Question about Microsoft Windows Vista Ultimate Edition
PRINTER WILL NOT PRINT PHOTOS
My Epson C42UX will not print photos although when I click on print the computer says it is sending information to the printer but nothing happens. The printer works fine on writing ,can anyone help.
  • Bryan Findler May 26, 2008
    Hi bigbags thanks for your help did as you said but there does not seem to be a Vista driver for my Epson C42UX but thanks again .Do you know what type of printer I should go for.
    Bryan(Brinner)
  • Bryan Findler May 27, 2008
    Tried that only way it prints a picture is when i close the computer down,then when I switch it back on the printer prints the picture is this correct to do this.
    Regards Bryan
    Sergeant:
  • 336 Answers
You might want to try shifting the USB cable that leads to the printer because the connection with USB can sometimes be the problem.
Good Luck!
Posted on May 26, 2008
  • Ryan Frame
    Ryan Frame May 29, 2008
    I don't recommend that. I would see if just waiting will fix the problem.
    RCF
    Sergeant:
    Champion:
  • 326 Answers
Goto the Epson website and get the Vista driver. Uninstall the printer from the control panel - printers then goto control panel - system - add/remove and remove all printer programs. Now reboot and when the system detects the printer use the downloaded driver for it.
  • Rory Biggs
    Rory Biggs May 27, 2008
    I use the HP F300 series. But the newer epxons should work with vista. Good luck.
  • Rory Biggs
    Go to the properties of the printer. There is a checkbox that tells the printer to print now. it may be waiting for a default time and when U reboot it closes out it dumps the print command. If this is not the case, look at the printer setup under the control panel - printers.
Epson stylus c42ux how do I put in new ink? I can't get to the print cartridges
Power up the printer and open the lid. The print head should come to the center. When you close the lid, it will go back to it's park position. Don't pull it over with the power off.
Jun 01, 2011 | Epson Stylus C42UX InkJet Printer
How to print photos on dx4850 from memory card
DX4850 is not designed to print photo's standalone; epson creativity suite software is required at this link
Once installed (along with printer drivers), a memory card may be inserted into the printer, to be followed by a notification from computer that a new drive is included in the system.
In case of ms-windows, there are two ways to print a document:
1. Select drive (under My Computer) and right click desired file and just select print.
2. Run epson easy photo print software and select file(s) to print and the package will guide you till printout.
As simple as that.
good luck
Dec 03, 2010 | Office Equipment & Supplies
I am printing a collage of photos on cardstock (for a calendar) using an Epsom Artisan 810. White vertical lines appear evenly spaced along the landscape format. My wife says it is due to the poor...
When you print photos, in Preferences you have to set up the quality of the print to either Best or Photo whichever is the highest one in the list. Hopefully this will increase the quality of the printing, although this is not a photo printer. And you are correct, it's a printer problem.
Nov 30, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How to load 4X6 photo paper
hi
  • Turn on the Epson 875DC and the attached computer. Make sure the cable between the two devices is securely in place.
  • Step 2 Remove any paper that is in the printer's feeder tray. Place the 4x6 photo paper printable side up in the tray, with the support sheet at the bottom of the stack of photo paper. Adjust the paper guides so they are pressed against the margins of the paper.
  • Step 3 Open the photos to be printed in your computer software program of choice. When you are ready to print the photos, click on the "File" link at the top of the window, then choose "Print." Click on "Properties" and select "4x6" for the paper size and "Photo Paper" under the paper type. Click "OK" to close the "Properties" window, then click "OK" again to print the photos.
  • Jul 02, 2010 | Brother MFC255CW All-in-One InkJet Printer
    Linked r300 to pc running windows7.can print photos but not cd's.
    Download and install the latest print cd software from here.
    http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-Photo-R300/Drivers-Support?target=driver&languageId=1&driverId=324514&defaultOSId=3&DRV_CATEGORY_CODE=CREATIVITYSOFT
    Dec 21, 2009 | Epson Stylus Photo R300 InkJet Printer
    The text of a document will not print. The
    Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
    For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
    Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
    No shadow density in photograph printing
    If you haven't been printing for 6 weeks, your print head is clogged, which is why the print quality is poor. Turn your printer on. On your computer, go to START, then SETTINGS, find PRINTERS AND FAXES and click on that. A window will open and you should see your printer. Right click on it, then click on PROPERTIES. A window will open, with several tabs. The one you need is MAINTENANCE. Open the tab and click on CLEAN PRINT HEAD. I think there are 2 options, cleaning and deep cleaning. Click on deep cleaning. You should hear the printer rumbling, then, when it finishes, it should print a page with 4 colors: black, cyan, magenta and yellow. If the colors come out right, you're done. If not, repeat the cleaning until you get a satisfying result. Just bear in mind that cleaning the print head uses a lot of your ink, so I suggest you put the refilled cartridges when performing this operation.
    Also, to avoid getting in this situation again, I suggest that you print one page, at least once in 10 days. That way, your print head should always work fine.
    If you found my answer helpful, please vote, it really means a lot to me to know weather I am helping someone or not.
    Jan 13, 2009 | Epson Stylus Photo® RX620 InkJet Printer
    Epson cx5000 Ink Cartridge shows ink is running out after 2 8 x 10 prints.
    IT IS POSSABLE THAT THE PRINT HEAD ARE DIRTY THEY HAHVE MATCHING BOARDS TO THE TONER CARTRIDGE BOARDS UNPLUG THE MACHINE AND CLEAN THE PRINT HEAD WITH ALCOHOL IF IT DOESN'T WORK THE BOARDS HAVE FAILED
    JP
    Dec 31, 2007 | Epson Stylus CX5000 InkJet Photo Printer
    Microsoft Windows Vista Ultimate Edition Logo
    51 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
