out , and remove the panel at the bottom , on the back . Behind this panel , will be the compressor and condenser " roll " coil , and the condenser fan motor . From your description of the problem , the fan motor in not operating , or the coils are extremely clogged with dust . If the fan motor is not operating , the most likely cause , is the main control board . You can try replacing the motor first , but , the board is most likely the cause . This is the electronic board , behind the 8 " X 10 " panel , behind the refrig also . If you remove the panel , and look at the board closely , You may see a burned part ( resistor ) . However , replacing the burnt part , will not solve the problem . The complete board will need to be replaced .
Posted on Oct 14, 2009
I have a 10 year old GE Monogram refrig. We noticed a small puddle of oily liquid on floor beneath freezer door. It is accumulating about 1 tsp/day.
certain amount of oil is in the compressor motor casing to stop it burning out
it is under the same pressure as the refrigerant
I would say the oil comes from that casing
you could turn the fridge off at the wall
bring the fridge out to get behind it
and degrease the area to see if the leak is severe
if it is..... needs a fridge technician
not sure
check if cost of replacing the motor compressor unit
on a ten year old ge
might be more that fridge is worth
Nov 10, 2016 | GE Refrigerators
Hot center wall in refrigerator
This is more likely to a defrost heater sticking on and not turning itself off, could be either a timer, board or defrost temperature sensor issue
Apr 03, 2014 | Refrigerators
Ge zisw48dyb hot to touch on middle bar front between doors
Pull the refrig out and remove the lower panel . Check that the fan motor is working and no object is blocking the blade to keep it from turning . If your compressor is a top model , remove the top cover and check the fan motor and coils for dust coverage .
May 01, 2010 | GE Monogram Side by Side Refrigerator
GE Monogram refrigerator does not cool. The fan on top was loose and not spinning. I fixed that, and it now spins properly, but he freezer and frig will not cool at all.
I need you to pull away from wall and remove cover over compressor and feel compressor for heat. If too hot to hold hand there or if warm or just cool. Tell me what you find. I would like to help you solve this if you like. Sea Breeze
Feb 21, 2010 | GE Monogram ZISS480NRSS 48" Built-In...
Vertical divider separating the refrigerator section from the freezer section is extremely hot to the touch on the exterior surface. So, hot it almost burns your hand. What could this be and how would I...
The fan behind the fridge at the bottom which cools the compressor , is not turning . Remove the back panel covering the compressor and see if something is blocking the blade . If not , motor is bad , so put a small fan there to keep the coils and compressor cool until you can get a new motor .
Aug 09, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
I have a side by side GE Monogram. When closing
the refrigerator should be leaning back enough to allow it to reclose. there are hieght adjusters behind the grill on front
Jun 12, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram will not accept freezer/fridge
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
Jun 05, 2009 | GE Monogram® ZISS420DMSS Side by Side...
My refrigerator is a GE Monogram ZISS480NRGSS S/N SH031008. The temperature in both the freezer and the fresh food sides increased and did not go down. A technician came in and changed a valve (I do not...
May 20, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Freezer not working properly
Your heating element has failed and needs to be replaced, the heating element keeps your coils from icing up and in return when then go bad cause this problem.
May 16, 2009 | GE Monogram ZISB360DR 36'' Trimmed For...
Freezer door is canted forward. This separates the gasket from the frame and allows air in. Large amount of frost build up.
HI thanks for the question. the fridge door should close by itself if opened and then just let go of door. if not that way. raise the front of the fridge to make it work that way. thanks the appliance doc. please rate my answer. thanks.
Aug 11, 2008 | GE Monogram ZICS360NRRH C... Bottom...
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
